if you want to launch specific tables directly on pfx3 you still need to ask for a cabinet code. Launching tables using commandline only works if cabinet mode key has been entered as far as i'm aware. If you do have a key you don't have to setup any backglasses or dmd repositioning and you can just play on a single screen as usual if wanted. I do advice when requesting a key they will ask for a photo of your setup and they might accept the cabinet key request when you show a rotated screen (physically) thats how i initally did it before i had my cabinet. If you already got a key yes the settings in pinballx / database etc is the same as playing on a cabinet
Well .. Tom added grid position for FX3 in desktop mode. You need to set this up in gamemanager.  I never used it, but give that a try.
Thanks I did have a cabinet with a code worked perfectly but have had to sell the cab due to room, have just reinstalled on my oc bug can only play in desktop mode when you launch the table it just goes to the pinvallfx3 menu  and you then have to scroll the menu for the table.
can you try something ?
Open a cmd prompt and "cd" to your steam.exe folder. Then type the following :
steam.exe -applaunch 442120 -table_Citadel
and press enter. Does it launch the sorcerers lair table or do you end up in the main menu ?
Also since you had a cabinet code activated before are the options for cabinet mode in the main menu still available ? if not can you reenter your cabinet code that you had gotten for your cabinet and try again ?
Had to resend for my code as its saying the one I have is invalid, I have fx2 loading into desktop no issues just fx3 I am having the issue with.
if you don't see the cabinet options or it's asking for code or something then direct launching of tables is not available as far as i know. You can test it with the cmd command i gave you. if not wait for the code and check again then :)
