 Can any one help I keep getting the attached error when installing pinballx on Win7 see photo.
Is it a new install or an update, and what version is being installed (the normal PinballX version or the xp/vista version [32 or 64bit])?
If an update try deleting flash.ocx and running the installer again.
(i'd also be tempted to click ignore just to see what happens - but that's just me!)
Hi its a new install, i have even rinstalled windows and installed issue occurs as i install Pinballx, even tried as administrator and still have same issue.
Does the installation complete after clicking Ignore? If so, try the steps noted here:
The instalation completes after clicking ignore, I can delete the ocx  out of the Pinballx directory, but the program will not load up at all, I can get into game manager and settings both open up and work OK.
Pinballx won't launch, I have service pack 1 installed.
I will check the others tonight.
Does it creates an app error eventlog ?
  • Draco1962 changed the title to [RESOLVED] Issue Win7
