Hello,
I have had a Mame32 Arcade for years.  I recently lost the hard drive and am now setting it back up and I thought I would give Gameex a try.  I am having difficulty getting it to set up.  Despite registering I still get the nag screen, and I dont seem to have the setup configured correctly o point at my roms, it says no games found.  I searched and couldnt find any quick setup guides and the video on youtube is an older version that doesnt function the same.  Any help would be appreciated.
Hey,
First things first. Did you get the registration email? This would have your key.
If not please get in touch with me privately and Ill make sure you get it.
As for support issues, please post your log file (from the log folder) and GameexEx.ini file (from the data folder).
Thanks.
Tom.
Which YouTube sources did you check?  Did you check Austin's?  It's a few years old, but the same basic principals should apply and it offers some good insight.
Tom, I did get the email and I am sorry but I assumed when I put the username and password in the setup that would register it.  I have now applied the registry patch file from the email and the "nag screen" is gone.  Thank you.  I did watch Austin's video and I am still having issues.  I believe the root of my problems is that my install is not on my boot "C" drive.  My Mame and other files are all on a storage drive.  A number of the install folders the program is looking for like snap, flyers and cabinets are not in the path, and are not created.  I am working thru it and have at least got it up and running at this point.  I may need some guidance to get all the paths sorted out etc. I will keep posted.  Thank you for the reply.
One step forward and then I am  back... I am attaching my  log file, the other file GameexEx.ini is not present.   I have gotten the program to run but when I go into Mame in the program it says no games found, but under all games they are there and seem to launch fine.  My other issue is the controller .cfg.  I have a HotRod controller, and the .cfg is in the Mame64 Ctrlr folder, in my old setup using Mame32 I could just set the HotRod controller from within Mame and apply to all games, but this version does not support that.  Do I configure that within Ganmeex or via a command line \switch?
Thank you for your help.
Spoiler
GameEx.ini
[gameexonline]
streamquality=6
Privacy=1
EnableBackground=True
[general]
Xresolution=800
Yresolution=600
ResolutionRefreshRate=60
DisplayOnSecondary=False
MAMEPath=E:\Program Files (x86)\Mame20764bit
MAMEEXE=mame64.exe
ROMPath=E:\Program Files (x86)\Mame20764bit\roms
StartWait=False
USeAdvanceMame=False
AdvanceMAMEEXE=advmame.exe
AdvanceMAMEPATH=C:\Emulators\AdvanceMAME
ADVANCEMAMEOptions=-device_video_output fullscreen -quiet -dir_rom "C:\Emulators\Mame32\roms"
UseZinc=False
ZincEXE=zinc.exe
ZincPATH=C:\Emulators\ZiNc
ZincOptions=--renderer=.\renderer.znc
Font=Trebuchet MS
TitleText=MAME Games
OnlyWorking=True
AllowImperfect=True
VerifyRoms=True
OnlyRoms=False
NoGameInfo=False
GameFilter=Japan;Korea;Asia;Hispanic;Bootleg;French;German;Hack;Prototype;Hardware;Spanish;(Easy;(harder
GameFilterOn=False
NoAdult=False
NoClones=False
MameOptions=-nowindow -joy -skip_gameinfo
ArcadeMode=False
UseLargeFonts=True
SnapPath=E:\Emulators\Mame32\snap
AVISnapPath=E:\Emulators\Mame32\avisnap
AVIFrameSkip=0
flyerpath=E:\Emulators\Mame32\flyers
cabinetpath=E:\Emulators\Mame32\cabinets
CatverLocation=\DATA\catver.ini
nplayerslocation=\DATA\nplayers.ini
HistoryLocation=\DATA\history.dat
InfoLocation=\DATA\mameinfo.dat
CommandLocation=\DATA\command.dat
ShowGameInfoPage=True
