Looking for someone to test LEDBlinky with 64bit GameEx
Hey all,
I've created new 64 bit versions of the LEDBlinky GameEx and PinballX plugins and I'm looking for a couple users to give them a test. Email me back if you're currently using LEDBlinky with GameEx or PinballX (32 bit) and are willing to install the 64 bit version and do a quick test.
Thanks, arzoo
  • tthurman pinned, featured and unfeatured this topic
Attached are my gameex.ini and log.txt files from GameEx Arcade Edition X64:
log.txtGameEx.ini
For whatever the reason, the plugin is not loading when running AE 64-bit and the Pixelcade DMD does not display anything.
20:26:59.08  2/27/2020:  Loading PlugIns
20:26:59.11  2/27/2020:  Could Not Load Plugin: 3
@arzoo is able to load it. I am not able to determine why it will not load for me. The x32 version of AE loads the plugin fine and my Pixelcade DMD launches as expected.
Sorry it has been a full day and wasn't able to test as hoped. I'll have to give it a try tomorrow.
Do you mind downloading the latest update from the LEDBlinky site and giving that a try when you have time? Testing on my end indicates the 64-bit plugin is working but I'd like an additional confirmation. Thanks!
Pixelcade appears to be working in AE now. I had to delete the previous LEDBlinky installation and run the installer as administrator.
There are a few issues to iron out heading in the right direction.
Final issue appears to be with GameEx Arcade not closing down LEDBlinky during exit from AE. Per my conversation with @arzoo he noted:
"During my testing I also noticed that GameEx was not sending the FEQuit command when it exited."
EDIT: I have not yet tested with GameEx. I expect that the results should be the same.
Hi Tom - I have confirmed the exit behavior works as expected in GameEx vs. not working in GameEx Arcade Edition when configured with the 64-bit option.
Confirmed working well with GameEx and GameEx Arcade Editions running 64-bit versions of v16.28 available now for download!  Thanks, Tom, for the quick fix for AE!
