I had a working version of GameEx Arcade on my Windows 10 dell Optiplex 960 3.49ghz with 4gb of ram. I am using MAME .220 and I have the MAME .219 romset. It was all working but with no artwork so I downloaded the MAME system pack and ran the install. All appeared to work folders are all full of media and when I first fired up GameEx it looked great but it was flickering at the bottom of the screen a little so I closed it out and tried to open the setup wizard and it wouldn’t open so I tried to uninstall and it wouldn’t uninstall so I tried to open up GameEx again and now it will not open. Shows hourglass for a second after I try to open it then nothing ever happens.
You should also consider upgrading your MAME ROM set to match the version of MAME you are running to avoid errors due to incompatibility.