EnableStartPage=True
ShowStartPageFirst=True
skipintro=False
AntiAliasFonts=True
OutlineFonts=False
DisplayBackgroundImage=True
SnapBrightness=120
MusicPlayList=
MusicVolume=100
MediaCenterMode=2
PlayIntroSound=True
AttractModeTimer=4
AttractModeAudio=4
UsingArcadeVGA=False
StretchResToX=640
StretchResToY=288
TryToStretchto256=False
NoWaitVSync=false
Sleep=True
HideUpdateList=False
DisableExit=False
HideShutDown=False
StartUpVideo=C:\Video
LaunchOnStart=
LaunchOnStartNoWait=
LaunchOnExit=
LaunchOnExitNoWait=
FontSize=0
VectorResX=632
VectorResY=264
AlwaysStretch=410x256
DisableEscape=False
DisableRemoveGame=False
theme=Default - Default
Language=English
flatstartpage=False
DontSwitchRes=True
SnapDelay=7
AllowWindowResize=True
ShowLoadingScreen=True
Use16BitColour=False
Widescreen=False
DisableMAME=False
ShellBeforeLaunch=
ShellOnExit=
EnableJukeBox=True
jukeboxplaylist=Live! (CD1)
EnableMediaControls=True
ShufflePlayLists=True
LoadPlayListAtStartup=False
LoadPlayListThread=False
DownloadArt=True
TitleFont=Trebuchet MS
DialogTextWhite=False
TimeFormat=True
HideToolBar=3
DoNotFilterROMS=pacman;splatter
MAMEAudioMode=1
DisplayTitle=True
AVIAudio=True
MarqueePath=E:\Emulators\Mame32\marquees
PanelPath=G:\Dropbox\Mame32\cpanel
TitlePath=E:\Emulators\Mame32\titles
ICONPath=E:\Emulators\Mame32\icons
CPEnabled=True
CPPATH=\DATA\controls.ini
ShowVector=True
ShowNeoGeo=True
ShowOriginal=True
ShowAdult=True
ShowCPS=True
ShowVertical=True
ShowHorizontal=True
EnableFavorites=True
ShowMulti=False
ShowAllMAME=True
ShowLastGame=True
ShowRandomGame=True
ShowListNumbers=True
AlphaBlendVideos=True
EnableSound=True
MediaCenterOpenCheck=true
UseSharp=True
CreateImageOnThread=False
HideCreateSnaps=False
HideLogoff=False
HideStandBy=False
DisableMouse=False
ShowVideos=True
VideoPath=\\nasusa\VIDEO;\\Nasusa\video\- BOND -;\\nasusa\video\-  MINT  -\- MOVIES -;\\Nasusa\video\- BOND -;\\NASUK\video;\\NASUK\dvd
EnableAlphaPage=True
EnableJoystick=True
EnableSlikStik=False
KeyboardDirectInput=False
NoMahjong=False
VIDEOFFDSHOW=0
JoystickDevice=
EnableCustomInput=False
EnableCustomJoyInput=False
AttractVideosEnabled=True
AttractVideosRatio=-1
AttractVideosPath=F:\- GAMESDBASE -\Arcade\Video_MP4_HI_QUAL
AtractModeNewGameTimer=2
AdvancedGFX=True
HideZinc=False
TransitionType=0
Bypass=True
DontBlitWait=False
ShowMostPlayed=True
excludedmameroms=
DeadZoneX=0
DeadZoneY=0
jukeboxmode=1
enableambiance=False
HIDEDESKTOP=False
UseSnapBestMatch=true
IngameVK=121|122
EnableThemePicker=True
DisablePleaseWaitAnimation=False
EnableRipCD=True
DumbyValue=
DVDPath=G:\
AttractOnlyFavs=False
rotateplus90=False
ShowButtons=True
DisplayTitleText=True
PlayExitSaverSound=False
ShowAtari=True
ShowGolden=True
ShowHorizVert=0
UseModel2=False
Model2PATH=C:\Emulators\Model2
ShowModel2=True
ShowLightGun=True
EnableBezel=True
autoupdate=1
NoMAMEOnStartPage=True
HideRestart=False
EnableStartScreenSaver=True
SortMAMEThE=True
SortEmuThE=True
ShowMCEEXport=True
NoRotationRestrictions=False
MakeToolbarTextWhite=False
ExitGameAfter=0
ShowTrackball=True
ShowSpinner=True
LoadEmusOnThread=True
LoadRadioOnThread=False
StartPageAni=True
EmusAttractMode=False
MuteEmuAttractMode=False
Show4Player=True
CabControlFriendly=False
ManualPath=E:\Emulators\Mame32\manuals
HideShowTaskbar=True
CustomMAMEFolderPath=E:\Emulators\Mame32\CustomFolders
MAMEFavoritesini=E:\Emulators\Mame32\Folders\Favorites.ini
MenuFontSameSize=False
PreviewVideos=2
ShowStatistics=True
DisableMouseWheel=False
ErrorReporting=0
ReduceCPU=True
ShowNotPlayed=True
ShowOnlineLists=True
ScreensaverMode=0
AttractText=Press anything to start...
