Hi, I have latest edition of pinballx. I am finding that in the front end my backglasses and playfield are not matching up. Also when I select a table, often a different table will open up. Seems like everything not in sync. All my games play great if I open individually in VPX.
14:56:54.8  12/7/2019:  PinballX - Version 4.05 x64
14:56:55.0  12/7/2019:  Windows 10 Home 64-bit (16GB)
14:56:55.0  12/7/2019:  Loading Settings
14:56:55.1  12/7/2019:  Initialize Component
14:56:55.2  12/7/2019:  Initialize Display
14:56:55.3  12/7/2019:  Machine just booted so waiting 6 seconds for screens and startup programs. Boot Time = 12/7/2019 2:56:26 PM
14:57:01.3  12/7/2019:  Testing Flash engine.
14:57:03.7  12/7/2019:  Loading PlugIns
14:57:04.2  12/7/2019:  Created DirectX BackGlass Window
14:57:04.3  12/7/2019:  Created DirectX DMD Window
14:57:04.3  12/7/2019:  Looking for startup images
14:57:04.4  12/7/2019:  Hiding Cursor
14:57:04.5  12/7/2019:  Hiding Taskbar
14:57:04.5  12/7/2019:  Getting GPU and CPU Information
14:57:04.5  12/7/2019:  CPU:  Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
14:57:04.5  12/7/2019:  4 cores, 4 threads
14:57:04.5  12/7/2019:  GPU 1: NVIDIA GeForce GTX 1050 Ti
14:57:04.6  12/7/2019:  GPU 2: Intel(R) HD Graphics 4000
14:57:04.6  12/7/2019:  Displays: 3
14:57:04.6  12/7/2019:  Load Game List
14:57:04.6  12/7/2019:  Loading Database: Visual Pinball
14:57:04.6  12/7/2019:  Initial load gamelist took: 31ms
14:57:04.6  12/7/2019:  Initial load gamelist took: 16ms
14:57:04.7  12/7/2019:  Finding and matching artwork and videos
14:57:04.8  12/7/2019:  Took: 157ms
14:57:04.8  12/7/2019:  Loading Game Statistics and Scores
14:57:05.3  12/7/2019:  Main display running full screen windowed.
14:57:05.3  12/7/2019:  Loading Surfaces
14:57:05.4  12/7/2019:  Finished Loading Surfaces
14:57:05.4  12/7/2019:  Initialize Audio
14:57:05.6  12/7/2019:  Set Keyboard Controls
14:57:05.7  12/7/2019:  Initialize Joystick
14:57:05.8  12/7/2019:  1 Joystick Attached
14:57:05.8  12/7/2019:  Started
15:02:37.9  12/7/2019:  Launch System
15:02:37.9  12/7/2019:  Hide DMD
15:02:37.9  12/7/2019:  Hide Backglass
15:02:37.9  12/7/2019:  Waiting for threads
15:02:37.9  12/7/2019:  Disposing display
15:02:38.3  12/7/2019:  Writing ScreenRes.txt
15:02:38.3  12/7/2019:  C:\Pinball\Visual Pinball\VPinballX.exe /play -"C:\Pinball\Visual Pinball\Tables\Playboy(Bally 1978)1.3.vpx"
15:02:38.4  12/7/2019:  Writing ScreenRes.txt
15:02:38.4  12/7/2019:  C:\Pinball\Visual Pinball\VPinballX.exe /play -"C:\Pinball\Visual Pinball\Tables\Nascar Stern 2005.vpx"
15:02:40.4  12/7/2019:  C:\Pinball\PinballX\vpauto.exe
15:02:40.5  12/7/2019:  C:\Pinball\PinballX\vpauto.exe
15:02:45.3  12/7/2019:  VPX Full screen exclusive mode detected
15:02:45.4  12/7/2019:  VPX Full screen exclusive mode detected
15:02:56.8  12/7/2019:  Found PinMAME ROM: nascar.nv
15:02:58.5  12/7/2019:  Found PinMAME ROM: nascar.nv
15:03:35.1  12/7/2019:  Hidden Visual Pinball Editor Window
15:03:35.6  12/7/2019:  Hidden Visual Pinball Editor Window
15:04:00.4  12/7/2019:  Exit System Control Pressed
15:04:34.1  12/7/2019:  Created DirectX BackGlass Window
15:04:34.1  12/7/2019:  Created DirectX DMD Window
15:04:34.6  12/7/2019:  Main display running full screen windowed.
