[RESOLVED] DMD is allways displayed in the 3th. Monitor only if i start Tables with PinballX, in outside all works fine?
My DMD is allwas displayed in the 3th Monitor in my Pinball Cab
even with a Backglas like Black Hole that has a Counter in the Backglas.
The OPTIONS in the Backlass: Hide DMD is aktivated
I also uncheck in the Rom with F1: use external DMD and also show DMD/Display window
Both Options are not aktivated but anyway the DMD is Displayed in the DMD Monitor.
If I start the Tables directly from VPX then everything works correctly but if i start the Tables via PinballX the DMD is permanently displayed in the third monitor.
Question: Where saved PinballX this settings? What can I delete in PinballX so that this doesn't happen anymore?
WHEN reporting an issue that you require assistance, please attach copies of your pinballx.ini and log.txt files! This is essential as a foundation for the assistance you are requesting!
Did you read the manual that is send with PinballX .? A lot of stuff is covered in there
Is there a Dokumentation in German?
In English for me is not easy.
log.txt PinballX.ini
2 hours ago, NEWER said:
Are this the right Files?
Yes! 👍
Under settings.exe go to Display Settings,
Try changing the 'auto position dmd' setting to No,
And also change the 'auto position DirectB2S' to No
oh no now it works .
Many thanks for this Info.
I work 4 to 5 Days every evening till late in the night to fix that Problem but iam fail.
Now iam very happy that one problem is gone.
jaba daba du
  • Draco1962 changed the title to [RESOLVED] DMD is allways displayed in the 3th. Monitor only if i start Tables with PinballX, in outside all works fine?
59 minutes ago, Draco1962 said:
Thanks for reporting back. Glad it is sorted!
Yes iam so Happy now that Problem makers me Crazy for many Days.
Many thanks to help me so fast....
MANY GREETINGS TO ALL THE PINBALL FANS WORLDWIDE FROM STUTTGART MY HOMEBASE
No sorry. Englisg is the only available languagefor the documentation
But  pinballX and database manager can both be set to german.
How to translate a PDF in Google Translate.
If you have a PDF file such as an eBook or a document from a foreign client that you would like to translate to your native language, the best way to do that is using a human translator. However, if you need to use something online, you can follow these instructions to translate a PDF file in Google Translate.
Access the Translate Document tool.
Choose the language you would like to translate from and to. If you’re not sure what language your PDF file is in, you can set the input language to “Detect language.”
Click Choose File and then the blue Translate button.
Google will then translate the text.
You will get a pop-up with the PDF file translated.
  • Like 3
7 hours ago, Mike_da_Spike said:
I took @Draco1962advice and translated the document via an online translator for you. Not sure if it make any sense, but looks German to me
It may not be exact but probably close enough. The pictures will still be in English but I think with the verbal descriptions it should suffice.
