I'm looking to run some of my Android/Flash games within PinballX.  I can launch them fine, but need the cursor to be visible for gameplay.
Is there a way to switch off the "Hide Cursor" option within a specific system?
Thanks!
Not that i know of, i think you'll have to have the 'Hide Mouse Cursor' set to No and then just move the cursor to the side of screen when a system is launched where it's not used
Wouldn't GameEx be a more suitable solution? PinballX's primary function is pinball emulation, and mouse input isn't required for gameplay.
Would likely run into the same issue as hiding cursor is global.
Oh dear, I know too little of GameEx. Then @scutter's idea is the best. Show the mouse and make some kind of table-launch script to hide the mouse where needed.
