Just wondering if anybody can point me in the right direction. I am using GameEx Arcade with MAME and an Xarcade tankstick. For some reason my save state(create and load) are assigned to the bottom 2 buttons of the 2nd players controls. Where should I be looking to find out how to change them from those buttons to something else that won't interfere with the game play.
Hitting TAB in game while in MAME, go to  Input General, then User Interface.  (CAUTION! Changes here effect ALL MAME games, not just the one you are entering!)
You'll notice that Save State is assigned to F7 and Load State is F7 not Shift
Click Return to Previous Menu and then navigate to Player 2 controls, look for the F7 and Shift-F7 assignments and change to the buttons you wish by  clicking on the buttons of choice.
Save by clicking Return to Previous Menu (saves the changes) until you are out of the TAB menu.
  • Draco1962 changed the title to [RESOLVED] Tank-Stick Mame Save States
