Buenas...mi problema radica en que no puedo quitar los juegos (visual pinball,pfx2 y 3 solo tengo esos sistemas) con el boton difinido ni con algun otro a configurar...Q deja de funcionar y solo queda activo ESC que se limita a dar pasos atras en pfx2 y 3 hasta llegar al boton de quitar el juego...en visual pinball ESC abre el editor y queda ahi ya que desaparece el cursor como para cerrar totalmente el programa...los primeros dias me funcionaba bien Q y mataba el proceso correctamente y regresaba al menu de tablas de Pinball X...ojala sea un error simple y se pueda resolver...desde ya muchas gracias.
When reporting an issue, please remember to translate to English and to attach copies of your pinballx.ini and log.txt files for review. Thanks!
We will try to work on the issues of only one PC, please.
Can you explain further what "error of not removing games" means?
First question: What will happen if you run the following command from the command line ?
  Quote
 "C:\VPINBALL10\VPinball 10.8\VPinballX.exe" /play -"C:\VPINBALL10\VPinball 10.8\tables\FirepowerV1.0.5.vpx"
Does it launch, or does it give an error?
Second, can you maybe post a video as well? As @Draco1962 mentioned, I don't understand what you mean by "error of not removing games."
Your computer is operating on Windows 10 with a limited 4GB of memory, and you are attempting to launch VP 10.8 as well ? I suggest considering the PinballX Lite version as an alternative if your computer is outdated and lacks sufficient processing and memory power.
Of course...I press "Q" to remove the game (table) and return to the menu to select another table and it doesn't...when I'm in visual pinball I press "Q" and it opens the editor and it stays there (as in the attached image) and in pinball FX 2 and 3 I press "Q" and it does nothing...there is no way to remove the game and select another one.
Ok
Good advice...as the games work perfectly independently "visual pinball 10, pfx2 and pfx3" I thought there would be no problems using pinball x as a launcher...I will try the lite version.
You have set the "esc" key to quit the program. Please try  to set exit emulator to same key.
Your log shows it exists the emulator
Yes...I tried but it didn't solve the problem...I can't find a way to kill the process...it doesn't matter...I appreciate the help...Thank you.
  On 9/16/2024 at 10:06 PM, kristian25 said:
it doesn't matter
Why not ? PinbalLX is able to kill the emulators.
So if it aint working for you, something is wrong.
Are you running VP or any other game/emulator as administrator  ?
  • 4 weeks later...
Hello...apologies for not responding previously...I installed a new version of pinball x and the problem of not being able to remove the games was solved...
now the problem I have is that visual pinball does not show the "backglass" images on the second screen...future pinball and pfx 2 and 3 yes...the playfield images do appear as well as the logos...the backglass images do not...what could be the problem?
Edited by kristian25
Please attach fresh copies of the pinballx.ini and log.txt files for the new issue.
Also, confirm what media do you have in the PinballX\Media\Visual Pinball\Backglass Images and PinballX\Media\Visual Pinball\Backglass Videos folders?
  • Draco1962 changed the title to [RESOLVED] Pinball X no quita el juego.
  • Draco1962 locked this topic
