Suggestions for monitor for PinballX tables, I have questions
I want to change my monitor for my pinball machine. The size I can use is 21.5 inches.
Could someone advise me on this monitor for the tables? It's an MSI4307 21.5" FullHD LED IPS. According to the specifications, how do you see it for tilt and table viewing?
Not sure what you exactly mean with this.
I don't have experience with that monitor , but if it can run 100hz with full HD, it will be sufficient to run tables smoothly (if your video card is able to produce this).
1 hour ago, DakotaPinball said:
Oops, well, I hadn't thought about the graph, I thought so, thank you, I'll look for information to know if it's worth it
Even if the GPU can't do 100hz it would probably be fine for HD @ 60Hz so you could run that monitor at that refresh rate until you have chance to upgrade GPU.
The change of monitor may still be worthwhile even if you can't currently run at 100Hz refresh rate. It depends what you have now, panel type (IPS/VA/TN) and whatever input lag that has.
Don't think you'll find many people running VPX with the combination of a GTX970 with a FullHD display and the latest tables so it's unlikely you'll find out if it can run 100Hz smoothly without trying it unfortunately.
If you turn off certain Windows visual settings you may make up for some of the limitations of your GPU.
