Wheel images work though.
So I sold my cab, and trying to set up pinballx on his computer using TeamViewer. But I just cant get it to work. Audio and, video and images all download, they just wont show up when lunching Pinballx. I had it here, working, showing him before purchase . And now my pinballx has the same issue.
Windows 10, Visual pinball.
Did you follow the manual to setup pinballx ?
Was it now working before you sold the cabinet?
Limit information to make something out of it
it worked befor i sold it, i kept the computer, so its the same installation. it just stopped showing videos and playfield images. and don't change music. but all the files are there.
Can you clarify. Does this mean you have a 2nd install with the same issue?, as i understand it the original pc was sold with the cab - or was the cab sold without the pc?.
I'm not sure if the issue is with a brand new install on a different pc or with the install on the original pc that was working before transit.
Please also attach a copies of the log.txt and pinballx.ini files
Only pinball hardware was sold. No computer or files was included.
Will send files when I get home.
  On 5/10/2022 at 9:15 AM, scutters said:
Ok. so it's a brand new install on a new pc, just using your old pinball hardware.
In that case most obvious thing to check is that LAV codecs are installed - https://forums.gameex.com/forums/files/file/2451-lav-video-codecs/
I think you may have reversed it. He kept the computer attached to the pincab, which he has since sold sans computer, files, etc.
He did say that it was working before so maybe the codecs are not the issue, but no way to know for sure until the pinballx.ini and log.txt files are provided as requested.
Not following it completly (but must be my Denglish)
If i read correctly, the cab is sold without the pc. So i asume(as Scutters said) that it is a new pc in the cab
correct, but. at the same time I still have all the software.
so my, previously working, installation no longer show images or video either. and I cant get it to work on his computer connected to the cab.
  Quote
[Display]
Monitor=0
rotate=270
Windowed=False
windowwidth=812
windowheight=457
windowx=543
windowy=752
PlayFieldBrightness=230
WheelTextColor=ffffffff
InfoTextColor=ffffffff
InfoTextOutlineColor=ff000000
FilterTextColor=ffffffff
MenuColor=ffffa500
ShowDateAndTime=False
WheelAutoCrop=True
FullScreenWindowedNew=False
StretchUnderlay=True
[BackGlass]
monitor=1
x=0
y=0
width=1280
height=1024
AutoPositionB2S=False
[DMD]
Enabled=False
monitor=2
x=0
y=0
width=900
height=300
AutoPositionPinMAME=False
[FileSystem]
EnableFileMatching=False
[Interface]
UseTableLoadingMedia=True
GIFbackgroundcolor=ff000000
DesktopModeEnabled=False
EnableAdditionalDetail=True
ShowSystem=True
ShowRatings=True
OneClickLaunch=True
[Audio]
StreamVolume=90
SampleVolume=90
PlaySoundInVideos=True
[Startup]
playsound=True
playvideo=False
StartWithWindows=No
[KeyCodes]
quit=81
left=37
right=39
select=13
rotate=82
pageleft=33
pageright=34
exitemulator=27
ingame=80
screenshot=83
capturevideos=86
instructions=73
volumedown=109
volumeup=107
credit=53
plunger=164
launch=50
[JoyCodes]
quit=10
left=0
right=1
select=2
rotate=11
pageleft=3
pageright=4
exitemulator=12
ingame=13
instructions=14
launch=17
Credit=15
Plunger=16
[Text]
All=All
PlayGameTwoPlayer=Two Player Game
Line1=Free Play
Line2=Press Start
Featuring=Featuring
Tables=Tables
PlayGame=Play Game
Instructions=Instructions
Information=Information
Flyer=Flyer
Gameplay=Gameplay
Tutorial=Tutorial
Promo=Promo
ExitGame=Exit Game
ReturnToGame=Return to Game
Return=Return
Exit=Exit
Shutdown=Shutdown
Favorite=Favorite
Favorites=Favorites
FavoritesAdd=Add To Favorites
FavoritesRemove=Remove From Favorites
MostPlayed=Most Played
LastPlayed=Last Played
Lists=Lists
CapturingVideos=Capturing videos. Please wait. This will take several minutes.
