same issue for me --> I'm on the latest version of PinballX and up to date on my windows 11 pro drivers. This has just started happening recently (last week or 2) --> I'm rolling an iPac2 for about a decade, the usb version.
Please attach copies of your pinballx.ini, log.txt file and answer these questions:
Have you tested other USB devices on the same ports to confirm no issues with the same ports?
Have you checked Windows Device Manager when inserting the cable directly via PS/2 and with USB adapter?
Any device errors showing? Likely it will appear under HID (Human Interface Devices).
When you plug in the PS/2-USB combo or just the straight PS/2, have you checked for changes or errors in Windows Device Manager?
Have you tried uninstalling/reinstalling the I-PAC2 software/drivers? They will sometimes corrupt over time.
Have you reached out to Ultimarc for assistance? [email protected]
Have you tested other USB devices on the same ports to confirm no issues with the same ports? - No Issues
Have you checked Windows Device Manager when inserting the cable directly via PS/2 and with USB adapter? - I'm full USB
Any device errors showing? Likely it will appear under HID (Human Interface Devices). - No
When you plug in the PS/2-USB combo or just the straight PS/2, have you checked for changes or errors in Windows Device Manager? - USB Only
Have you tried uninstalling/reinstalling the I-PAC2 software/drivers? They will sometimes corrupt over time. - I have not because everything else works as expected
Thanks for the quick response!
PinballX.ini log.txt
Sounds like an issue with modifier keys (shift/alt/ctrl) not sending 'repeats' when held down following a windows update  (KB5083769), see Autorepeat stopped working on certain keys since latest update - Microsoft Q&A (but i don't think the fix proposed there will work!)
Instead, here's a few different possible solutions/workarounds. Easiest/least risk first;
  • Thanks 1