GlaunchEnabled=False
PCBPath=C:\Emulators\Mame32\pcb
ArtworkPath=C:\Emulators\Mame32\artworkpreview
LoadJukeTracksOnStartup=True
EnableLetterSelect=True
JukeQueueMode=0
EnableBezelAttract=True
ForceDailyReboot=-1
EnableSearch=True
FixToEmuList=0
ShowLastPlayed=True
TwoThreeRes=
EnableTouchScreen=True
EnableMediaCheck=True
EnableOtherSystems=True
ForceShutdown=False
EnableHiScore=True
DisplayImageList=False
SortEmulators=True
ShowAllGames=True
InactivityTimer=0
EnableAdvCustomInput=False
HideHibernate=False
EnableKeyboardShutdown=False
AutoRotateMAME=False
EnableLaunchDialog=True
lastmusicpath=C:\Users\ThomasSpeirs\Music
looplist=False
TrackballSupport=True
EnableVisualizations=True
EnableVideoThumbs=False
cabinet3dpath=E:\Emulators\Mame32\cabinets3d
EnableClientServerMAME=False
ClientServerMAMEPath=C:\Emulators\ClientServerMAME
ClientServerMAMEEXE=vmame.exe
OnQueueEndMode=0
MAMERemoveDupes=0
CommnadLocation=\DATA\command.dat
AutoDownloadDescriptions=True
GameExtenderCustomImageMAMEPath=E:\Emulators\Mame32\marquees
Enablepopupdescriptions=True
SetPalRes=False
PalRes=800x600x32x60
SetNTCSRes=True
NTSCRes=800x600x32x60
SetNTSCRes=False
SetTwoThreeRes=False
AmbianceFolder=E:\Program Files (x86)\Mame Gameex Arcade
EnableEscapeKeyExit=True
DisableChangeView=False
EnabledConfigurationApp=True
resumelastatstartup=False
HelpText=
ShowHistoryAndMAMEInfo=False
baksnappath=C:\Emulators\Mame32\backgroundsnap
TVVideoPath=
OtherVideoPath=C:\Video;[myvideos];\\NASUK\bluray
ChangeMonitorFrequency=False
ChangeMonitorResolution=False
NoCasino=False
EnableDownloadService=True
ShowCHD=True
Databasesnappath=G:\Mame32\DatabasSnap
ArcadeMonitorType=0
EnableHighestRated=True
SeekPreviewVideo=0
Logopath=E:\Emulators\Mame32\logos
MAMEVideoThemePath=E:\Emulators\Mame32\themevideos
UseModel3=False
Model3PATH=C:\Emulators\Model3
Model3Options=-fullscreen -res=1920,1080
ShowModel3=True
MAMEDefaultVideoThemePath=E:\Emulators\Mame32\defaultthemevideos
UseAAE=False
AAEPATH=C:\Emulators\AAE
[daphne]
UseDaphne=False
DaphnePath=C:\Emulators\Daphne
DaphneExe=Daphne.exe
DaphneSnap=C:\Emulators\Daphne\images
DaphneOptions=vldp -fullscreen -x 640 -y 480 -nohwaccel
Enabled_1=True
ROMName_1=astron
GameName_1=Astron Belt
GameOptions_1=-framefile "R:\ARCADE\Daphne\vldp\astron\astron.txt"
Enabled_2=True
ROMName_2=badlands
GameName_2=Badlands
GameOptions_2=-framefile "R:\ARCADE\Daphne\vldp\badlands\badlands.txt"
Enabled_3=True
ROMName_3=bega
GameName_3=Bega's Battle
GameOptions_3=-framefile "R:\ARCADE\Daphne\vldp\bega\bega.txt"
Enabled_4=True
ROMName_4=cliff
GameName_4=Cliff Hanger
GameOptions_4=-framefile "R:\ARCADE\Daphne\vldp\cliff\cliff.txt"
Enabled_5=True
ROMName_5=cobraab
GameName_5=Cobra Command
GameOptions_5=-framefile "R:\ARCADE\Daphne\vldp\cobra\cobra.txt
Enabled_6=True
ROMName_6=lair
GameName_6=Dragon's Lair
GameOptions_6=-framefile "R:\ARCADE\Daphne\lair_HD\lair_hd.txt"
Enabled_7=True
ROMName_7=lair2
GameName_7=Dragon's Lair II Timewarp
GameOptions_7=-framefile "R:\ARCADE\Daphne\vldp\lair2\lair2.txt"
Enabled_8=True
ROMName_8=esh
GameName_8=Esh's Aurunmilla
GameOptions_8=-framefile "R:\ARCADE\Daphne\vldp\esh\esh.txt"
Enabled_9=False
ROMName_9=firefox
GameName_9=Firefox
GameOptions_9=-framefile "R:\ARCADE\Daphne\vldp\FireFox\firefox.txt"
Enabled_10=True
ROMName_10=ffr
GameName_10=Freedom Fighter
