I am currently on ver 3.45 will anything get messed up upgrading to the newest?  I just remember the pain of getting all setup in the beginning (being new and getting VPX tables correct mostly)so I wanted to ask.
The main reason is I was trying to setup FP w/BAM using FPloader.exe as the executable, it only partially works PinballX crashes back to the wheel screen why FP continues to load and plays the table.  Any idea if the upgrade will fix this?
Not all optimizations with a new release are posted. It will behoove you to upgrade and, if the FP issue persists, attach copies of your log.txt files for review.
You can always downgrade pbx after an upgrade. But if you encounter issues with a new version, the community is here to help you
