Hello,
The table loads I can put coins in and use the plunger. When I try to use my flippers the game freezes. Also if I let a ball drain 2 other ones automatically plunge and just drain. Any help on this?
15 hours ago, Rpags7474 said:
Hello,
Is this only happening if you launch the table via pinballx or also when yoy launch the table manually from the operating system ?
If you alt-tab, is there a vbscriot error from visual pinball ?
  • Thanks 1
  • Draco1962 changed the title to [RESOLVED] Stranger things issues