15:04:37.4  12/7/2019:  Created DirectX BackGlass Window
15:04:37.6  12/7/2019:  Created DirectX DMD Window
15:04:38.0  12/7/2019:  Main display running full screen windowed.
15:09:26.4  12/7/2019:  Launch System
15:09:26.4  12/7/2019:  Hide DMD
15:09:26.4  12/7/2019:  Hide Backglass
15:09:26.4  12/7/2019:  Waiting for threads
15:09:26.4  12/7/2019:  Disposing display
15:09:26.8  12/7/2019:  Writing ScreenRes.txt
15:09:26.8  12/7/2019:  C:\Pinball\Visual Pinball\VPinballX.exe /play -"C:\Pinball\Visual Pinball\Tables\Diner.vpx"
15:09:31.5  12/7/2019:  C:\Pinball\PinballX\vpauto.exe
15:09:31.6  12/7/2019:  The process cannot access the file 'C:\Pinball\PinballX\Databases\Statistics.ini' because it is being used by another process.
15:09:31.6  12/7/2019:     at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
15:09:31.6  12/7/2019:     at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
15:09:31.6  12/7/2019:     at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize)
15:09:31.6  12/7/2019:     at PinballX.inireadernet.Flush()
15:09:31.6  12/7/2019:     at PinballX.FrmMain.x()
15:09:32.5  12/7/2019:  Created DirectX BackGlass Window
15:09:32.6  12/7/2019:  Created DirectX DMD Window
15:09:32.1  12/7/2019:  Main display running full screen windowed.
15:09:36.2  12/7/2019:  VPX Full screen exclusive mode detected
15:09:53.2  12/7/2019:  Found PinMAME ROM: diner_l4.nv
15:11:30.5  12/7/2019:  Launch System
15:11:30.5  12/7/2019:  Hide DMD
15:11:30.5  12/7/2019:  Hide Backglass
15:11:30.5  12/7/2019:  Waiting for threads
15:11:30.6  12/7/2019:  Disposing display
15:11:31.3  12/7/2019:  Writing ScreenRes.txt
15:11:31.4  12/7/2019:  C:\Pinball\Visual Pinball\VPinballX.exe /play -"C:\Pinball\Visual Pinball\Tables\Family Guy.vpx"
15:11:31.1  12/7/2019:  C:\Pinball\PinballX\vpauto.exe
15:11:36.1  12/7/2019:  VPX Full screen exclusive mode detected
15:11:39.8  12/7/2019:  Found PinMAME ROM: diner_l4.nv
15:11:59.3  12/7/2019:  Exit System Control Pressed
15:12:07.1  12/7/2019:  Created DirectX BackGlass Window
15:12:08.0  12/7/2019:  Created DirectX DMD Window
15:12:08.3  12/7/2019:  Main display running full screen windowed.
15:12:08.5  12/7/2019:  Created DirectX BackGlass Window
15:12:08.6  12/7/2019:  Created DirectX DMD Window
15:12:08.9  12/7/2019:  Main display running full screen windowed.
