[RESOLVED] DMD not shown when topper is active
I recently added a topper screen. After doing that, the DMD screen in PinballX started showing up on the wrong monitor (invisible,under the playfield). I can move the DMD to the backglass monitor, but NOT to the DMD monitor or the topper monitor. Seems like there's a bug somewhere, preventing the DMD to be shown on display numbers > 3. Log files attached but you won't find anything special in them I'm afraid.
log.txt PinballX.ini
Can you please add a screen capture of your Windows Display settings, like this? Below is mine and yours will appear different. Thanks.
It's not because it works for someone else, that there might not a bug. It's not working in my case. And the DMD worked fine before.
I'll update the status for my other pending issues.
I wouldn't put this down a bug in PinballX, it just windows being windows and making a mess of screen numbers. I use 6 screens and nvidia and windows disagree about the screen numbers so what chance does pbx have?.
You have a few options;
  1. Manually edit the pinballx.ini file to try screen ids > 5
  2. Set the screen id the same as the backglass for the DMD and use the DMD x, y offset values as a relative position from the top left of the backglass
  3. Try and clean the windows registry entries for attached screens as described here - https://www.vpforums.org/index.php?showtopic=49405&p=501605
Personally, option 3 would be last resort and only after backing up those registry entries.
I am willing to bet that much of this is stemming from fighting against having the playfield as screen 1. I am curious as to why @Wimpie is having an issue with  the playfield set to screen 1 to begin with? Is it because of the cabling set for each monitor is different and Windows is forcing the issue? T
This is something I had to address when adding a topper to my min-Pin caused some similar issues - this post sheds some light on the topic:
Video port priority order
It doesnt matter on why hardware screen the display is, but it should be the first screen on the left.
My order is 2-1-3 as well, (2 = playfield, 1= backglass, 3 = dummy hdmi for toppr/vdmd etc)
If really want to have playfield on nr 1, try using dc2.e e from 12noon (https://12noon.com/?page_id=641).
With this you can create an xml from your configuration, and modify the with notepad.
During launch of windows, import these settings and you always good.
I used this on my previous cab to have consistent monitor setup as windows could swap something, but my new pc doesnt have any issue with it
I will try to swap the order, but guys... I still think it's weird that this can't be handled correctly by PinballX. I have no issues at all with Visual Pinball X: backglass and playfield are shown on the correct monitors without swapping anything.
We can have a long argue about it, but we are just people that will try to help
As the creator/founder/master/god himself said :
This one can be marked as resolved (well, with a workaround). I've placed my DMD on screen 1 with an offset of X=3870. That puts the DMD on screen 3.
  • Draco1962 changed the title to [RESOLVED] DMD not shown when topper is active
