I desperately need help. I don't know what happened to me, but my PinballX has lost its last customized settings.
Pinball Wicked
Pinball M
Pinball FX (it's configuring it)
Pinball Collection HD
Is there an .ini file that saves the Setting.exe configuration where I set all the parameters with PinballX? The same thing happened to me, but I made a copy of the Config directory, but all I have here is pinballX.ini.
  • Draco1962 changed the title to Need help finding customized settings
Did you read the PinballX manual?
PinballX.ini is indeed the configuration file where all settings are.
Each system also has an XML file in the databases directory, followed by the folder which is the system's name. The XML file with the same name as the parent folder is the main XML file. Other XML files will be shown in the lists menu.
  • Thanks 1
