Hello,
I encounter a problem when I launch a table using PINBALLX. I have the BACKGLASS but not the PLAYFIELD.
On the other hand, when PINBALLX is launched I have the wheel on the playfield and when I launch a table
directly through VPINBALLX I also have the playfield.
I don't understand.
Thanks for your help.
PinballX.ini log.txt
I think the problem comes from the positioning of my screens which are 2-1.
I encounter the problem generated by windows like many of us!!
But I didn't encounter this problem in my old installation. If I reverse my screens in the pinballx settings
I have my backglass and I have my playfield but very small!
So you changed something (new installation) and you repositioned your screens and now you have issues?
How about setting your old settings back ?
 i had to change my PC.
 I reinstalled everything with the same settings which worked very well.
 What I can't explain is why I have the wheel on the playfield and the looding message
and then nothing on the playfield even though the table launches well!
Also attach new pinballx.ini and log.txt files, please.
1 minute ago, scutters said:
Can you post a picture or video of the problem?
Not sure i understand the issue from the description alone. Is it playfield videos are missing, or is it just a focus problem after launching VPX?
Make sure you installed lav codecs on the new pc anyway - https://forums.gameex.com/forums/files/file/2451-lav-video-codecs/
LAV Codecs are a must!
And the new pinballx.ini and log.txt files from right after the display error please. Thanks.
As vpx stand alone doesnt have to do with a front end. So fullscreen exclusive mode won't be a differrence if you just click it from Windows
  • Draco1962 changed the title to [RESOLVED] NO PLAYFIELD
