Hello. In GameEx Arcade edition, how do I make the game information appear (see image) in the upper left corner and the rom name not appear? Thank you!!
The title is hard coded to display. Please submit as an enhancement request here:
I don't understand. I have GameEx installed on 2 computers. The one I'm going to use for the arcade machine and on a laptop where I do tests.
In the first I get the name of the rom and in the second (the laptop) I get that information, but I don't know how, because I haven't requested anything at any time...
There must be some small differences in your two setups. GameEx uses the data you supply it with and point to when configuring the directory paths.
The application simply is displaying the information made available to it.
So, If game info is showing on one and not the other, it must be some difference between the two.
Would really benefit from you attaching copies of your gameex.ini and log.txt files from both systems to compare as we can only guess and I really suck at guessing.
Glad you got it sorted and are seeing what you want! Thanks for letting us know!
  • Draco1962 changed the title to [RESOLVED] Mame game info
  • Draco1962 locked this topic