15:17:29.5  12/7/2019:  Launch System
15:17:29.5  12/7/2019:  Hide DMD
15:17:29.5  12/7/2019:  Hide Backglass
15:17:29.5  12/7/2019:  Waiting for threads
15:17:29.5  12/7/2019:  Disposing display
15:17:29.6  12/7/2019:  Launch System
15:17:29.6  12/7/2019:  Hide DMD
15:17:29.6  12/7/2019:  Hide Backglass
15:17:29.6  12/7/2019:  Waiting for threads
15:17:29.6  12/7/2019:  Disposing display
15:17:29.8  12/7/2019:  Writing ScreenRes.txt
15:17:29.8  12/7/2019:  C:\Pinball\Visual Pinball\VPinballX.exe /play -"C:\Pinball\Visual Pinball\Tables\Super Mario Bros.vpx"
15:17:29.9  12/7/2019:  C:\Pinball\PinballX\vpauto.exe
15:17:29.1  12/7/2019:  Writing ScreenRes.txt
15:17:29.1  12/7/2019:  C:\Pinball\Visual Pinball\VPinballX.exe /play -"C:\Pinball\Visual Pinball\Tables\Strikes 'N Spares.vpx"
15:17:30.1  12/7/2019:  C:\Pinball\PinballX\vpauto.exe
15:17:33.7  12/7/2019:  VPX Full screen exclusive mode detected
15:17:33.1  12/7/2019:  VPX Full screen exclusive mode detected
15:17:37.5  12/7/2019:  Found PinMAME ROM: snspares.nv
15:17:38.0  12/7/2019:  Found PinMAME ROM: snspares.nv
15:20:34.0  12/7/2019:  Exit System Control Pressed
15:20:34.1  12/7/2019:  Exit System Control Pressed
15:20:40.5  12/7/2019:  Created DirectX BackGlass Window
15:20:40.6  12/7/2019:  Created DirectX DMD Window
15:20:40.8  12/7/2019:  Main display running full screen windowed.
15:20:41.5  12/7/2019:  Created DirectX BackGlass Window
15:20:41.6  12/7/2019:  Created DirectX DMD Window
15:20:41.9  12/7/2019:  Main display running full screen windowed.
15:22:59.7  12/7/2019:  Launch System
15:22:59.7  12/7/2019:  Hide DMD
15:22:59.7  12/7/2019:  Hide Backglass
15:22:59.7  12/7/2019:  Waiting for threads
15:22:59.7  12/7/2019:  Disposing display
15:22:59.8  12/7/2019:  Launch System
15:22:59.8  12/7/2019:  Hide DMD
15:22:59.8  12/7/2019:  Hide Backglass
15:22:59.8  12/7/2019:  Waiting for threads
15:22:59.8  12/7/2019:  Disposing display
15:23:00.1  12/7/2019:  Writing ScreenRes.txt
15:23:00.1  12/7/2019:  C:\Pinball\Visual Pinball\VPinballX.exe /play -"C:\Pinball\Visual Pinball\Tables\Playboy(Bally 1978)1.3.vpx"
15:23:00.5  12/7/2019:  C:\Pinball\PinballX\vpauto.exe
15:23:04.4  12/7/2019:  VPX Full screen exclusive mode detected
15:23:13.8  12/7/2019:  Found PinMAME ROM: playboyb.nv
15:23:28.9  12/7/2019:  Exit System Control Pressed
15:23:35.2  12/7/2019:  Created DirectX BackGlass Window
15:23:35.3  12/7/2019:  Created DirectX DMD Window
15:23:35.9  12/7/2019:  Main display running full screen windowed.
15:23:36.2  12/7/2019:  Created DirectX BackGlass Window
15:23:36.3  12/7/2019:  Created DirectX DMD Window
15:23:36.6  12/7/2019:  Main display running full screen windowed.
15:40:38.8  12/7/2019:  Launch System
15:40:38.8  12/7/2019:  Hide DMD
15:40:38.8  12/7/2019:  Hide Backglass
15:40:38.8  12/7/2019:  Waiting for threads
15:40:38.8  12/7/2019:  Disposing display
15:40:39.2  12/7/2019:  Writing ScreenRes.txt
15:40:39.2  12/7/2019:  C:\Pinball\Visual Pinball\VPinballX.exe /play -"C:\Pinball\Visual Pinball\Tables\Who Dunnit.vpx"
15:40:39.3  12/7/2019:  C:\Pinball\PinballX\vpauto.exe
15:40:39.3  12/7/2019:  Writing ScreenRes.txt
15:40:39.3  12/7/2019:  C:\Pinball\Visual Pinball\VPinballX.exe /play -"C:\Pinball\Visual Pinball\Tables\The Walking Dead.vpx"
15:40:39.4  12/7/2019:  C:\Pinball\PinballX\vpauto.exe
15:40:43.2  12/7/2019:  VPX Full screen exclusive mode detected
15:40:43.3  12/7/2019:  VPX Full screen exclusive mode detected
15:40:46.9  12/7/2019:  Found PinMAME ROM: wd_12.nv
15:40:50.8  12/7/2019:  Found PinMAME ROM: wd_12.nv
15:58:03.7  12/7/2019:  Exit System Control Pressed
15:58:11.1  12/7/2019:  Created DirectX BackGlass Window
15:58:11.9  12/7/2019:  Created DirectX DMD Window
15:58:13.3  12/7/2019:  Main display running full screen windowed.
