when I exit PBX with ALt-F4 (I have the option disabled "exit to windows"in the menu, and via RDP I maintain my cab and exit PBX via alt-F4) it trows out 2 errors :
Nothing in the logfile (just exit correctly)
PinballX.iniFetching info... log.txtFetching info...
But I have  2 events in the eventlog :
Log Name:      Application
Source:        .NET Runtime
Date:          9/4/2019 6:04:36 PM
Event ID:      1026
Task Category: None
Level:         Error
Keywords:      Classic
User:          N/A
Computer:      Pinball
Description:
Application: AnyCPUPluginWrapperx86.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.MissingMemberException
   at Module1.Main(System.String[])
Source:        Application Error
Event ID:      1000
Task Category: (100)
Level:         Error
Keywords:      Classic
User:          N/A
Computer:      Pinball
Description:
Faulting application name: AnyCPUPluginWrapperx86.exe, version: 1.0.7185.39483, time stamp: 0x5d6ed367
Faulting module name: KERNELBASE.dll, version: 10.0.17763.652, time stamp: 0x57e2061a
Exception code: 0xe0434352
Fault offset: 0x0011fd82
Faulting process id: 0x720
Faulting application start time: 0x01d5633a67d336d8
Faulting application path: C:\Pinball\PinballX\AnyCPUPluginWrapperx86.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report Id: b17fee3b-f7bf-4cce-a1a1-be77e28f39de
Faulting package full name:
Faulting package-relative application ID:
Why is AnyCPUPluginWrapperx32.exe is used in the 64 bit version ? Should it not be AnyCPUPluginWrapperx64.exe ?
EDIT 2:
Tested : Renamed AnyCPUPluginWrapperx64.exe to AnyCPUPluginWrapperx32.exe and the error is gone ..
EDIT 3:
After renaming the exe I don't have the exit error, but DOF plugin won't launch ...
Yup . No error on closing with 3.63. Only ... The Teensy led's  (Matrix and strips) , just stop and the leds that where on at the moment of exiting the programs, stays on, until PBS starts again
It doesn't get a clear-reset after closing ...
  On 9/5/2019 at 7:42 AM, Tom Speirs said:
What plugin is that with? I guess its because its missing the app_exit event as per this topic.
It's the DirectOutput PinballX Plugin.dll that is using it.
I got another error with PBX 3.63 (Sorry tom). Not sure if I need to open a new post for it
When I Go to list All TAbles, PBX is hunging and crashing
It looks like the resolution is changes (in the font of the system list getting smaller)
this is in the logfile as last entry
09:58:22.2  9/5/2019:  PlugIn caused an exception and is being disabled.
[SETTINGS].logFetching info... XDMDlog.txtFetching info... log.txtFetching info...
here's my INI file
Also have the Dof log (must post it as ZIP, only have 7.8 MB max to post :( ):
PinballX DirectOutput Plugin.zipFetching info...
Edited by Mike_da_Spike
added DOF log
Also stopped with the same error if I go to other menu options.
From the systems menu I selected my "Visual Pinball X", it loads and shows the table, but hungs after the wheel was hunging.
EDIT:
I revert back to 3.62, because hard to select tables for me now :(
Hmmm .. having the same issue on 3.62 too
What happens if you disable that plugin or go to 32bit Mike - i guess it'll work
V3.62x64 seems to work on my desktop without that plugin (i just don't have any games installed, just demo media)
Edit - tried v3.63x64 on desktop, menu looks ok too
EDIT:
If you didn't have the issue before, I suggest a reboot.
I booted multiple times.
I tried all versions from 3.63 to the latest I used . And only 3.59 is working fine for me. Rest is all hunging
Will try 3.64 now (Awesome support Tom ! I need such developers at my work !)
Your welcome. Its nice to have some decent users to test for a change. Im going to update your member status to Contributor by the way.
I don't see plugins getting disabled. I have 2 plugins enabled (DOF and Scutters PBXLoadingVideo's) and both keep enabled. But only testing for 30 minutes ...
Will do.
Something completely different, but my passion wiil be pinball.
Must have the key somewhere in my email