GameOptions_10=-framefile "C:\Roms\Laserdisc\Freedom Fighter\ffr.txt"
Enabled_11=True
ROMName_11=galaxy
GameName_11=Galaxy Ranger
GameOptions_11=-framefile "R:\ARCADE\Daphne\vldp\galaxyr\galaxyr.txt"
Enabled_12=False
ROMName_12=gtg
GameName_12=Goal to Go
GameOptions_12=-framefile "C:\Roms\Laserdisc\Goal to Go\gtg.txt"
Enabled_13=True
ROMName_13=interstellar
GameName_13=Interstellar
GameOptions_13=-framefile "R:\ARCADE\Daphne\vldp\interstellar\interstellar.txt"
Enabled_14=True
ROMName_14=gpworld
GameName_14=GP World
GameOptions_14=-framefile "R:\ARCADE\Daphne\vldp\gpworld\gpworld.txt"
Enabled_15=True
ROMName_15=mach3
GameName_15=Mach 3
GameOptions_15=-framefile "R:\ARCADE\Daphne\vldp\mach3\mach3.txt"
Enabled_16=True
ROMName_16=roadblaster
GameName_16=Road Blaster
GameOptions_16=-framefile "R:\ARCADE\Daphne\vldp\rb\rb.txt"
Enabled_17=True
ROMName_17=ace
GameName_17=Space Ace
GameOptions_17=-framefile "R:\ARCADE\Daphne\Space Ace HD\ace_hd.txt"
Enabled_18=True
ROMName_18=sdq
GameName_18=Super Don Quix-ote
GameOptions_18=-framefile "R:\ARCADE\Daphne\vldp\sdq\sdq.txt"
Enabled_19=False
ROMName_19=tq
GameName_19=Thayer's Quest
GameOptions_19=-framefile "R:\ARCADE\Daphne\vldp\tq\tq.txt"
Enabled_20=True
ROMName_20=uvt
GameName_20=Us vs Them
GameOptions_20=-framefile "R:\ARCADE\Daphne\vldp\uvt\uvt.txt"
UseGamepad=False
DaphneFlyer=C:\Emulators\Daphne\flyers
DaphneCabinet=C:\Emulators\Daphne\cabinets
DaphneTitle=C:\Emulators\Daphne\titles
DaphneMarquee=C:\Emulators\Daphne\marquees
DaphnePanel=C:\Emulators\Daphne\cpanel
LaunchBefore=
LaunchAfter=
DaphneCustomGameExtenderCustomArtPath=C:\Emulators\Daphne\marquees
DaphneBakSNAP=C:\Emulators\Daphne\backgroundimages
DaphneLogo=C:\Emulators\Daphne\logos
DaphneVideoThemePath=C:\Emulators\Daphne\videothemes
DaphneDefaultVideoThemePath=C:\Emulators\Daphne\defaultvideothemes
[dvd]
EnableDVD=True
CODEC=0
DVDFFDSHOW=0
EnableDVDDisk=True
DVDPath=\\NASUK\dvd
UseVMR9=True
EnableExternalPlayer=False
Use VMR9=False
CMD=""C:\Program Files (x86)\Corel\DVD9\WinDVD.exe" "[dvd]""
[pictures]
PicturesEnabled=True
Paths=C:\Pictures;[mypictures]
UseAlphaBlend=True
SlideDuration=12
[news]
URL_1=http://rss.news.yahoo.com/rss/topstories
URL_2=
URL_3=http://rss.news.yahoo.com/rss/tech
URL_4=http://slashdot.org/index.rss
URL_5=
URL_6=http://www.emulator-zone.com/rss_news.php
URL_7=http://www.spesoft.com/news.xml
URL_8=http://www.gameex.info/forums/index.php?app=core&module=global&section=rss&type=forums&id=1
URL_9=http://www.hulu.com/feed/highest_rated/videos
URL_10=http://www.hulu.com/feed/popular/videos/this_week
URL_11=http://www.hulu.com/feed/recent/movies
URL_12=
URL_13=
URL_14=
URL_15=
URL_16=
URL_17=
URL_18=
URL_19=
URL_20=
URL_21=
URL_22=
URL_23=
URL_24=
URL_25=
URL_26=
URL_27=
URL_28=
URL_29=
URL_30=
URL_31=
URL_32=
URL_33=
URL_34=
URL_35=
URL_36=
[radio]
RadioEnabled=True
Enabled_5=True
Name_5=Kohina - old school game & demo
URL_5=http://acamar.org:8000/listen.pls
Enabled_6=False
Name_6=Bangkok Radio
URL_6=http://64.62.253.55/bangkok64
Enabled_7=True
Name_7=Kohina - Fresh Tracks
URL_7=http://anka.org:8080/fresh.ogg.m3u
Enabled_4=False
Name_4=Delta Uno
URL_4=http://www.deltauno.it/home/delta1.asx
Enabled_1=False
Name_1=
URL_1=
Enabled_2=
Name_2=
URL_2=
Enabled_3=
Name_3=
URL_3=
Enabled_8=
Name_8=
URL_8=
Enabled_9=
Name_9=
URL_9=
Enabled_10=
Name_10=
URL_10=
Enabled_11=
