Hi guys, so the control panel layout image is a great idea taht pops up before the MAME rom loads.
However, I guess my buttons were "designed/installed" backwards. I have 4,5,6 on top, and 1,2,3 on bottom.
My layout:
4-5-6
1-2-3
All the buttons work if remapped, but for instance, Zaxxon, has 1 button to fire with. The pop up image shows button 4 as "Fire", when in fact I have to press button 1. So, where does Gameex get the layout as to what button is 1 or 5 etc?
Edited by tthurman
Moved: GameEx>General
Thanks! However, where is it designated that the upper left button is "button1" in the controls.ini?
I rather not move my buttons physically to match up with 1 in upper left since right now my 1 is in lower left.
I could also edit the controls.ini to swap all JOY_BTN1 with BTN4 etc..but don't want that to update in the future.
That make sense?
I haven't spent a considerable amount of time working on customization's myself, but you might want to give this a read for the information you're looking for.
Ok, so it seems this feature of displaying the cpanel layout is driven by cpwizard if I understand.
Also, the output file controls.ini is designed for button layout of:
1 2 3
4 5 6
Are those safe assumptions?
As I understand it the CP Wizard is outputting information based on that from the controls.ini file, but what it can't know is where you may have those particular holes filled on any given control panel layout or what key they correlate to on any number of available keyboard encoders.  I'm not sure that makes sense....
It would seem there would be a more universal layout to simplify the process, but if there is I'm not aware of it.
This thread is old, but should give you an idea.
http://forum.arcadecontrols.com/index.php?topic=61726.0
From my understanding, it used to be that the controls.ini (also controls.dat) was updated for each MAME update. I don't think it continues to be updated for quite a few years now.
Thanks for the input guys. I decided in teh end to just move my bottom row of buttons to the top to line up with the image/layout.
I'll work more on this once the rest of the cabinet is fully working.
I've never understood this either, it's based on .141 yet somehow still considered to be effective and seems to be universally supported regardless of it's age.  :huh:
controller ini files are another option
If you look into it deeper you will start to notice omissions over time with regards to systems that have since been made to work since .141 was released.