Ratings=Ratings
HighScores=High Scores
RateTable=Rate Table
NotRated=Not Rated
Systems=Systems
RecentlyAdded=Recently Added
Restart=Restart
[FuturePinball]
Enabled=False
WorkingPath=
TablePath=
Executable=
Parameters=
LaunchBeforeEnabled=false
LaunchBeforeWorkingPath=
LaunchBeforeHideWindow=False
LaunchBeforeWaitForExit=True
LaunchAfterEnabled=False
LaunchAfterWorkingPath=
LaunchAfterHideWindow=False
LaunchAfterWaitForExit=True
MouseClickFocus=True
[VisualPinball]
WorkingPath=F:\Visual Pinball
TablePath=F:\Visual Pinball\Tables
Executable=VPinballX.exe
AutoConfigure=False
[ExitScreen]
EnableExit=True
EnableShutdown=True
EnableRestart=True
[StartupProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=true
WaitForExit=false
[ExitProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=False
WaitForExit=
[AttractMode]
Timer=1
ShowFor=15
MuteAudio=False
[System_1]
Name=MAME
Enabled=False
WorkingPath=
TablePath=
Executable=
Parameters=
SystemType=0
[AutoExit]
Enabled=False
Minutes=10
[Login]
[PinballFX2]
Enabled=False
Executable=steam.exe
Parameters=-applaunch 226980 [TABLEFILE]
Process=Pinball FX2.exe
Rotate=False
WaitFor=20
[PinballArcade]
Parameters=-applaunch 238260
Process=PinballArcade.exe
WaitForSelect=50
[GameListManager]
onlinemode=true
[RealDMD]
EnableColor=False
Color=ffff1414
[PinballFX3]
Parameters=-applaunch 442120 "-table_[TABLEFILE]"
Process=Pinball FX3.exe
Rotate=False
WaitFor=20
[Zaccaria]
Enabled=False
Parameters=-applaunch 444930
Process=ZaccariaPinball.exe
[Topper]
monitor=3
x=0
y=0
width=1920
height=1080
[VideoCapture]
crf=21
KeysStartRecord=164|120
KeysEndRecord=164|120
Seconds=45
UseGPU=True
SavePath=F:\PinballX\Media\Visual Pinball\Table Videos
[Internal]
lastwheelcachematchsize=-1123
lastselected=Tee'd Off (Gottlieb 1993)Tee'd Off (1993)VisualPinball
filter_year=
filter_company=
filter_custom=
filter_favorites=False
filter_lastplayed=False
filter_mostplayed=False
filtername=Visual Pinball Tables
filter_rating=0
filter_system=Visual Pinball
filter_recentlyadded=False
filter_filterini=
lastwindirsize=44691
osname=Microsoft Windows 10 Pro
cpucores=6
cpuname=Intel(R) Core(TM) i5-8600K CPU @ 3.60GHz
[Plugin_1]
Enabled=False
Name=PlugInLED.dll
[Plugin_2]
Enabled=False
Name=PlugInSpeech.dll
[Plugin_3]
Enabled=False
[Plugin_4]
Enabled=False
Name=Xpadder Plugin.dll
[Apron]
monitor=4
x=0
y=0
width=1920
height=1080
[SetupWizard]
EmuPath1=C:\Emulation\Emulators
AssetPath1=C:\Emulation\Assets
ROMPath1=C:\Emulation\ROMs
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=Basic
SavePosition=False
SearchText=
EmulatorIndex=0
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=0
NewsFeedsIndex=0
MappedDrivesIndex=0
SystemIndex=0
ShowPanel=True
FontSize=1
WindowSize=1013, 839
WindowLocation=100, 135
WindowState=Normal
CustomArray=
SearchArray=
SectionIndex=4
[General]
Language=English
  Quote
09:16:20.43  2022-05-10:  PinballX Core - Version 5.41 x64
09:16:20.45  2022-05-10:  Microsoft Windows 10 Pro 64-bit (16GB)
09:16:20.45  2022-05-10:  Loading Settings
09:16:20.45  2022-05-10:  Initialize Component
09:16:20.47  2022-05-10:  Initialize Display
09:16:20.50  2022-05-10:  Testing Flash engine.