Name_11=
URL_11=
Enabled_12=
Name_12=
URL_12=
Enabled_13=
Name_13=
URL_13=
Enabled_14=
Name_14=
URL_14=
Enabled_15=
Name_15=
URL_15=
Enabled_16=
Name_16=
URL_16=
Enabled_17=
Name_17=
URL_17=
Enabled_18=
Name_18=
URL_18=
Enabled_19=
Name_19=
URL_19=
Enabled_20=
Name_20=
URL_20=
Enabled_21=False
Name_21=Capital Gold
URL_21=mms://ms1.capitalinteractive.co.uk/gold_high
Enabled_22=True
Name_22=Slay Radio
URL_22=
Name_23=XFM
URL_23=http://rope.icgo.fimc.net/staticweb/onair_players/onair_xfm_abacast/player/onair_xfm.asx
Enabled_23=False
Name_24=Radio Woodstock
URL_24=http://nick8.surfernetwork.com/Media/RWST.asx
Enabled_25=True
Name_25=Club 977 Alternative
URL_25=http://www.977alt.com/977alt.asx
Enabled_26=True
Name_26=Radio Paradise
URL_26=http://www.changeip.com/radio/rp_128.asx
Enabled_27=True
Name_27=Hitz Radio
URL_27=http://www.hitzradio.com/hitzradio.asx
Enabled_28=True
Name_28=Club 977
URL_28=http://www.club977.com/club977.asx
Enabled_29=True
Name_29=9412 Rock Station
URL_29=http://www.9412.com/9412.asx
Enabled_30=True
Name_30=Power Hitz
URL_30=http://www.powerhitz.com/powerhitz.asx
Enabled_31=True
Name_31=Radio Wazee
URL_31=http://www.wazee.org/128.asx
Enabled_32=True
Name_32=The Edge Radio
URL_32=http://mfkrboard.com/edgeradio/edge.m3u
Enabled_33=True
Name_33=WFUV 90.7 FM Public Radio
URL_33=http://www.wfuv.org/wfuvlive.asx
Enabled_34=False
Name_34=Pirate Radio
URL_34=http://www.loudcity.net/Portals/0/LCPlayLists/90/123.asx
Enabled_35=True
Name_35=EYE 97
URL_35=http://www.loudcity.net/Portals/0/LCPlayLists/157/eye97.asx
Enabled_36=True
Name_36=Hit Music Station
URL_36=http://www.hitmusicstation.net/ecoute_haut_debit.m3u
Name_37=Radio IO 80's
URL_37=http://radioio.sc.llnwd.net:8240
Enabled_24=
Enabled_37=False
Enabled_80=True
Url_80=FAVREMOVE
Enabled_81=True
Url_81=FAVREMOVE
Enabled_82=True
Url_82=FAVREMOVE
Enabled_83=True
Url_83=FAVREMOVE
enabled_84=True
name_84=radioio.com : 80s New Wave
url_84=http://www.shoutcast.com/sbin/shoutcast-playlist.pls?rn=1269943&file=filename.pls
Enabled_85=
Name_85=
Url_85=
Enabled_38=True
Name_38=C64.COM's SID Stream
URL_38=http://www.c64.com/sid.m3u
[htmlapplications]
enabled_1=False
URL_1=http://10foot.cbuenger.com/mceWeather/index.php?start=1&lang=2
Name_1=Weather
Logo_1=Weather
MouseEmu_1=False
Enabled_2=True
URL_2=https://online.gameex.com
Name_2=GameEx Online
Logo_2=
MouseEmu_2=False
Enabled_3=False
URL_3=http://10foot.cbuenger.com/mceWeather/index.php?start=1&lang=2
Name_3=Weather
Logo_3=Weather
MouseEmu_3=True
Enabled_4=False
URL_4=
Name_4=
Logo_4=
MouseEmu_4=True
Enabled_5=False
URL_5=
Name_5=
Logo_5=
MouseEmu_5=True
Enabled_6=False
URL_6=
Name_6=
Logo_6=
MouseEmu_6=True
UseHTMLApps=True
Hide_2=False
Hide_3=
Hide_4=True
Hide_5=
[externalapplications]
Enabled_99=True
Name_99=Configuration
Path_99=[apppath]
CMD_99=GameExConfig.exe
Snap_99=GameExText
ShowDesktop_99=True
MapKeys_99=False
WaitBeforeKeys_99=
SendKeys_99=
Enabled_2=False
Name_2=Notepad
Path_2=c:\windows
CMD_2=notepad.exe
Snap_2=GameExText
ShowDesktop_2=True
MapKeys_2=True
WaitBeforeKeys_2=
SendKeys_2=
Enabled_3=False
Name_3=Mad Dog McCree
Path_3=G:\Mad_Dog_mcCree
CMD_3=G:\Mad_Dog_mcCree\mdm.exe
Snap_3=GameExText
ShowDesktop_3=True
MapKeys_3=True
WaitBeforeKeys_3=4000
SendKeys_3=F
Enabled_1=False
name_1=Close And Restart GameEx
path_1=G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin
