I don't understand this but for some reason, GameEx is crashing one of my computers. It gives no errors and just freezes (Like the old days of Win98). Just freezes and I need to reset it. I ran some diagnostics of the system itself and found no problems whatsoever. I also tried a reinstall and the problem persists. Anyone else having this problem?
Over Heating? Bad Memory Module?
None of those. The problem is I don't get any info. Normally GameEx gives you an error report but instead, the PC crashes. I tested the computer first since I assumed it was a hardware/OS issue but it all checked out. The computer only crashes when I have GameEx running.
What exactly happens when it crashes? BSOD? Screen freeze? Can you Alt+Tab out? Maybe multiple instances of GE is running causing your comp. to crash.
This is happening to me too.
I only installed GamEx for the first time last night... (I'm running Win98SE on a PIII600 with 512MB Ram and a 32MB TNT card for the purpose of a Mame cabinet). At first I couldnt even load it as it bombed out saying a font wasnt found... so I looked it up and downloaded the core font pack and I can now load Gamex to the main menu.
The problem occurs when I pick anything from that main menu that launches something (eg Mame or some media) and the PC hangs there and then... the screen doesnt change, alt+tab doesnt do anything, and I have to hard-off the PC.
I'm new to this forum and came across this thread as it may be related... if anyone has any ideas please let me know!
Thanks!
Can you post your log files please (all of it).
Start > Programs > GameEx > Log File.
Tom,
I still don't know what was causing it.. I think it may actually have been MediaPlayer. I got frustrated and did a reformat/clean OS install and haven't had the problem since.
I wish I could have pinned down the problem but it looks like it was more a Windows problem than a GameEx problem. I only use that PC for media files so that explains it as far as I can tell.
Here's my log file... I went into GameEx, chose mame, chose all games, then it froze.
17:56:17.3 21/01/2007: GameEx: Version 7.09: Starting Log
17:56:17.7 21/01/2007: Operating System Platform: Win32Windows
17:56:17.7 21/01/2007: Operating System Name: Windows 98
17:56:17.7 21/01/2007: Operating System Version: 4.10.67766446
17:56:17.7 21/01/2007: Checking for versions of .net Framework installed
17:56:17.8 21/01/2007: .net Framework 1.1 Installed
17:56:17.9 21/01/2007: x86 Family 6 Model 8 Stepping 1
17:56:18.1 21/01/2007: Running Randomize()
17:56:18.2 21/01/2007: Loading PlugIns
17:56:18.7 21/01/2007: Checking for applications to Launch On Startup
17:56:18.7 21/01/2007: Initialising Video/MNG DLL's
17:56:18.8 21/01/2007: Running Misc startup tasks
17:56:18.8 21/01/2007: Setting Menu types
17:56:18.8 21/01/2007: Opening Configuration File
17:56:18.8 21/01/2007: Getting Configuration Values
17:56:18.8 21/01/2007: Using Theme: Default - BubbleBobble
17:56:18.8 21/01/2007: Checking for alternate Image Directory for Theme: Default - BubbleBobble
17:56:18.9 21/01/2007: Launching HideOS.exe
17:56:19.0 21/01/2007: Hiding Taskbar
17:56:19.0 21/01/2007: Is Media Center running?
17:56:19.0 21/01/2007: Checking/Creating LCD Registry values
17:56:19.2 21/01/2007: Check Media Center Exit/Start Mode
17:56:19.2 21/01/2007: Media Center Mode 2
17:56:19.3 21/01/2007: Text/Language: English
17:56:19.3 21/01/2007: Applying Language/Text
17:56:19.6 21/01/2007: Snap Delay set to: 2
17:56:19.6 21/01/2007: Get other settings
17:56:19.9 21/01/2007: Set: Find emulator artwork on best match basis
17:56:20.0 21/01/2007: Start work for Form
17:56:20.1 21/01/2007: Getting Original Screen Size
17:56:20.6 21/01/2007: Loading ICON
17:56:21.9 21/01/2007: Initializing Component
17:56:23.3 21/01/2007: Initialising Bass Audio Library
