Using parts from this build, GPU from @ClassicGMR, and parts obtained from a Thermaltake case I acquired, I decided to refresh my niece's PC experience as she experienced a bad PSU and was in need of a slightly smaller case than the Antec P280.
Retro-Modern "Flip" Build
Core Hardware
  • Intel Core i7‑2600K
  • Intel DZ68BC motherboard
  • 24GB DDR3‑1600 Corsair Vengeance
  • NVIDIA GTX 970 4GB  - Thanks @ClassicGMR
  • Samsung 840 EVO 500GB SSD (Boot Drive)
  • 1TB WD 5400RPM HDD (Storage)
  • Cooler Master Geminii S524
  • Apevia Prestige Power 800W 80+ Gold
Networking
  • TP‑Link Archer T9E AC1900 PCI‑E WiFi Adapter (replaces N900)
Case & Cooling
  • Thermaltake V3 Black Edition
  • 5× Apevia Cosmos 120mm Blue LED fans
OS
  • Windows 10 IoT Enterprise LTSC 2021
Top 2 images of the completed build
3rd image - Inside before I went zip tie crazy with cable management!
4th image - Intake and exhaust airflows, but minus the fan on the floor
  • Draco1962 changed the title to Niece's Retro-Modern "Flip" Build
A 2nd Gen i7 and 24GB RAM is a nice combo. The quad core still can run a lot of things and the GPU definitely helps. Hell the RAM running at 1600 instead of 1333 is nice!
Yeah I had two different kits of Vengeance - an 8GB (Black heat spreaders) and 16GB (Blue heat spreaders). My CDO normally wants everything to match, but, due to the same shapes and the blue & black motherboard aesthetic, it just works.
She's spent several days playing GTA V online with nary a stutter or freeze. Before with only 8GB and the much more limited Gigabyte GeForce GTX 660 OC 2GB GDDR5 barely kept up. She practically has a new PC and can play almost all but the most demanding AAA games.
  • Draco1962 changed the title to [GAMING PC] Niece's Retro-Modern "Flip" Build