cmd_1=CloseAndRestartGameEx.bat
snap_1=
showdesktop_1=True
mapkeys_1=True
WaitBeforeKeys_1=d
SendKeys_1=
Enabled_4=False
name_4=
path_4=
cmd_4=
snap_4=
showdesktop_4=True
mapkeys_4=True
WaitBeforeKeys_4=
SendKeys_4=
Enabled_5=False
name_5=
path_5=
cmd_5=
snap_5=
showdesktop_5=True
mapkeys_5=True
WaitBeforeKeys_5=
SendKeys_5=
Enabled_6=False
name_6=
path_6=
cmd_6=
snap_6=
showdesktop_6=True
mapkeys_6=True
WaitBeforeKeys_6=
SendKeys_6=
Enabled_7=False
name_7=
path_7=
cmd_7=
snap_7=
showdesktop_7=True
mapkeys_7=True
WaitBeforeKeys_7=
SendKeys_7=
Enabled_8=False
name_8=
path_8=
cmd_8=
snap_8=
showdesktop_8=True
mapkeys_8=True
WaitBeforeKeys_8=
SendKeys_8=
Enabled_9=False
name_9=
path_9=
cmd_9=
snap_9=
showdesktop_9=True
mapkeys_9=True
WaitBeforeKeys_9=
SendKeys_9=
Enabled_10=False
name_10=
path_10=
cmd_10=
snap_10=
showdesktop_10=True
mapkeys_10=True
WaitBeforeKeys_10=
SendKeys_10=
Enabled_11=False
name_11=
path_11=
cmd_11=
snap_11=
showdesktop_11=True
mapkeys_11=True
WaitBeforeKeys_11=
SendKeys_11=
Enabled_12=False
name_12=
path_12=
cmd_12=
snap_12=
showdesktop_12=True
mapkeys_12=True
WaitBeforeKeys_12=
SendKeys_12=
Enabled_13=False
name_13=
path_13=
cmd_13=
snap_13=
showdesktop_13=True
mapkeys_13=True
WaitBeforeKeys_13=
SendKeys_13=
Enabled_14=False
name_14=
path_14=
cmd_14=
snap_14=
showdesktop_14=True
mapkeys_14=True
WaitBeforeKeys_14=
SendKeys_14=
Enabled_15=False
name_15=
path_15=
cmd_15=
snap_15=
showdesktop_15=True
mapkeys_15=True
WaitBeforeKeys_15=
SendKeys_15=
Enabled_16=False
name_16=
path_16=
cmd_16=
snap_16=
showdesktop_16=True
mapkeys_16=True
WaitBeforeKeys_16=
SendKeys_16=
Enabled_17=
name_17=
path_17=
cmd_17=
snap_17=
showdesktop_17=
mapkeys_17=
WaitBeforeKeys_17=
SendKeys_17=
Enabled_18=
name_18=
path_18=
cmd_18=
snap_18=
showdesktop_18=
mapkeys_18=
WaitBeforeKeys_18=
SendKeys_18=
Enabled_19=
name_19=
path_19=
cmd_19=
snap_19=
showdesktop_19=
mapkeys_19=
WaitBeforeKeys_19=
SendKeys_19=
Enabled_20=
name_20=
path_20=
cmd_20=
snap_20=
showdesktop_20=
mapkeys_20=
WaitBeforeKeys_20=
SendKeys_20=
Enabled_21=
name_21=
path_21=
cmd_21=
snap_21=
showdesktop_21=
mapkeys_21=
WaitBeforeKeys_21=
SendKeys_21=
Enabled_22=
name_22=
path_22=
cmd_22=
snap_22=
showdesktop_22=
mapkeys_22=
WaitBeforeKeys_22=
SendKeys_22=
Enabled_24=
name_24=
path_24=
cmd_24=
snap_24=
showdesktop_24=
mapkeys_24=
WaitBeforeKeys_24=
SendKeys_24=
Enabled_25=
name_25=
path_25=
cmd_25=
snap_25=
showdesktop_25=
mapkeys_25=
WaitBeforeKeys_25=
SendKeys_25=
EmulateMouse_1=-1
EmulateMouse_2=-1
EmulateMouse_3=3
EmulateMouse_4=
EmulateMouse_5=
EmulateMouse_6=
EmulateMouse_7=
EmulateMouse_8=
EmulateMouse_9=
EmulateMouse_10=
EmulateMouse_11=
EmulateMouse_12=
EmulateMouse_13=
EmulateMouse_14=
EmulateMouse_15=
EmulateMouse_16=
EmulateMouse_17=
EmulateMouse_18=
EmulateMouse_19=
EmulateMouse_20=
EmulateMouse_21=
EmulateMouse_22=
EmulateMouse_24=
EmulateMouse_25=-1
LaunchBefore_16=
LaunchAfter_16=
AlsoLaunch_16=
LaunchBefore_17=
LaunchAfter_17=
LaunchBefore_1=
HelpText_1=
[text]
mameCHDlist=CHD
mameCHDstart=CHD Games
steamlist=Steam
steamstart=Steam Games
uplaylist=Uplay
uplaystart=Uplay Games
originlist=Origin
originstart=Origin Games
banner=Banner
Downloading=Downloading
Seeking=Seeking
Download=Download
PlayBluRay=Play Blu Ray
GetMetaData=Get MetaData
Touch_Help_1=Control is located at bottom of screen.
