scutters Posted May 9, 2020 Share Posted May 9, 2020 Animated Company Logos View File These are an improved version of DMD style company logo animations (originally posted https://www.gameex.info/forums/topic/24176-animated-system-logos-wheels) along with some neon type animations to cover other years / manufacturers. Png files included are animated pngs. Note that the previews are on a white background, these files look better where they are intended to be used, on the dark semi transparent Additional Detail area of PinballX. Files included (ALT is used to indicate alternatives for the main version of a file, remove the ALT part to use it in PinballX); DMD Style Alvin G.gif Bally (1991-).gif Bally (1991-)ALT.gif * Alternative Bally animation, could be renamed and used for games listed as Midway Barnstorm Games.gif * Not a 'real' DMD animation. Improvised. Capcom.gif Data East (1991-).gif Data East (1991-)ALT1.gif * Alternative DE animation, rename to use Data East (1991-)ALT2.gif * Alternative DE animation, rename to use Farsight Studios.gif * Not a 'real' DMD animation. Improvised. Form Slingers.gif * Not a 'real' DMD animation. Improvised. Gottlieb (1992-).gif Gottlieb (1992-)ALT1.gif * Alternative Gottlieb Premier animation, also used as as Premier JP Salas.gif * Not a 'real' DMD animation. Improvised. Inder (1993-).gif * Not a 'real' DMD animation. Improvised. Midway (1991-).gif * Not a 'real' DMD animation. Improvised. Original.gif * Not a 'real' DMD animation. Improvised. Premier.gif * Duplicate of Gottlieb (1992-)ALT1.gif Sega (1981-).gif SegaALT1 (1981-).gif * Alternative Sega animation, rename to use SegaALT2 (1981-).gif * Alternative Sega animation, rename to use Spinball.gif Spinball S.A.L..gif Spooky Pinball.gif * Not a 'real' DMD animation. Improvised. Stern (1999-2010).gif Stern (2011-2016).gif Technetium Games.gif * based on ftp dmd video Williams (1991-).gif Williams (1991-)ALT.gif * Alternative Williams animation, rename to use Zen Studios.gif Neon Effect (pre DMD) Allied Leisure.apng Astro Games.apng Atari.apng Automaticos.apng AutomaticosALT.apng * Talleres del Llobregat Bally (-1990).apng Bally Midway.apng Bally Wulff.apng Barni.apng Bell Games.apng Bensa.apng Bill Port.apng Chicago Coin.apng Christian.apng * Christian Automatic / Christian Tabart CIC Play.apng Cirsa.apng Data East (-1990).apng EMAGAR.apng Epic Games.apng Epic Pinball.apng Europlay.apng Game Plan.apng Geiger.apng Gottlieb (-1979).apng Gottlieb (1980-1991).apng Grand Products.apng Hankin.apng HankinALT.apng I.D.I..apng Iberomatic.apng Iberomatic S.A..apng IDSA.apng Inder (-1985).apng Inder (1986-1992).apng Interflip.apng Jac van Ham.apng Jersey Jack Pinball.apng Jeutel.apng Joctronic.apng Juegos Populares.apng LTD.apng MAC.apng MAC S.A..apng Maresa (-1975).apng Maresa (1976-).apng MARSA.apng Midway (-1990).apng Mylstar.apng No Image.apng No Image.png Nuova Bell Games.apng Petaco.apng Peyper.png Pinstar.apng Playmatic.apng Rally (-1965) Rally (1966-) Recel.apng Recreativos Franco.apng Rowamet.apng Sega (-1980).apng Segasa.apng SLEIC.apng Sonic.apng SonicALT.apng Sport Matic.apng Stargame.apng Stern (-1980).apng Stern (1981-1998).apng Taito.apng Taito do Brasil.apng Tecnoplay.apng Unidesa.apng Universal de Desarrollos Electronicos.apng * same as Unidesa Videodens.apng Williams (-1990).apng Zaccaria.apng Other (matching display type of era / tables) American Pinball.gif Dutch Pinball.gif Magic Pixel.apng Malzbie Games.apng Mr Game.gif Pinball Fantasies.gif Stern (2017-).apng OrbitalPin.apng OrbitalPinALT.gif VPW.apng These files should be placed in your PinballX\Media\Company Logos folder. The files are named to display the animations only for years ranges in the brackets, but can be renamed to display for all years if that is preferred. As always with these things keep the ones you want, delete what you don't!. To display the animations in PinballX make sure you're up to date and have Show Additional Detail enabled under General settings in Settings.exe. If you display company logos as wheel overlay images (Settings.exe->Generel Settings->Wheel Overlay Images option) the gif images will not display correctly in the wheel. Copy a static png logo image with same file/company name as the gif back to the company logos folder (that file will be used for the overlay, with the gif displayed in Additional Detail area), or disable the wheel overlay option. The animations need PinballX V4.84 or later to work. If the logo's aren't being used / picked up by PinballX please check your database table entry Manufacturer name, the company name should match the name of the file, if it doesn't change the name of file or update the manufacturer info for those table(s). Submitter scutters Submitted 05/09/20 Category Wheel Images 2 1 Quote Link to comment Share on other sites More sharing options...
