Hi everyone,
I have a problem with PinballX.
When I am scrolling between Tables sometimes Pinball X will stuck loading the new backglass. Playfield Videos or Images are loading fast. Also sometimes the DMD Videos on the 3rd screen will not load fast. If I wait approx. 3-10 Sec. the new Image will displayed.
I have this looked over and over but I dont find any Solution.
Specs:
OS: Windows 10 Actual Release
PinballX Version: 5.28 64bit (but it is also slowing down on prev. versions)
If you need any more Information to help me with this problem feel free to ask.
Greetings
WALLY
Are you using the actual backglass file or videos/images in PinballX?
It's this setting in PinballX;
If set to Yes try setting to No and use videos/images for the backglass as you do for playfield.
Please also update your LAV codecs, that might help with the DMD videos.
If those are not the issue(s) then please attach you Pinballx\Log\Log.txt and PinballX\config\pinballX.ini files.
Hi
the setting for the B2S is set to NO. Setting it to YES will no show any Backglass in PinballX at all.
Files are attached.
WALLY
log.txt PinballX.ini
Edited by wallyrt
Editing File Attach
Hi Wally, can you attach copies of your pinballx.ini and log.txt files? No copy & paste please. Thanks.
DONE
Can't see any issues in the log or ini files.
Did you install or reinstall the lav codecs? If you did that can you confirm if the backglass problem is for all tables or only some, and attach a zip file with some of the backglass media where you have the issue.
I do not have installed the codec yet. I will do this this evening and report back if this will solve the issue.
Greetings
wally
1 hour ago, Mike_da_Spike said:
did it stopped working at a sudden moment, or did you reinstall the cabinet ?
Hi,
I had to reinstall the whole cabinet because my old Windows 7 System crashed. So I reinstalled it with WIndows 10.
@scutters
I have installed the lav codec and the problem seems to be gone. I still have to try some settings but the delay issue seems to be gone. Many thanks for the tip.
Greetings
WALLY
  • Draco1962 changed the title to [RESOLVED] PinballX slows down on Backglass
