Stato:    Connessione TLS stabilita.
Comando:    USER slashguns04
Risposta:    331 Password required
Comando:    PASS *******************
Risposta:    530 User cannot log in.
Errore:    Errore critico: Impossibile collegarsi al server
Why?
i thinks this belongs in general section.
it is possible that you can not login because you are a basic member and not a lifetime / contributing / supporting member but i can not verify that because i'm a lifetime member so it's only a guess as i'm not sure users would be able to login and browse the ftp if they don't have access
Basic Member - 15MB Upload space. FTP upload only. 20 saved personal messages. 5 downloads a day from download section, 10 second wait, 150MB per day. No access to PinballX download service. No access to GameEx Onliine and FTP. Advertisements shown on forum.
on ftp it says Upload only (port 22) the 5 downloads per day and 150 mb is for files hosted on this site here itselve not for the ftp.
If you really do not want to pay (or can't pay) for the ftp you could try some facebook groups (pinball fx3 community, visual pinball addicts etc) or record them yourselve. Someone just asked the same question and someone posted a link to their google drive. I'll pm you the link but best you join those communities as well files are getting shared there also
3 hours ago, slashguns04 said:
I read that basic users can download up to 5 downloads per day and 150 mb
That is a reference to the forum downloads, not FTP.
Is your FTP client configured correctly?
https://www.gameex.info/forums/ftp/
It could be a permissions issue, but you should confirm your client settings until such time Tom has an opportunity to review your user profile.
Edited by tthurman
<edit> Merged with original topic
  • Thanks 1
btw even if you have access you can use http://ftpbrowse.gameex.com/ in google searches just type what you are looking for followed by the addres or even inurl:address then if it finds somethings you browse to it using ftp that way you can for example find which users in others section have uploaded fx3 / fx2 stuff
for example to find pinball fx3 stuff if the folder is named "pinball fx3" you search for https://www.google.com/search?q=pinball+fx3+inurl%3Ahttp%3A%2F%2Fftpbrowse.gameex.com%2F&oq=pinball+fx3+inurl%3Ahttp%3A%2F%2Fftpbrowse.gameex.com%2F
look at the address and browse to it using filezilla client to same directory
  • Thanks 1
Just now, slashguns04 said:
is there any pack in particular of the future pinball and visual pinball tables that with ftp automatically download and match all contents?
not sure i don't download future pinball but you can match content using game manager (if you entered login data in settings.exe) but i'm not sure if it has future pinball stuff. you mostly have to rename yourselve to match whats inside your database. Over the years there have been many table releases and not everyone names are the same when they upload on ftp so there is no easy way to do it perhaps using game manager but it is possible most content is vpx. Should check the others section as well
there are some video's here /-PinballX-/Other Uploads/TerryRed/Future Pinball (Updated with Topper Files) and docklets here /-PinballX-/Other Uploads/DownloadSnaps/Future Pinball Docklets/ thats all i could find future pinball related, not in the main sections
  • Thanks 1
