I have had the mouse curser change from the windows default arrow to one single pixel when you don't exit  pinballx correctly.   Only way to get it back was to go into control panel and set mouse pointer options back to whatever you want.  A bit difficult to do when your mouse pointer is only one pixel, as Tom said if you disable hide mouse in pinballx this won't be an issue.
If pinballx is crashing (alt-f4 is govong mouse back), and your mouse is 1 dot and taskbar is away, just laun pinballx again and close it.
Mouse pointer is back and taskbar is back