Touch_Help_2=Continuously tap bottom right for credits and top right to start.
Touch_Help_3=Controls are located bottom and middle of screen.
Touch_Help_4=Control is located at bottom of screen.
GameExArcadeStart=Arcade
GameExArcadeList=Arcade
RipDVD=Rip DVD
SearchMusic=Search Music
Dialog_RippingCD=Ripping CD
Dialog_PleaseWait=Please Wait
Dialog_ScanningFolders=Scanning Folders
Dialog_ScanningFiles=Scanning Files
Dialog_LoadingDatabases=Loading Databases
Dialog_LoadingSettings=Loading Settings
Status_ListUpdated=List Updated
Status_FavRemoved=Removed from favorites
Status_FavAdded=Added to favorites
Status_ItemRemoved=Item removed
Status_NextTrack=Next track
Status_PreviousTrack=Previous track
Status_Pause=Pause
Status_play=Play
Status_AddedToQ=Added to queue
Status_NetPlayReq=Requested NetPlay
Status_NetPlayCan=Cancelled NetPlay
YouTube=YouTube
News=News
SearchYouTube=Search YouTube
RequestNetPlay=Request NetPlay
CancelNetPlay=Cancel NetPlay Request
MAMENetPlayStart=NetPlay
NetPlayList=NetPlay
Accept=Accept
Now=Now
Next=Next
GameMusic=Game Music
TVAdvert=TV Advert
Commands=Commands
RecordVideo=Record Video
ResumeGame=Resume Game
ExitGame=Exit Game
InGame=In Game
Stopped=Stopped
Play=Play
ResumeDVD=Resume DVD
NoItems=- NO ITEMS FOUND -
Hibernate=Hibernate
MenuMore=More
AllGamesStart=All Games
AllGamesList=All Games
NotAvailable=Not Available
HiScore=High Score
GetLyrics=Get Lyrics
OtherSystems=Other Systems
OpenMedia=Open Media
Biography=Biography
MenuView=Change View
MenuBack=Back
MenuExit=Exit
MenuHome=Home
LastPlayedList=Last Played
LastPlayedStart=Last Played
SEARCHTITLE=Enter criteria then select menu
SEARCHTITLE2=Press select to release cursor
SearchList=Search
SearchStart=Search
SearchMedia=Search Media
SearchJukebox=Search Jukebox
Items=Items
MediaPlayerStart=Library
MediaPlayerList=Library
NoMediaFound=- NO MEDIA FOUND -
eBookViewerStart=eBooks
eBookViewerList=eBooks
Artwork=Artwork
PCB=PCB
Statistics=Statistics
InsertCD=Insert CD:
SearchGames=Search Games
GameManual=Manual
PlayStation=Playstation
mame2simlist=2 Players
mame2simstart=2 Player Simultaneous
mame4simlist=4 Players
mame4simstart=4 Player Simultaneous
MCEEXPORT=Export To MCE
StartScreenSaver=Start Screensaver
Visualize=Visualize
SelectVisualize=Select Visualization
About1=Windows Emulator Front End and HTPC
About2=Written By:
About3=For Latest Version, please visit:
byalbum=By Album
byartistalbum=By Artist/Album
byartist=By Artist
bycat=By Category
bygenre=By Genre
bymanu=By Manufacturer
bysys=By System
byname=By Name
bytitle=By Title
byyear=By Year
Selectplaylist=Play list / More
createsnaps=Create Snaps
CreateSnaps1A=You are about to create snap shots or videos for every game in the [EMULATOR] Games List. This option can be removed from GameEx, by enabling the Hide Create Snaps option in the configuration.
CreateSnaps2=You should be aware this is a lengthy process
CreateSnaps3=With your current settings it is estimated that it will take at least:
CreateSnaps4=[MINUTES] Minutes to complete this process if you use a 20 second pause between snaps.
