I configured Pinballx so that it exits the future pinball emulator with the "K" key, but when I use Future Pinball with BAM, it does not exit the emulator with the "K" key, only with "ESC". Has anyone gone through something similar? Thanks
Your parameters for FP launch are;
STAYINRAM /open "[TABLEPATH]\[TABLEFILE]" /play /exit /arcaderender
Can you try with this (note the / before STAYINRAM);
/STAYINRAM /open "[TABLEPATH]\[TABLEFILE]" /play /exit /arcaderender
It didn't work either, I'm almost giving up on FP...
You may want to provide your log.txt file as originally requested which may provide those helping you with additional clues.
According to your settings file, your exit is keycode 27. That is 'esc' key and not 'K'
Sorry, there is indeed a exit emulator as well. I map exit and exit emulator to the same joykey.
Not sure if it's a typo or not but in your ini file you have the exit emulator key mapped to 'h' not 'k'. Please confirm that, and as requested attach your pinballx\log\log.txt file (after trying to exit a FP game with the exit key)
Really friend, now that I noticed that the "H" key is there, it was because I did several key tests, but also with the "H" it doesn't work. Below is my .ini and the log, now with the "K" key. Thank you all.
log.txtFetching info... PinballX.iniFetching info...
Hi,
The log file still shows the STAYINRAM option is being used without the '/' before it;
07:34:13.05  18/10/2022:  C:\Games\Future Pinball\BAM\FPLoader.exe STAYINRAM /open "C:\Games\Future Pinball\Tables\Cavaleiro Negro 2.0.fpt" /play /exit /arcaderender
Can you adjust the launch parameters to /STAYINRAM and post a new log.txt file after. Thanks.
