i am getting error code 530 when logging into online.gammex.com with any of my ftp clients.  can someone take a look?
Were you able to login in the past? Are you using the same credentials as you use to access the forums?
yes on both counts..530 usually means an issue with home folder on the ftp server i think?  ive tried my username and email address..same issue
I have no problem accessing the server via FTP. Likely it is not a server issue. 530 is usually an authentication issue (Incorrect login credentials or other setup issue for the FTP site in the FTP software).
Some things to check are that the FTP program you are using is not being blocked by your firewall. You may need to add it as an exception to allow for the FTP server to authenticate your connection from your PC.
Working fine for me also.
it did work in the past for me...i see the link you sent explains that founding member would not have ftp..but the mail pinballx page still says its free ftp access...can someone confirm what i need to purchase to get access again?
Free access is available to upload content only.
