Tenho o visual pinball X instalado. Todas as mesas funcionam perfeitamente.
Quando eu abro pelo PinballX, a roleta volta e a mesa fica aberta por trás. Preciso alternar no alt/tab para poder jogar.
Já formatei meu Pc por diversas vezes.
Mas quando faço toda instalação volta com o mesmo problema.
Alguém sabe esse problema?
Please submit your requests for assistance in English.
Also we will need you to provide copies (no copy & paste) of your latest pinballx.ini and log.txt files.
Thank you!
____________________
Por favor, envie seus pedidos de assistência em inglês.
Além disso, precisaremos que você forneça cópias (sem copiar e colar) dos seus arquivos pinballx.ini e log.txt mais recentes.
Obrigado!
Try updating PinballX to the latest version, and if not set make sure Visual Pinball is set to run in Exclusive Fullscreen (under Visual pinball video preferences)
Open Vosual pinball, go to  ideo settings and enable "full screen exclusive " mode.
Withing pinbalx (via settings .exe) enable full screen exclusive hack as well.
Latest Pinballx version is 6.02. Ease updat
If you still got issues, ease attach your new log file and settings file
First suggestion is to stop uninstalling and reinstalling. Stay at the most recent version.
Second. Be patient. Some issues take more time. If you have @Mike_da_Spike and @scuttersinterest, you are in good hands.
  • Thanks 1
Okay, I'm very grateful.
I've had this problem for 45 days now.
Everything worked perfectly.
My playfield has the resolution 1366x758 and the backglass 1920x1080.
I believe this is not the problem because, as I said, it works normally with these settings.
You started to post it on monday.
Their must be something changed
Did you follow the steps I mentioned in https://forums.gameex.com/forums/topic/29056-perdendo-foco-visual-pinball/?do=findComment&comment=213303, because I dont see the fullscreen exclusive hack being activated.
i have made a small tool to get focus on vpinball, but that was written for VP VR. It brings back focus to vp.
But by default all should work without my 'helper' program
  On 10/5/2023 at 2:56 AM, conceito service said:
Yes, I did exactly as you mentioned in the previous post. Everything in full screen.
Try changing your Visual Pinball launch parameters in PinballX to;
Parameters=-EnableTrueFullscreen -Minimized /Play -"[TABLEPATH]\[TABLEFILE]"
(If editing in Settings exe rather than directly in the ini file remove the 'Paramters=' bit)
  On 10/5/2023 at 10:03 AM, conceito service said:
Congratulations! It worked, the table is loading. However, when I press the exit button, it doesn't go back to the roulette wheel, PinballX closes and I have to open it again.
Please attach new copies of your PinballX.ini and log.txt files (make sure the log.txt file is after exiting a table and PinballX closing)
I don't understand why PinballX would now crash on table exit with what appears to be a DirectX issue. Follow the advice in Mikes link above to try and fix it.
Out of interest, if you remove the '-EnableTrueFullscreen' from the Visual Pinball launch parameters does the error still occur? (but you then return to having a focus issue)
