Hello all first post.
Im having an issue only while launching future pinball through pinballX.
It wont allow the backglass to go resize into full on my 2nd monitor and all around it,  turns green.
When launching BAM without PinballX, everything works fine.
• Also having an issue when VPX launches, the playfield is just black, this of course works fine when not using PinballX. (focus at the time learning the program and working with FP as i know it well.
I have just started setting things up, first time user.
thanks for any suggestions.
PinballX.ini
I don't have any experience with FP (not using it)< but if you post your log file (in the log directory, the log.txt file) as attachemnt.
Make sure you simulate your issue and closing PBX and post that log file.
For Visual pinball, do you run PBX as admin ?
please do FP and VPX run and post that log
The future pinball issue seemed to be an isolated table, so far so good.
I was able to get the VP working as well, looks like i need to make some batch kills for the B2s, is there a common script definition for this?
you can use a bat(ch) file as a launch after / launch before script for the system. For killing stuff taskkill should suffice in the batch file but you can do anything from inside batch files even powershell, vbscript etc by calling the executables. I sometimes use powershell if i need to run something elevated (as administrator). for launch before stuff i also use autohotkey scripts which i compile to exe's and run from bat files
Taskill in  a batch will work, but please be aware it's unusual to need to do that for B2S - it should close when VP exits. Does the B2S close with VP outside pinballx?
