Hello,
where can I find version 1.9 of pbx recorder because I am having a problem with pinup which does not close between
 the video capture of each table.
THANKS
HELLO,
I have the following message.
Oops!
This attachment is not available. It may have been removed or the person who shared it may not have permission to share it to this location.
But this morning the download of the part still started. I'm going to try this program.
THANKS
Can you tell me where the created video files are stored, please? Because they are not in the pinballx media as with version 1.6.
THANKS
PBXRecorder has its own log file (same location as the exe), check that, it should log where the files are being created.
If you overwrote your PBXrecorder.ini file and don't have PinballX installed in C:\PinballX then that might be the issue as PBXRecorder defaults to that location (if that is the case update the PinballX install location when starting PBXRecorder).
THANKS
Are you using 1.6 or where you able to download 1.9 ?
I think I unzipped the 1.9 file incorrectly.
It works for backglass.
On the other hand, I have an error for the playfield, probably due to the audio.
I don't see the Stereo Mix device in the Windows sound recording pane even when displaying all devices.
Or should you type the ffmpeg.exe -list...... command?
THANKS
Maybe your sound card / drivers do not support stereo mix, what do you see with disabled devices shown in the sound settings recording pane?
Try recording without playfield audio selected and see if that works.
  On 10/26/2023 at 12:59 PM, duv67 said:
yes it works without audio.
I think audio was added in PbxRecorder V1.9, so you may have to record without audio as you did in V1.6 (and then use table audio files as well).
@jejegameex might be able to assist further, but i don't think your sound card is compatible with audio capture from PbxRecorder.
  On 10/27/2023 at 8:59 AM, duv67 said:
How do you get sound in the wheel for the presentation of the tables?
Audio files go in the PinballX\Media\Visual Pinball\Table Audio folder.
Have a look at this thread Table sound when browsing tables - PinballX Media Projects - Spesoft Forums (gameex.com), or download the files from the Gameex FTP site.
Files need to named to match your table name, if you download using Database Manager then the files will be renamed and placed in the correct location for you (i think that is also the case with Game Manager).
The FTP site is free to all users these days :)
Thank you for the link. This may be a fallback solution for me.
But I would like to record my own audio files so that they are synchronized with the images,
especially for the puck packs.
I'll try to find a sound card.
Does this mean that the issue is resolved for you?
According to google, Microsoft 'voice recorder' should capture voice or the system sound.
  • Draco1962 changed the title to [RESOLVED] pbx recorder