Mike_da_Spike Posted May 11, 2020 Share Posted May 11, 2020 Really nice @scutters ! Do you also have them not pixelated ? Just the regular ones with a resolution of 128x32 (or a larger equivalent of it) ? Thanks man ! Quote Link to comment Share on other sites More sharing options...
scutters Posted May 11, 2020 Author Share Posted May 11, 2020 3 hours ago, Mike_da_Spike said: Really nice @scutters ! Do you also have them not pixelated ? Just the regular ones with a resolution of 128x32 (or a larger equivalent of it) ? Thanks man ! Thanks mate I have frames @ 128*32 for most of these, but they don't look very good used as company logos in the additional detail area - so i scaled to 512*128 with a new overlay and then resized to 512*160 to stop pinballx stretching them more horizontally when used in the front end. So these logo gifs are pretty much specifically only for use in additional detail area. If you need source frames for another use i can send them over to you. I posted the some company logo images @128*32 a while back; https://www.gameex.info/forums/topic/23059-company-logos-12832/ 1 Quote Link to comment Share on other sites More sharing options...
PcTeknic Posted May 27, 2020 Share Posted May 27, 2020 This is really fantastic. Do you also plan to make Spanish manufacturers such as Inder, Juegos Populares, Maresa or Recreativos Franco y Sonic? From other game makers like Barnstorm Games (Pro-Pinball), SlamIt Pinball (Big Score), Zen Studios (FX2 and FX3)? I have those clean logos in .png, I can pass them to you since some will not find them. 1 Quote Link to comment Share on other sites More sharing options...
scutters Posted May 27, 2020 Author Share Posted May 27, 2020 @PcTeknic Thanks, glad you like them! I concentrated on the mainstream companies to start with. I'll try to add more, but it might take a while as i've got a few things on at the moment (blame @Mike_da_Spike) 1 1 Quote Link to comment Share on other sites More sharing options...
PcTeknic Posted May 27, 2020 Share Posted May 27, 2020 Por supuesto, todo el tiempo que necesites. La verdad que los Pinball Españoles son poco conocidos, pero no ver el de Zen Studios si que me ha extrañado mucho. I have forgotten some like Farsight Studios (Pinball Arcade) or Fromslingers (Pinball Wicked) Quote Link to comment Share on other sites More sharing options...
Mike_da_Spike Posted May 27, 2020 Share Posted May 27, 2020 1 hour ago, scutters said: @PcTeknic Thanks, glad you like them! I concentrated on the mainstream companies to start with. I'll try to add more, but it might take a while as i've got a few things on at the moment (blame @Mike_da_Spike) Blame the Dutch guy .. thats an easy one ... 1 Quote Link to comment Share on other sites More sharing options...
scutters Posted May 28, 2020 Author Share Posted May 28, 2020 (edited) @PcTeknic Here's a zen studios one to get you by.. I'll add it to the download pack when i've got a few more. (thanks to @Mike_da_Spike, i used his fx3 real dmd videos as source) Edited June 4, 2020 by scutters Note - this gif is now included in the download pack (v1.2) 2 Quote Link to comment Share on other sites More sharing options...
PcTeknic Posted May 28, 2020 Share Posted May 28, 2020 Is really great. Fantastic, thanks Quote Link to comment Share on other sites More sharing options...
joyrider3774 Posted May 28, 2020 Share Posted May 28, 2020 not sure if they are needed but i got the formslingers logo. not sure where i had gotten it think from their media site or website (edit no it was from here http://formslingers.com/ ) Farsight studios i also have but i guess you do to btw where do you display these componay logo's ? just instead of the normal company logo's ? isn't it like a bit overactive if they are animated not sure i've seen a video somewhere showing this in action 2 Quote Link to comment Share on other sites More sharing options...
scutters Posted May 28, 2020 Author Share Posted May 28, 2020 6 hours ago, joyrider3774 said: btw where do you display these componay logo's ? just instead of the normal company logo's ? isn't it like a bit overactive if they are animated not sure i've seen a video somewhere showing this in action They just appear in the additional detail area of pinballx (with game rating, system name etc) if you have that set to do so. I tried to make most of them start on a 1st frame that is the main logo, and display that for a couple of seconds before the other frames to try to stop them being too busy. I don't have a video recorded, but you can always download them, try them and then delete if you don't like them. They'll probably be the only gif files in your company logos folder so easy enough to identify, and you don't need to delete png images before copying the gifs, pinballx will just use the gifs if found. Quote Link to comment Share on other sites More sharing options...
scutters Posted June 4, 2020 Author Share Posted June 4, 2020 I have update the pack to V1.2 (once approved) Lots of the logos requested have been added. Enjoy 2 Quote Link to comment Share on other sites More sharing options...
