[ATTN: Tom] PinballX 5.41 .net6 - Crash when using the key for turn up the sound
Hi,
I have 2 fresh installation of Windows 10 Pro (my desktop PC and my pinball cabinet) and PinballX crash when I push the key 'plus' or 'minus'.
If I change keys (replacing minus by J for example), PinballX crash too.
The log shows anything.
Attach your pinballx.ini as well please when reporting an issue. Thanks.
@Tom Speirs
This is reproduceable .
Nothing in the log, but in event log 2 Errors :
Application: PinballX.exe
CoreCLR Version: 6.0.322.12309
.NET Version: 6.0.3
Description: The process was terminated due to an internal error in the .NET Runtime at IP 00007FFA9C87D70F (00007FFA9C6B0000) with exit code c0000005.
Faulting application name: PinballX.exe, version: 1.0.0.0, time stamp: 0x61954b73
Faulting module name: coreclr.dll, version: 6.0.322.12309, time stamp: 0x6216cac2
Exception code: 0xc0000005
Fault offset: 0x00000000001cd70f
Faulting process id: 0x2c70
Faulting application start time: 0x01d84c9d20853f84
Faulting application path: C:\Pinball\PinballX\PinballX.exe
Faulting module path: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.3\coreclr.dll
Report Id: bdbb495b-e926-4cec-af8b-190f6fa1d975
Faulting package full name:
Faulting package-relative application ID:
Can you check code ?
  • Draco1962 changed the title to [ATTN: Tom] PinballX 5.41 .net6 - Crash when using the key for turn up the sound
  • 1 month later...