15:58:13.4  12/7/2019:  Created DirectX BackGlass Window
15:58:13.5  12/7/2019:  Created DirectX DMD Window
15:58:13.7  12/7/2019:  Main display running full screen windowed.
17:27:29.1  12/7/2019:  Launch System
17:27:29.2  12/7/2019:  Hide DMD
17:27:29.2  12/7/2019:  Hide Backglass
17:27:29.2  12/7/2019:  Waiting for threads
17:27:29.2  12/7/2019:  Disposing display
17:27:29.2  12/7/2019:  Launch System
17:27:29.6  12/7/2019:  Writing ScreenRes.txt
17:27:29.6  12/7/2019:  C:\Pinball\Visual Pinball\VPinballX.exe /play -"C:\Pinball\Visual Pinball\Tables\Twilight Zone.vpx"
17:27:29.6  12/7/2019:  C:\Pinball\Visual Pinball\VPinballX.exe /play -"C:\Pinball\Visual Pinball\Tables\The Sopranos.vpx"
17:27:29.6  12/7/2019:  C:\Pinball\PinballX\vpauto.exe
17:27:29.7  12/7/2019:  C:\Pinball\PinballX\vpauto.exe
17:27:33.6  12/7/2019:  VPX Full screen exclusive mode detected
17:27:45.3  12/7/2019:  Found PinMAME ROM: sopranos.nv
17:27:46.6  12/7/2019:  Found PinMAME ROM: sopranos.nv
17:34:11.5  12/7/2019:  Exit System Control Pressed
17:34:11.6  12/7/2019:  Exit System Control Pressed
17:34:18.7  12/7/2019:  Created DirectX BackGlass Window
17:34:18.7  12/7/2019:  Created DirectX DMD Window
17:34:19.0  12/7/2019:  Main display running full screen windowed.
17:34:19.3  12/7/2019:  Created DirectX BackGlass Window
17:34:19.3  12/7/2019:  Created DirectX DMD Window
17:34:19.6  12/7/2019:  Main display running full screen windowed.
17:35:20.9  12/7/2019:  Launch System
17:35:20.9  12/7/2019:  Hide DMD
17:35:20.9  12/7/2019:  Hide Backglass
17:35:20.9  12/7/2019:  Waiting for threads
17:35:20.9  12/7/2019:  Disposing display
17:35:21.0  12/7/2019:  Disposing display
17:35:21.3  12/7/2019:  Writing ScreenRes.txt
17:35:21.3  12/7/2019:  C:\Pinball\Visual Pinball\VPinballX.exe /play -"C:\Pinball\Visual Pinball\Tables\World Poker Tour.vpx"
17:35:21.3  12/7/2019:  C:\Pinball\PinballX\vpauto.exe
17:35:25.2  12/7/2019:  VPX Full screen exclusive mode detected
17:35:27.4  12/7/2019:  Writing ScreenRes.txt
17:35:27.4  12/7/2019:  C:\Pinball\Visual Pinball\VPinballX.exe /play -"C:\Pinball\Visual Pinball\Tables\Tron Legacy (Stern 2011).vpx"
17:35:27.5  12/7/2019:  C:\Pinball\PinballX\vpauto.exe
17:35:30.9  12/7/2019:  Found PinMAME ROM: wpt_140a.nv
17:35:33.1  12/7/2019:  VPX Full screen exclusive mode detected
17:35:37.1  12/7/2019:  Found PinMAME ROM: wpt_140a.nv
17:38:58.0  12/7/2019:  Exit System Control Pressed
17:38:58.1  12/7/2019:  Exit System Control Pressed
17:39:05.0  12/7/2019:  Created DirectX BackGlass Window
17:39:05.0  12/7/2019:  Created DirectX DMD Window
17:39:05.3  12/7/2019:  Main display running full screen windowed.