17:56:24.2 21/01/2007: Loading default loading screen
17:56:24.4 21/01/2007: Loading Custom Emulators
17:56:24.4 21/01/2007: Loading Emulator 2: Sega MegaDrive(GENS+)
17:56:24.6 21/01/2007: Loading Emulator 4: Pinball (Visual Pinball)
17:56:24.9 21/01/2007: Loading Emulator 5: Pinball (Future Pinball)
17:56:25.6 21/01/2007: Using 2D Animations
17:56:25.6 21/01/2007: Using General Font: HandelGothic BT
17:56:25.6 21/01/2007: Using Title Font: HandelGothic BT
17:56:25.6 21/01/2007: Initialising DirectDraw
17:56:25.9 21/01/2007: Creating DirectDraw Device
17:56:26.4 21/01/2007: Setting Resolution to 800x600 32 bit color
17:56:27.6 21/01/2007: Creating DirectDraw Surfaces
17:56:27.6 21/01/2007: Creating Primary Surface - Full Screen Mode
17:56:27.6 21/01/2007: Creating Back Buffer
17:56:27.9 21/01/2007: Loading graphic surfaces
17:56:28.1 21/01/2007: Creating Surfaces Misc and Dialogs
17:56:28.5 21/01/2007: Creating Surface Volume
17:56:28.5 21/01/2007: Creating Surfaces Arrows
17:56:28.5 21/01/2007: Creating Surfaces GameEXlogo Text
17:56:28.5 21/01/2007: Creating Surfaces Toolbar
17:56:28.6 21/01/2007: Creating Surfaces Backgrounds
17:56:32.3 21/01/2007: Creating Surfaces Toolbar Controls
17:56:32.3 21/01/2007: Creating Surfaces GameEx Logo
17:56:32.3 21/01/2007: Creating Surfaces Home & Exit
17:56:32.4 21/01/2007: Creating Surfaces Snaps
17:56:32.4 21/01/2007: Creating Surfaces Menu and List Bars
17:56:32.6 21/01/2007: Creating Fonts
17:56:32.6 21/01/2007: Creating Menu Font
17:56:36.4 21/01/2007: Creating Game Font
17:56:37.7 21/01/2007: Creating Font Black
17:56:38.2 21/01/2007: Creating Font Black Small
17:56:38.5 21/01/2007: Creating Game Font Faded
17:56:40.8 21/01/2007: Creating Title Font
17:56:40.8 21/01/2007: Restoring Title Font From Cache
17:56:42.9 21/01/2007: Fonts Created Succesfully
17:57:08.3 21/01/2007: Initialising Windows Media Player Component
17:57:09.0 21/01/2007: MAME Path is: C:\Emulation\Mame32
17:57:09.0 21/01/2007: MAME EXE file is: Mame32.exe
17:57:09.0 21/01/2007: ROM Path is: C:\Emulation\Mame32\roms
17:57:09.0 21/01/2007: Catver.ini is located at: C:\PROGRAM FILES\GAMEEX\DATA\catver.ini
17:57:09.0 21/01/2007: controls.ini is located at: C:\PROGRAM FILES\GAMEEX\data\controls.ini
17:57:09.0 21/01/2007: History.dat is located at: C:\PROGRAM FILES\GAMEEX\DATA\history.dat
17:57:09.0 21/01/2007: nplayers.ini is located at: C:\PROGRAM FILES\GAMEEX\DATA\nplayers.ini
17:57:09.1 21/01/2007: MAMEinfo.dat is located at: C:\PROGRAM FILES\GAMEEX\DATA\mameinfo.dat
17:57:09.1 21/01/2007: Loading Controls.ini map file
17:57:09.2 21/01/2007: Snap Path is: C:\Emulation\Mame32\snap
17:57:09.2 21/01/2007: AVI Snap Path: Not Found
17:57:09.2 21/01/2007: Flyer Path is: C:\Emulation\Mame32\flyers
17:57:09.2 21/01/2007: Cabinet Path is: C:\Emulation\Mame32\cabinets
17:57:09.2 21/01/2007: Title Path is: C:\Emulation\Mame32\titles
17:57:09.2 21/01/2007: Panel Path is: C:\Emulation\Mame32\cpanel
17:57:09.2 21/01/2007: Icon Path is: C:\Emulation\Mame32\icons
17:57:09.2 21/01/2007: Marquee Path is: C:\Emulation\Mame32\marquees
17:57:09.2 21/01/2007: MAME CMD options: -triplebuffer -nowindow -joy
17:57:09.2 21/01/2007: Attempting to load game list
17:57:09.5 21/01/2007: Loading last used Game List
17:57:09.5 21/01/2007: Setting Music Volume
17:57:09.6 21/01/2007: Creating DirectSound Device
17:57:09.6 21/01/2007: Trying: Primary Sound Driver
17:57:09.6 21/01/2007: Loading Sound Files
17:57:10.2 21/01/2007: DirectSound Device Created Successfully
17:57:10.2 21/01/2007: Creating ICONS
17:57:10.3 21/01/2007: Recreating ICONS
17:57:11.2 21/01/2007: Initialising DirectInput for Gamepad support
17:57:11.7 21/01/2007: Unable to create a joystick device
17:57:11.8 21/01/2007: Playing intro sound file
17:57:11.9 21/01/2007: Initializing MCE Remote
17:57:11.9 21/01/2007: Initialization OK! Starting GameEx!