09:16:20.54  2022-05-10:  Loading PlugIns
09:16:20.55  2022-05-10:  Looking for startup images
09:16:20.95  2022-05-10:  Hiding Cursor
09:16:20.96  2022-05-10:  Hiding Taskbar
09:16:20.97  2022-05-10:  Getting GPU and CPU Information
09:16:21.00  2022-05-10:  CPU: Intel(R) Core(TM) i5-8600K CPU @ 3.60GHz
09:16:21.00  2022-05-10:  6 cores, 6 threads
09:16:21.00  2022-05-10:  GPU 1: NVIDIA GeForce RTX 2070 SUPER
09:16:21.00  2022-05-10:  Displays: 1
09:16:21.00  2022-05-10:  Load Game List
09:16:21.04  2022-05-10:  Loading Database: Visual Pinball
09:16:21.06  2022-05-10:  Initial load gamelist took: 16ms
09:16:21.08  2022-05-10:  Finding and matching artwork and videos
09:16:21.12  2022-05-10:  Took: 31ms
09:16:21.12  2022-05-10:  Loading Game Statistics and Scores
09:16:22.82  2022-05-10:  Loading Surfaces
09:16:22.87  2022-05-10:  Finished Loading Surfaces
09:16:22.87  2022-05-10:  Initialize Audio
09:16:22.92  2022-05-10:  Set Keyboard Controls
09:16:22.92  2022-05-10:  Initialize Joystick
09:16:23.05  2022-05-10:  2 Joysticks Attached
09:16:23.05  2022-05-10:  Setting default net connection limit to 25
09:16:23.05  2022-05-10:  Started
09:16:29.64  2022-05-10:  Exiting
09:16:29.66  2022-05-10:  Showing Taskbar
09:16:29.67  2022-05-10:  Unhiding Mouse Cursor
09:16:29.69  2022-05-10:  Disposing Plugins
09:16:29.69  2022-05-10:  Saving Settings
09:16:30.79  2022-05-10:  Bye
  On 5/10/2022 at 11:05 AM, Karmeck said:
Can you add the files as attachment as well?
Try to clear your %temp% folder as well (you got enough space left ?)
If you launch database manager, do you see your media ?
All thire content is included, but sure.
I have to check.
In game manager all boards have images. Gave to check the individual media categories.
i noticed something now, I tried to change the wheel image for ac-dc, but it stays the same.
temp folder cleared, about 50mb
I see the media, and can change it and in changes for me inside game manger, like changing wheel image for ac-dc, but inside pinball x, it stays the same.
This looks like a naming issue, or caching (but you cleared temp out)
What you can do for trying : move all the files in the media\《system》\wheel directory to another location.
With Databasemanager,  download or add some wheels.
Launch pinballx. Check if the wheels that you added are now available
more testing, moved one table to a separate folder, for kinda adding them by one, see which one is causing trubbel.
Still no videos,
open game manger, close it, open again, close it. start pinball x. image and audio now works.
add an other table, all is now black and all i get is wheel images, again.
What video codecs did you install ? (Where any codecs installed?)
Otherwise it looks like a corrupted file (1 or more)
all of them.
it was only when i removed the wheel image that the wheel image changed.
going back in to game manger I can see the image do not stay changed, only if I remove the current wheel image, it changes.
I'm not sure why PinballX isn't picking up your table videos (or images), but as you have file matching set to False make sure the videos are named exactly as the table name or table description (and check which folder they are in) - a screen shot of the files and a copy of you database xml might help us.
For the FTP / Gameex online you should use your email address now rather than forum userid - that was changed a while ago for security reasons.
what ever i enter in the username and password fields, do not stay there. They are gone as soon as I click on an other setting.
It kept what I put into after I ran pinballx once.
Videos and audio still don't work though. Only the starting music plays.
Have you made any changes to the pc after removing it from the cab, installing software etc?
(i notice a shortcut to MPC-HC on the desktop video, were extra codecs installed on top of the LAV codecs etc)
So no issues with sound card or other sound software
Are you sure you have playfield and audio files that are corresponding to your table name or table description ?
