my files are in another location than the tutorials say...
Hi ,
I tried about everything but my files are in this location :
D:\Games\Emulators\Visual Tables\Tables .
Does that mean I have to adjust these parameters too?
/open -"[TABLEPATH]\[TABLEFILE]" /play /exit /arcaderender /STAYINRAM
If so I have to do that for mame as well.
hope it will get better now :)
You should not change anything to this.
Paths can be changed what you did in workibg path and table path.
(Can someone move this to the correct thread ?)
Moved to the correct subforum.
Please attach copies (no copy and paste) of your pinballx.ini and log.txt files when reporting an issue or requesting assistance. Thanks.
For VP the parameters are different to FP
For VP try something like
-minimized /play -"[TABLEPATH]\[TABLEFILE]"
(and for VP also set enable launch before to No)
Hi all,
Here are my files. PinballX.ini
log.txt .
@scutters When putting vp to no as a result the tables won't show up anymore ... so when I try to load a table of any kind I get this :244494918_Loaderror.thumb.png.57a0fdb2fe8b4b39b252b1b5394cf005.png
I hope you will be able to set it straight... and thx in advance.
greetz,
BrutalJoke
