Can't reinstall https://www.pinballx.com/vbbxsetup.exe not found 404
Hi,
I am trying to reinstall PinballX but getting the below error during the reinstall.
Is the file still present on your webserver ?
Could you please check your webserver ?
404 - File or directory not found.
The resource you are looking for might have been removed, had its name changed, or is temporarily unavailable.
  On 2/6/2024 at 1:36 PM, scutters said:
Wow i must really skim through the installer then..  never even seen the option!
Normally I would not select it, but didn't have pbx yet on my lapto, and thecdefaultvis that VP will be installed. Think its only 1 time, not during upgrade
Edit : With screenshots :
I just wanted to make an email to tom about it
  • Thanks 1
  On 2/6/2024 at 9:27 AM, stinkefisch said:
Hi,
Don't unintstall PinballX en install a new version. This could overwrite some of the XML database files (I know FX3 will do it)
Just use the upgrade.
For you, just uncheck this box and hit 'next' to continue. Dont forget that you need to install Visual Pinball yourself
