ask you about a problem i have.Sometimes for some reason the dmd goes behind backglass.I edit dmddevice.ini set it to true but the problem remains.When i restart my pc everything works fine.Any ideas?
What version B2SBackglassServer are you using?
See [Solved] Issues with DMD hidden Behind Backglass since B2S update - B2S Development Support - Virtual Pinball Universe (vpuniverse.com)
B2S releases - Releases · vpinball/b2s-backglass · GitHub
The issue will be best raised on VPUniverse or VPforums as it's probably not directly PinballX related and you will get more help on those sites. If you're lucky @jrl who has been doing B2S application updates may see the issue here (.. but he might not)
@pdiavolikisI have moved your topic (again) to the correct forum.
Please pay attention to where you are posting your threads for assistance to ensure a prompt response and avoid deletion.
Refer to this thread if there is any confusion:
  • Haha 1
Yes, these things are meant to be solved with the last release from yesterday.
  • Thanks 2
Here is the changelog of the last pre-release, but the version might become 1.4 in the end...
1.3.1.2
- Add additional setting FormToBack complementing FormToFront. Now three states available:
  1. "Standard" setting (both FormToBack and FormToFront turned off) is now as it was in 1.3.0.6. -> formDMD isn't controlled by the FormToFront/Back setting
  2. FormToFront sets the flag Form.TopMost = True -> cannot get any other window on top
  3. FormToBack, forces the forms back and ignores any try to get them come forward -> Windows stay in back. The B2S Server is not available in the taskbar anymore.
- Merge some more settings in the dll version.
- Make sure LED "D" (Digit) updates from VPMame is forwarded to all plugins. thanks to rdowens11vx!
But for the release I need some more testers, who can test the new as well as the old states, and give feedback
  • 4 weeks later...
New pre-release up https://github.com/vpinball/b2s-backglass/releases/tag/b2s-backglass-215c1b7
It will become 1.4.0:
1.4.0
   3. FormToBack, forces the forms to the back and ignores any try to get them come forward -> Windows stay in back. The B2S Server is not available in the taskbar anymore.
- Merge some more settings from the dll version.
- Make sure LED "D" (Digit) updates from VPinMame is forwarded to all plugins. thanks to rdowens11vx!
- Make the B2SBackglassServerEXE Large Address Aware by changing the build flags for x86 builds (x86 to AnyCPU). No need to patch 4GB anymore!
@Mike_da_Spikefor testing the other pre-release. Do you mind test this one as well?  Pole Position not working, should be history now 😀
I cannot promise anything. I'm running a bit behind with al the JPSalas updates, and @scuttershad a good idea for DBM as wel, which cost us a lot of time.
i will put it on the cab and check if all working.
What does this means ? Can a plugin be created that can read the LED digits ? I'm intrested how that will work. Will other lamps also be forwarded, so that the plugin can interpret this as well ?
Yeah, sorry Mike... that is my fault :P
Must be for the fix for the B2S generic flexdmd plugin - https://www.vpforums.org/index.php?showtopic=49874.
I'm watching with interest to see how that progresses!!
Not sure if other standard lamps can just be forwarded or not too, but i guess they can (pinup triggers?)
  • Thanks 1
On 10/26/2022 at 4:44 AM, Mike_da_Spike said:
Nais. Intrested in that too, as a lot of vpinmame alphanumeric wont display correct on a real dmd.
Yes, he sent a pull request which was Incorporated, so that is now part of the builds as well
/Jarr3
I've added the new version. And working like a charm.
no issues found thus far.
The form to back is working for me, and even shows correctly launching from PinballX
Good job ! (well for  Pole Position you introduced the bug :D, so good it is working again :P  )
  • Draco1962 changed the title to [RESOLVED] dmd problem