17:39:06.3  12/7/2019:  Created DirectX BackGlass Window
17:39:06.4  12/7/2019:  Created DirectX DMD Window
17:39:06.8  12/7/2019:  Main display running full screen windowed.
17:39:43.6  12/7/2019:  Launch System
17:39:43.6  12/7/2019:  Hide DMD
17:39:43.6  12/7/2019:  Hide Backglass
17:39:43.6  12/7/2019:  Waiting for threads
17:39:43.6  12/7/2019:  Disposing display
17:39:43.1  12/7/2019:  Writing ScreenRes.txt
17:39:43.1  12/7/2019:  C:\Pinball\Visual Pinball\VPinballX.exe /play -"C:\Pinball\Visual Pinball\Tables\World Poker Tour.vpx"
17:39:44.0  12/7/2019:  C:\Pinball\Visual Pinball\VPinballX.exe /play -"C:\Pinball\Visual Pinball\Tables\Back To The Future (Data East 1990) 1.4.vpx"
17:39:44.0  12/7/2019:  C:\Pinball\PinballX\vpauto.exe
17:39:44.1  12/7/2019:  C:\Pinball\PinballX\vpauto.exe
17:39:48.0  12/7/2019:  VPX Full screen exclusive mode detected
17:39:48.1  12/7/2019:  VPX Full screen exclusive mode detected
17:39:53.6  12/7/2019:  Found PinMAME ROM: wpt_140a.nv
17:40:09.8  12/7/2019:  Exit System Control Pressed
17:40:16.1  12/7/2019:  The process cannot access the file 'C:\Pinball\PinballX\Databases\Statistics.ini' because it is being used by another process.
17:40:16.1  12/7/2019:     at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
17:40:16.2  12/7/2019:     at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
17:40:16.2  12/7/2019:     at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize)
17:40:16.2  12/7/2019:     at PinballX.inireadernet.Flush()
17:40:16.2  12/7/2019:     at PinballX.FrmMain.x()
17:40:16.7  12/7/2019:  Created DirectX BackGlass Window
17:40:16.8  12/7/2019:  Created DirectX DMD Window
17:40:16.1  12/7/2019:  Main display running full screen windowed.
17:40:17.1  12/7/2019:  Created DirectX BackGlass Window
17:40:17.2  12/7/2019:  Created DirectX DMD Window
17:40:17.4  12/7/2019:  Main display running full screen windowed.
17:41:16.4  12/7/2019:  Launch System
17:41:16.5  12/7/2019:  Hide DMD
17:41:16.5  12/7/2019:  Hide Backglass
17:41:16.5  12/7/2019:  Waiting for threads
17:41:16.5  12/7/2019:  Disposing display
17:41:16.5  12/7/2019:  Launch System
17:41:16.8  12/7/2019:  Writing ScreenRes.txt
17:41:16.9  12/7/2019:  C:\Pinball\Visual Pinball\VPinballX.exe /play -"C:\Pinball\Visual Pinball\Tables\KISS 1979.vpx"
17:41:16.9  12/7/2019:  C:\Pinball\PinballX\vpauto.exe
17:41:16.1  12/7/2019:  Writing ScreenRes.txt
17:41:16.1  12/7/2019:  C:\Pinball\Visual Pinball\VPinballX.exe /play -"C:\Pinball\Visual Pinball\Tables\Guns and Roses.vpx"
17:41:17.0  12/7/2019:  C:\Pinball\PinballX\vpauto.exe
17:41:20.7  12/7/2019:  VPX Full screen exclusive mode detected
17:41:20.9  12/7/2019:  VPX Full screen exclusive mode detected
17:41:30.1  12/7/2019:  Found PinMAME ROM: gnr_300.nv
17:41:30.3  12/7/2019:  Found PinMAME ROM: gnr_300.nv
17:42:01.5  12/7/2019:  Exit System Control Pressed
17:42:07.7  12/7/2019:  Created DirectX BackGlass Window
17:42:07.8  12/7/2019:  Created DirectX DMD Window
17:42:08.1  12/7/2019:  Main display running full screen windowed.