17:57:12.0 21/01/2007: Testing Main Loop Once: Processing Frame
17:57:13.1 21/01/2007: Testing Main Loop Once: Main Loop ran successfully
Sorry but I'm gonna add a "me too" to this thread. I have been away for about four months and downloaded the latest version yesterday. I have had no success in two days at getting gamex running. My logfile looks like the one above. i.e. no error is reported but the system is locked solid. The only way out is a reset and the same thing happens all over again. Even on the most basic settings I have had no success.
In addition, I cannot get any video working in Gamex and if I do attempt to set it up in either the advanced setup or the wizard then Gamex starts with a black screen, soundtrack is heard but there is no further response from Gamex. Task manager says Gamex is not responding and ctrl-alt-delete is the only answer.
At a guess this is video card or codec related but I've used the same codec pack with Gamex previously over an extended period of time (Gamex versions from about 3.xx to 6.xx). New Video card in the interim is 8800GTS and I know that it's most likely the cause of my video problem but that doesn't explain the hanging when scrolling through the game list.
If everyone else is having fun and their systems and software are working, I'm very happy for them. I only mention any of this because clearly there are a few other people having similar problems and if they're not as patient as I am they will have already given up. There is a problem here and I wish I could be more helpful in trouble shooting it but if there is no problem reported in the logfile I'm not sure what else I can do to help.
Post your log.
I think your system may be too underpowered for GameEx. It does not meet the minimum requirements. You may be better with MAMEWAH, gamelauncher or a nottso graphic extensive front end.
Other than upgrade your system and OS things to try are as follows.
1. Get the latest version.
2. Turn on 16-Bit Colour.
3. Turn off advanced graphics.
4. Run at a lower resolution.
  • 1 month later...
I'm having this same problem as described above since 2 updates ago. Here's my log file.
22:28:15.7 3/16/2007: GameEx: Version 7.77: Starting Log
22:28:15.7 3/16/2007: Operating System Platform: Win32NT
22:28:15.7 3/16/2007: Operating System Name: Windows XP
22:28:15.7 3/16/2007: Operating System Version: 5.1.2600
22:28:15.7 3/16/2007: Checking for versions of .net Framework installed
22:28:15.7 3/16/2007: .net Framework 1.1 Installed
22:28:15.7 3/16/2007: .net Framework 2.0 Installed
22:28:15.7 3/16/2007: AMD Athlon XP 2400+
22:28:15.7 3/16/2007: 2Ghz
22:28:15.7 3/16/2007: Running Randomize()
22:28:15.7 3/16/2007: Loading PlugIns
22:28:15.7 3/16/2007: Checking for applications to Launch On Startup
22:28:15.8 3/16/2007: Initialising Video/MNG DLL's
22:28:15.8 3/16/2007: Running Misc startup tasks
22:28:15.8 3/16/2007: Setting Menu types
22:28:15.8 3/16/2007: Opening Configuration File
22:28:15.8 3/16/2007: Getting Configuration Values
22:28:15.8 3/16/2007: Using Theme: Default - Galaxian
22:28:15.8 3/16/2007: Checking for alternate Image Directory for Theme: Default - Galaxian
22:28:15.8 3/16/2007: Launching HideOS.exe
22:28:15.8 3/16/2007: Hiding Taskbar
22:28:15.8 3/16/2007: Is Media Center running?
