Malakabator Posted January 5, 2021 Share Posted January 5, 2021 hey guys, I'm new to the DIY arcade life. i built a full size cabinet with my son. It came with a i-pac 2 controller and i purchased a Pandora Gbox-ex2 thinking i can just plug the usb into it and all will work. Well it doesn't. has anyone tried this that can give me pointers. Its already wired with the i-pac 2, i can copy the files from the Pandora just don't know where to go from there. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Draco1962 Posted January 5, 2021 Share Posted January 5, 2021 I take it you are not using an emulation frontend with the Pandora Gbox-ex2 . You may get better traction contacting the seller of the cartridge or product support site as we are dedicated to supporting the GameEx, PinballX, and Touch-Play emulation frontends. Moving this to a more appropriate subforum in the event someone is familiar and can give pointers. Quote Link to comment Share on other sites More sharing options...
tthurman Posted January 6, 2021 Share Posted January 6, 2021 Not being a JAMMA expert I'm at a bit of a disadvantage commenting here, but you do realize that JAMMA is a standardized interface that was designed to make quick work of switching out games in a JAMMA cabinet just by swapping out the PCB? If your cabinet had a JAMMA interface, harness then all you would do is plug it into the PCB. Due to this I don't see how the i-pac would ever function in this environment. The i-pac is a keyboard emulator that still may work with something like this particular PCB via one of the USB ports, but even so it has to be programmed. My i-pac was part of a custom joystick build I ordered, and arrived pre-configured due to this. I would venture to guess that yours simply hasn't been configured. https://www.ultimarc.com/control-interfaces/i-pacs/i-pac2/?selected_section=product_tab_25#product_tab_25 Quote Link to comment Share on other sites More sharing options...