17:42:08.3  12/7/2019:  Created DirectX BackGlass Window
17:42:08.3  12/7/2019:  Created DirectX DMD Window
17:42:08.6  12/7/2019:  Main display running full screen windowed.
17:44:49.0  12/7/2019:  Exiting
17:44:49.1  12/7/2019:  Showing Taskbar
17:44:49.1  12/7/2019:  Exiting
17:44:49.1  12/7/2019:  Unhiding Mouse Cursor
17:44:49.1  12/7/2019:  Waiting for Online Thread
17:44:49.1  12/7/2019:  Disposing Plugins
17:44:49.1  12/7/2019:  Saving Settings
17:44:49.2  12/7/2019:  Waiting for Online Thread
17:44:52.4  12/7/2019:  Bye
17:44:53.2  12/7/2019:  Bye
[Display]
Monitor=2
rotate=270
Windowed=False
windowwidth=812
windowheight=457
windowx=543
windowy=752
PlayFieldBrightness=230
WheelTextColor=ffffffff
InfoTextColor=ffffffff
InfoTextOutlineColor=ff000000
FilterTextColor=ffffffff
MenuColor=ffffa500
[BackGlass]
monitor=0
x=0
y=0
width=1360
height=768
AutoPositionB2S=True
[DMD]
monitor=1
x=0
y=0
width=1030
height=350
AutoPositionPinMAME=False
[FileSystem]
EnableFileMatching=True
[Interface]
UseTableLoadingMedia=True
GIFbackgroundcolor=ff000000
DesktopModeEnabled=False
EnableAdditionalDetail=True
ShowSystem=True
ShowRatings=True
[Audio]
StreamVolume=90
SampleVolume=90
PlaySoundInVideos=True
[Startup]
playsound=False
playvideo=False
StartWithWindows=Yes
[KeyCodes]
quit=27
left=37
right=39
select=13
rotate=82
pageleft=33
pageright=34
exitemulator=81
ingame=80
screenshot=83
capturevideos=86
instructions=73
volumedown=109
volumeup=107
credit=53
plunger=164
launch=50
[JoyCodes]
quit=3
left=0
right=5
select=2
rotate=
pageleft=6
pageright=7
exitemulator=3
ingame=
instructions=
launch=
Credit=1
Plunger=4
[Text]
All=All
PlayGameTwoPlayer=Two Player Game
Line1=Free Play
Line2=Press Start
Featuring=Featuring
Tables=Tables
PlayGame=Play Game
Instructions=Instructions
Information=Information
Flyer=Flyer
Gameplay=Gameplay
Tutorial=Tutorial
Promo=Promo
ExitGame=Exit Game
ReturnToGame=Return to Game
Return=Return
Exit=Exit
Shutdown=Shutdown
Favorite=Favorite
Favorites=Favorites
FavoritesAdd=Add To Favorites
FavoritesRemove=Remove From Favorites
MostPlayed=Most Played
LastPlayed=Last Played
Lists=Lists
CapturingVideos=Capturing videos. Please wait. This will take several minutes.