22:28:15.8 3/16/2007: Checking/Creating LCD Registry values
22:28:15.8 3/16/2007: Check Media Center Exit/Start Mode
22:28:15.8 3/16/2007: Media Center Mode 2
22:28:15.8 3/16/2007: Snap Delay set to: 2
22:28:15.8 3/16/2007: Get other settings
22:28:15.9 3/16/2007: Desktop set to Hide ICONS and set Background to Black
22:28:15.9 3/16/2007: Backing up Registry Wallpaper Settings
22:28:15.9 3/16/2007: Set: Find emulator artwork on best match basis
22:28:15.9 3/16/2007: Start work for Form
22:28:15.9 3/16/2007: Getting Original Screen Size
22:28:15.9 3/16/2007: Initializing Component
22:28:16.3 3/16/2007: Creating Radio Station Genres
22:28:16.4 3/16/2007: Succesfully created station genres
22:28:16.4 3/16/2007: MAME Path is: D:\MAME\MAME32 v0.111 COMPLETE!\MAME32
22:28:16.4 3/16/2007: MAME EXE file is: Mame32.exe
22:28:16.4 3/16/2007: ROM Path is: D:\MAME\MAME32 v0.111 COMPLETE!\MAME32\roms
22:28:16.4 3/16/2007: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
22:28:16.4 3/16/2007: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
22:28:16.4 3/16/2007: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
22:28:16.4 3/16/2007: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
22:28:16.4 3/16/2007: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
22:28:16.5 3/16/2007: Loading Controls.ini map file
22:28:16.5 3/16/2007: Snap Path is: D:\MAME\MAME32 v0.111 COMPLETE!\MAME32\snap
22:28:16.5 3/16/2007: AVI Snap Path is: D:\Finished Torrents\[Crashtest Video Collection]
22:28:16.5 3/16/2007: Flyer Path is: D:\MAME\MAME32 v0.111 COMPLETE!\MAME32\flyers
22:28:16.5 3/16/2007: Cabinet Path is: D:\MAME\MAME32 v0.111 COMPLETE!\MAME32\cabinets
22:28:16.5 3/16/2007: Title Path is: D:\MAME\MAME32 v0.111 COMPLETE!\MAME32\titles
22:28:16.5 3/16/2007: Panel Path is: D:\MAME\MAME32 v0.111 COMPLETE!\MAME32\cpanel
22:28:16.5 3/16/2007: Manual Path: Not Found
22:28:16.5 3/16/2007: Icon Path is: D:\MAME\MAME32 v0.111 COMPLETE!\MAME32\icons
22:28:16.5 3/16/2007: Marquee Path is: D:\MAME\MAME32 v0.111 COMPLETE!\MAME32\marquees
22:28:16.5 3/16/2007: Loading Custom Emulators
22:28:16.7 3/16/2007: Using 2D Animations
22:28:16.7 3/16/2007: Using General Font: HandelGothic BT
22:28:16.7 3/16/2007: Using Title Font: HandelGothic BT
22:28:16.7 3/16/2007: Initialising DirectDraw
22:28:16.8 3/16/2007: Applying GameEx is Loading Image
22:28:16.8 3/16/2007: Creating DirectDraw Device
22:28:16.8 3/16/2007: Using Device: RADEON X850 Series
22:28:17.0 3/16/2007: Setting Resolution to 1280x1024 32 bit color
22:28:17.0 3/16/2007: Creating DirectDraw Surfaces
22:28:17.0 3/16/2007: Creating Primary Surface - Full Screen Mode
22:28:17.2 3/16/2007: Creating Back Buffer
22:28:17.2 3/16/2007: Loading graphic Surfaces
22:28:17.3 3/16/2007: Creating Surfaces Misc and Dialogs
22:28:17.3 3/16/2007: Creating Surfaces Volume
22:28:17.3 3/16/2007: Creating Surfaces Arrows
22:28:17.4 3/16/2007: Creating Surfaces GameEXlogo Text
22:28:17.4 3/16/2007: Creating Surfaces Toolbar
22:28:17.4 3/16/2007: Creating Surfaces Backgrounds
22:28:23.3 3/16/2007: Creating Surfaces Toolbar Controls
22:28:23.3 3/16/2007: Creating Surfaces GameEx Logo
22:28:23.4 3/16/2007: Creating Surfaces Home & Exit
22:28:23.4 3/16/2007: Creating Surfaces Snaps
22:28:23.4 3/16/2007: Creating Surfaces Menu and List Bars
22:28:23.5 3/16/2007: Creating Fonts
22:28:23.5 3/16/2007: Creating Menu Font
22:28:25.3 3/16/2007: Creating Game Font
22:28:26.0 3/16/2007: Creating Font Black
22:28:26.2 3/16/2007: Creating Font Black Small
22:28:26.3 3/16/2007: Creating Game Font Faded
22:28:27.5 3/16/2007: Creating Title Font
22:28:34.5 3/16/2007: Fonts Created Succesfully
22:28:34.5 3/16/2007: Starting GameExtender Publisher
22:28:34.5 3/16/2007: Text/Language: English
22:28:34.5 3/16/2007: Applying Language/Text
22:28:34.6 3/16/2007: Initialising Bass Audio Library
22:28:35.2 3/16/2007: MAME CMD options: -triplebuffer -nowindow -joy
22:28:35.2 3/16/2007: Attempting to load game list
22:28:35.4 3/16/2007: Running: Mame32.exe -help
22:28:35.4 3/16/2007: Running: D: D:\MAME\MAME32 v0.111 COMPLETE!\MAME32\Mame32.exe -help > D:\MAME\MAME32 v0.111 COMPLETE!\MAME32\help.txt
22:28:36.0 3/16/2007:
22:28:36.0 3/16/2007: Detected MAME Version as: 0.113
22:28:36.0 3/16/2007: Now Outputing Mame32.exe - Help
22:28:36.0 3/16/2007: --BEGIN--
22:28:36.0 3/16/2007: M.A.M.E. v0.113 (Mar 6 2007) - Multiple Arcade Machine Emulator
22:28:36.0 3/16/2007: Copyright © 1997-2007 by Nicola Salmoria and the MAME Team
22:28:36.0 3/16/2007: MAME is an emulator: it reproduces, more or less faithfully, the behaviour of
22:28:36.0 3/16/2007: several arcade machines. But hardware is useless without software, so an image
22:28:36.0 3/16/2007: of the ROMs which run on that hardware is required. Such ROMs, like any other
22:28:36.0 3/16/2007: commercial software, are copyrighted material and it is therefore illegal to
22:28:36.0 3/16/2007: use them if you don't own the original arcade machine. Needless to say, ROMs
22:28:36.0 3/16/2007: are not distributed together with MAME. Distribution of MAME together with ROM
22:28:36.0 3/16/2007: images is a violation of copyright law and should be promptly reported to the
22:28:36.0 3/16/2007: authors so that appropriate legal action can be taken.
