11 minutes ago, insert58815 said:
How do I use the settings?
Don't you use dmdext to mirror the onscreen DMD to your dmd screen ?
18 hours ago, insert58815 said:
I want to mirror to the DMD screen
If you still have problems you'll need to attach more info on your setup (pinballx.ini) , what you have got set up so far  (launch before bat file script etc) and what your pinball wicked settings are. Otherwise it's just guessing..
Please attach copies of your pinballx.ini and log.txt files whenever reporting an issue or error. As @scutters noted and your database xml file. Thanks.
Within Joyriders  tutorial, you need to adjust dmdext.exe to match your dmd.
I don't think anything is wrong with PinballX or that the log will show anuything.
Just setup all correctly outside PinballX and it can be used in the frontend
I'm sorry I don't know how to program the keys (esc key)
To watch the tutorial, you need to set the camera to 8, but there is no camera 8 in the setting bar
Where does the dmd script need to be modified?
thank you allIMG-3487.thumb.jpg.45d4791bc7a226a4f18c5dccfbbbaff3.jpgIMG-3490.thumb.jpg.323246d2748980ad6ef7f5375db2b2c0.jpg彈球X.ini
See Joyriders tutorial and number 3
Quote
3) download and place dmdext files somewhere if you are not using it already i placed it in my scripts folder if it's installed in other location you will need to change parameters in batch files calling dmdext you'll also need to change it if you are using pindmd and not a virtual dmd like i do. https://github.com/freezy/dmd-extensions/ check the readme for parameters for pindmd etc