Ratings=Ratings
HighScores=High Scores
RateTable=Rate Table
NotRated=Not Rated
Systems=Systems
RecentlyAdded=Recently Added
[FuturePinball]
Enabled=False
WorkingPath=h:\-PINBALL-\-FUTURE PINBALL-
TablePath=h:\-PINBALL-\-FUTURE PINBALL-\Tables
Executable=Future Pinball.exe
LaunchBeforeEnabled=false
LaunchBeforeWorkingPath=
LaunchBeforeHideWindow=False
LaunchBeforeWaitForExit=True
LaunchAfterEnabled=False
LaunchAfterWorkingPath=
LaunchAfterHideWindow=False
LaunchAfterWaitForExit=True
MouseClickFocus=True
[VisualPinball]
WorkingPath=C:\Pinball\Visual Pinball
TablePath=C:\Pinball\Visual Pinball\Tables
Executable=VPinballX.exe
AutoConfigure=False
[ExitScreen]
EnableExit=True
EnableShutdown=True
[StartupProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=true
WaitForExit=false
[ExitProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=False
WaitForExit=
[AttractMode]
Timer=1
ShowFor=15
MuteAudio=False
[System_1]
Name=MAME
Enabled=False
TablePath=C:\
Executable=mamep64.exe
Parameters=[TABLEFILE]
SystemType=0
[AutoExit]
Enabled=False
Minutes=10
[Login]
[PinballFX2]
Enabled=False
Executable=steam.exe
Parameters=-applaunch 226980 [TABLEFILE]
Process=Pinball FX2.exe
Rotate=False
WaitFor=20
[PinballArcade]
Parameters=-applaunch 238260
Process=PinballArcade.exe
WaitForSelect=50
[GameListManager]
onlinemode=false
[RealDMD]
EnableColor=True
Color=ffff1414
[PinballFX3]
Parameters=-applaunch 442120 "-table_[TABLEFILE]"
Process=Pinball FX3.exe
Rotate=False
WaitFor=20
[Topper]
monitor=2
[VideoCapture]
KeysStartRecord=164|120
KeysEndRecord=164|120
Seconds=45
UseGPU=False
[Internal]
lastwheelcachematchsize=-1123
lastselected=Kiss (Bally 1979)KISS (Stern 2015)VisualPinball
filter_year=
filter_company=
filter_custom=
filter_favorites=False
filter_lastplayed=False
filter_mostplayed=False
filtername=Tables
filter_rating=0
filter_system=
filter_recentlyadded=False
[Plugin_1]
Enabled=False
Name=PlugInLED.dll
[Plugin_2]
Enabled=False
Name=PlugInSpeech.dll
[Plugin_3]
Enabled=False
[Plugin_4]
Enabled=False
Name=Xpadder Plugin.dll
[Apron]
monitor=8
[SetupWizard]
EmuPath1=C:\Emulation\Emulators
AssetPath1=C:\Emulation\Assets
ROMPath1=C:\Emulation\ROMs
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=Advanced
SavePosition=False
SearchText=
EmulatorIndex=0
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=0
NewsFeedsIndex=0
MappedDrivesIndex=0
SystemIndex=0
ShowPanel=True
FontSize=1
WindowSize=650, 478
WindowLocation=635, 281
WindowState=Maximized
CustomArray=
SearchArray=
SectionIndex=7
Next time please attach them. Much easier to search through the text for specific entries in a text editor than the forum page (and more forgiving on thumbs when viewing on a mobile device).  Thanks!
Do you have a double instance runnin of Pinballx? I see double entries in log and also when lsunching a vpx, i see 2 different vpx tables are launched
Works good when closing the Pinballx after auto start up and restarting Pinballx manually. Must be auto starting twice. Any sugestions how to sort that out?
Try disabling the start with windows option in pinballx (in settings.exe under startup settings) first, then reboot.
Let us know what happens, does pinballx still start on reboot, as a single instance, or not at all?
There is in the pinball folder also a program that will add pinballx to launch at start (or remove from start when run fir the 2nd time). Not sure exactly how to programbame is
ToggleStartWithWindows.exe in pinballx folder?.. i'm guessing that's called by settings.exe when you change the start with windows setting in pinballx settings.
@teezr2
It might be worth checking / posting your start up programs in windows for pinballx. Windows start -> settings -> apps -> startup
2 hours ago, teezr2 said:
Thanks folks. For some reason, Pinballx was in my startup apps twice.
Im so glad you figured it out. When I went to bed last night I was thinking, oh my god, what the hell did I screw up! lol.
  • Haha 1
:cheers: you never screw up things Tom. Its just us, the end users, who make a mess of your wonderful program B)