PcTeknic Posted June 5, 2020 Share Posted June 5, 2020 Really awesome, thanks again. 1 Quote Link to comment Share on other sites More sharing options...
PcTeknic Posted June 5, 2020 Share Posted June 5, 2020 I´m very happy with scutters Company Logos in my PinballX, looks great, nice work!!!!! 1 Quote Link to comment Share on other sites More sharing options...
scutters Posted June 6, 2020 Author Share Posted June 6, 2020 Updated to 1.3. As release note "Added more logos, Mylstar, Peyper, Form Slingers. Fixed ratios for Mr Game and Sonic to keep sizing same for all." 50 in the pack now so that's your lot for a while (i hope!) 2 Quote Link to comment Share on other sites More sharing options...
scutters Posted June 20, 2020 Author Share Posted June 20, 2020 Updated to v1.4 when approved. Neon effect gifs now more flickery. 1 Quote Link to comment Share on other sites More sharing options...
pindapoe Posted June 21, 2020 Share Posted June 21, 2020 Hello, thanks for the logos, they look beautiful, when I try to click in "View File" I got the following message as seen in the image I attached. Quote Link to comment Share on other sites More sharing options...
scutters Posted June 22, 2020 Author Share Posted June 22, 2020 @pindapoe should be approved and available to download again now. Quote Link to comment Share on other sites More sharing options...
scutters Posted June 27, 2020 Author Share Posted June 27, 2020 Updated to V1.5 (waiting approval) As release note; Too many companies added to list. Also corrected some names / years to match IPDB manufacturer data (e.g. 'Spinball.gif' is now 'Spinball S.A.L..gif') *** Because of the corrections in file names, i recommend deleting existing gif files in your Company Logos folder before copying the new versions across *** Most companies that made made more than a couple of tables are now covered Quote Link to comment Share on other sites More sharing options...
scutters Posted July 7, 2020 Author Share Posted July 7, 2020 Updated to V1.5.1 Bensa and Nuova Bell Games added. 1 Quote Link to comment Share on other sites More sharing options...
scutters Posted November 22, 2020 Author Share Posted November 22, 2020 Updated to V2 - neon gifs changed to use animated png format which look a whole lot better with semi transparency ** as in release notes make sure you update PinballX to V4.79 or later ** 1 Quote Link to comment Share on other sites More sharing options...
Wiesshund Posted December 6, 2020 Share Posted December 6, 2020 The Logos look great, up in the top right corner Where the animated system logo appears But it also displays them at the top right of the wheel image, with a small non animated system logo on the top left of the wheel image And the DMD style animated ones, like SEGA for example or JP Salas display funny there. Like SEGA is zoomed in on the E and G, dont even see the full letter, and JP Salas, all you see is las blown up real big Zaccaria does not even appear at all. See what it is doing to the SEGA logo here? Can't be the images themselves as you can see they work in the top right but they do not work where mirrored on the wheel Funny thing is, the non animated ones, the neons, they appear on the wheel fine Wonder if i can turn them off on the wheel, it is a bit redundant anyways Quote Link to comment Share on other sites More sharing options...
scutters Posted December 6, 2020 Author Share Posted December 6, 2020 The difference in the wheel overlay for DMD style and neon is probably due to the format (dmd are gif, neon are apng). I guess PinballX just pulls the first frame out differently depending on type. For the gifs if you have a static png with the same name in the company logos folder then pinballx should use that for the wheel overlay instead of a gif frame. But yes you can also turn them off in the wheel, in settings under general settings, wheel overlay images. I did have a note about it on the download at one time, i seem to have deleted it along the way somewhere so i'll add it back. Cheers! Quote Link to comment Share on other sites More sharing options...
scutters Posted April 10, 2021 Author Share Posted April 10, 2021 V2.2 posted. Added; AutomaticosALT.apng Barni.apng Bill Port.apng CIC Play.apng EMAGAR.apng Epic Games.apng Epic Pinball.apng Interflip.apng Joctronic.apng Magic Pixel.apng Malzbie Games.apng MARSA.apng Pinball Fantasies.gif Sport Matic.apng 1 Quote Link to comment Share on other sites More sharing options...
PcTeknic Posted April 21, 2021 Share Posted April 21, 2021 I've already tried them, they look great, thanks a million. 1 Quote Link to comment Share on other sites More sharing options...
