Hello, can we resize or move the display on the playfield of the tables displayed with the wheel
 because they are poorly centered or do not take up the entire screen?
In fact the yellow frame is missing on the left side of the screen?
 THANKS
PinballX.ini log.txt
Sorry, must be the translated text, but I realy don't have a clue what you mean ?
Could you maybe post a screenshot with some things that you think that are not correct circled so we can see what you're talking about?
Also, have you checked the documentation for colors and other stuff? There are some great screenshots in there that might help.
Here is a photo of the screen. I have a yellow edge on the right side and not on the left side, you can see the office.
I notice a yellow bar on the right, but there's a blue one on the left.
Are you running in windowed mode, and is the PBX not configured to full screen? Or could it be your underlay that's causing this?
Just out of curiosity, what resolution are you using? I have more wheel previews than you do.
Per the pinballx.ini (and his last thread where there wss no playfield displaying occasionally):
FullScreenWindowedNew=True
56 minutes ago, Mike_da_Spike said:
Nice catch @Draco1962. So you think it could be his underlay?
Possible. Or is it something else in the playfield settings causing conflict?
[Display]
Monitor=0
rotate=90
Windowed=False
windowwidth=812
windowheight=457
windowx=507
windowy=454
PlayFieldBrightness=250
WheelTextColor=ffffffff
InfoTextColor=ffffffff
InfoTextOutlineColor=ff000000
FilterTextColor=ffffffff
MenuColor=ffffa500
ShowDateAndTime=False
ShowExitImage=True
WheelType=1
StretchUnderlay=False
  • Confused 1
[Display]
Monitor=0
rotate=90
Windowed=False
windowwidth=812
windowheight=457
windowx=507
windowy=454
MenuColor=ffffa500
ShowExitImage=True
WheelType=1
If I check this video, it looks the same  as on the screenshot
so, what's the exact issue now?
He probably didn't notice it right away after the other issue was resolved. But back to the ini:
Windowed=False
windowwidth=812
windowheight=457
windowx=507
windowy=454
is ti possible the problem lies within these?
I use full screen mode for the main screen and windowed full screen mode is yes.
I am in 1920x1080 resolution for the playfield and 1280x720 for the backglass.
Maybe try going windowed with
Windowed=True
windowwidth=1920
windowheight=1080
windowx=0
windowy=0
Not sure if it will address the issue so make sure you have a backup of the pinballx.ini to overwrite it if necessary.
20 hours ago, duv67 said:
Hello, can we resize or move the display on the playfield of the tables displayed with the wheel because they are poorly centered or do not take up the entire screen?
I still don't get what you mean by this
Doesn't it look like this ?
I see a blue 'frame' on your screenshot and video you made.
and also on the video you posted earlier :
Maybe it is from the source video or from the underlay ???
can you check both ?
From the video (https://forums.gameex.com/forums/topic/30107-resolved-no-playfield/) the blue and yellow bars on each side are present on all table playfields in PinballX but not on the loading screen (using a still image of the playfield video). So i think it must be from an overlay or underlay being used in PinballX.
@duv67 Check what underlays and overlays you have in \PinballX\Media\System Underlays and \PinballX\Media\System Overlays. Open them in paint and hopefully one of them has a blue and a yellow bar on the sides and is the cause.
HELLO,
Indeed, I have a yellow and blue box planned for the vpx tables in the \PinballX\Media\System Overlays folder.
 In fact I never noticed! I was looking for a bug where there wasn't one! Sorry for wasting your time.
 Have a good end of the day.
  • Haha 1
  • Draco1962 changed the title to [RESOLVED] display playfield showing blue and yellow borders