22:28:36.0 3/16/2007: Usage: MAME gamename [options]
22:28:36.0 3/16/2007: MAME -showusage for a brief list of options
22:28:36.0 3/16/2007: MAME -showconfig for a list of configuration options
22:28:36.0 3/16/2007: MAME -createconfig to create a mame.ini
22:28:36.0 3/16/2007: For usage instructions, please consult the file windows.txt
22:28:36.0 3/16/2007: --END--
22:28:36.0 3/16/2007: Loading last used Game List
22:28:36.0 3/16/2007: Setting Music Volume
22:28:36.0 3/16/2007: Cannot Load Play List. Check Path and filename
22:28:36.0 3/16/2007: Creating DirectSound Device
22:28:36.0 3/16/2007: Trying: Primary Sound Driver
22:28:36.0 3/16/2007: Loading Sound Files
22:28:36.1 3/16/2007: DirectSound Device Created Successfully
22:28:36.1 3/16/2007: Creating ICONS
22:28:36.1 3/16/2007: Recreating ICONS
22:28:36.7 3/16/2007: Initialising DirectInput for Gamepad support
22:28:36.7 3/16/2007: Using Device Saitek P3000 Wireless Pad
22:28:36.8 3/16/2007: Playing intro sound file
22:28:36.8 3/16/2007: Initializing MCE Remote
22:28:36.8 3/16/2007: Initialization OK! Starting GameEx!
22:28:36.8 3/16/2007: Testing Main Loop Once: Processing Frame
22:28:37.5 3/16/2007: Testing Main Loop Once: Main Loop ran successfully
Thanks, I don't know what to do. It seems to load fine, and will stay fine until I move the pointer to ANY menu item. Then the pc freezes and I must hit the reset button.
J, can you please try a different theme just to rule that out.
Thanks.
I already had done that, trying the default with the same results. I'm now going to try not using start page zoom animation, since it doesn't lock up until I point at a menu bar item.
Is it ok just using the keyboard?
Also, are you talking about a menu item, ie on the left of the screen, or an item in the gamelist?
nope, when I used the keyboard to move down from the MAME bar, it locked up again. As a note my pc speakers make a loud high pitched sound that loops when this locks up.This is a fresh install of GameEx(since I thought maybe my original was corrupt.)
Can you post your gameex.ini so I can try and duplicate the issue. I assume your talking about the menu bar on the left and when in MAME, yes?
Can you try a completely fresh install, in other words in a different install location other than C:\program files\gameex. Once we figure it out we can put it back.
Also, did you change anything else on your sysyem, new hardware new drivers or anything (new graphics drivers??). The way its crashing sounds like it might be something to do with that.
Also please try the attached GameEx.exe (replace the existing). Im pretty sure it will work, as I think I figured it where its failing for you with something introduced last few versions. However this would indicate a graphics card hardware/driver issue.
Cheers.
GameEx.zip
Cheers.
Thanks so much for such quick responses. I made no driver updates or hardware changes. I did do some windows updates.(critical ones only) I will try what you've suggested here and let you knowthe results. :)
You were right Tom. It's working great now.
Now, I noticed a video driver upgrade for my card (ATI X850) that was put out on Feb 21, 2007. Since I now have a working and non-working versions of GameEx installed I'm thinking I should try the driver update and see if that fixes the non-working version of GameEx.