CreateSnaps5=You should also be warned that the SNAP shots will be saved in the SNAP Path defined for this emulator
CreateSnaps6=This process is not recommended on Windows 98
CreateSnaps7=To exit this process once run HOLD down ESCAPE.
CreateSnaps8=Do you want to proceed?
Exit=Exit GameEx
HTMLPleaseWait=Please Wait
IsUpdatingList=GameEx is updating the MAME game list:
jukelist=Jukebox
jukestart=Jukebox
Karaokelist=Karaoke
Karaokestart=Karaoke
StartKaraoke=Start Karaoke Player
LaaunchingGame=Launching:
laserlist=Laserdisc
laserstart=Laserdisc Games
logoff=Log Off
favlist=Favorites
favstart=Favorites
mamealllist=Games
mameallstart=All Games
mamecpslist=CPS Games
mamecpsstart=CPS Games
mameAtarilist=Atari Games
mameAtaristart=Atari Games
mameGunlist=Lightgun
mameGunstart=Lightgun Games
mameTrackballlist=Trackball
mameTrackballstart=Trackball Games
mameSpinnerlist=Spinner
mameSpinnerstart=Spinner Games
mameModel2list=Model 2
mameModel2start=Sega Model 2 Games
mameGoldenlist=Golden Era
mameGoldenstart=Golden Era Of Arcade
mameneolist=Neo-Geo
mameNEostart=Neo-Geo Games
mamemultilist=Multiplay
mamemultistart=Multiplayer Games
mamevectorlist=Vector
mamevectorstart=Vector Games
Of=of
shutdown=Turn Off System
standby=Stand By System
Restart=Restart System
Start=Start..
updatelist=Update List
UpdatingList=Updating Game List:
UpdatingPleaseWait=Please Wait......
videoslist=Videos
videostart=Videos
LaunchingGame=Launching Game:
PlayThisGame=Play This Game
Recommended=Recommended Games:
Series=Games in Series:
Title=Title
Flyer=Flyer
Cabinet=Cabinet
Cabinet3d=3D Cabinet
Panel=Panel
Box=Box
Cartridge=Cartridge
Marquee=Marquee
FavoritesAdd=Add To Favorites
FavoritesRemove=Remove From Favorites
NoVideosFound=- NO VIDEOS FOUND -
NoPicturesFound=- NO PICTURES FOUND -
NoMusicFound=- NO MUSIC FOUND -
NoArtistsFound=- NO ARTISTS FOUND -
NoAlbumsFound=- NO ALBUMS FOUND -
NoGenresFound=- NO GENRES FOUND -
NoGamesFound=- NO GAMES FOUND -
NoStationsFound=- NO STATIONS FOUND -
NoNewsFound=- NO NEWS FOUND -
CannotCreateSnaps1=Cannot Create Snaps
CannotCreateSnaps2=Emulator '[EMULATOR]' Does not have a valid Snap path, so Snaps cannot be created. Setup a valid snap path in the configuration and try again.
ViewControls=View Controls
Instructions=Instructions
ViewControlsKey=Press '[KEY]' to view in game.
AllMusic=All Music
ClearCurrentPlaylist=Clear Current Playlist
ShufflePlaylist=Shuffle Current Playlist
PlayLastGame=Last Game
ViewSlideShow=View Slide Show
Pictures=Pictures
Radio=Radio
PlayDVD=Play DVD
PlayCD=Play CD
DVDonDiskStart=DVDs
DVDonDiskList=DVDs
Demo=Demo:
Playing=Playing:
MAMEOriginal=Original Games
MAMEOriginallist=Originals
MAMEAdult=Adult Games
MAMEAdultlist=Adult
ClearAndQueueAll=Clear and Queue All
AddAndQueueAll=Add all to Queue
RandomGame=Play Random Game
StartMAME=MAME
StartApps=More Games & Programs
StartEMU=Emulated Games
StartControl=Exit/Shutdown
StartMedia=Multimedia
ListMAME=MAME
ListApps=Games & Apps
ListEMU=Games
ListControl=Exit
ListMedia=Media
TimesPlayed=Times Played
LastPlayed=Last Played
DeleteFavs=Delete Favorites
DeleteMost=Delete Most Played
Chapter=Chapter
Aspect=Aspect
Aspect0=Original Aspect - Not Zoomed
Aspect4=Widescreen on 4:3 - Stretched
Aspect5=Fill Screen
Aspect3a=Widescreen to 4:3 - Zoomed
Aspect3b=Letterbox to Widescreen - Zoomed
Aspect2=Original Aspect - Zoomed
Aspect1a=Widescreen to 4:3 - Shrunk
Aspect1b=4:3 to Widescreen - Stretched
Paused=Paused
PlayVideo=Play Video
ResumeVideo=Resume Video
RestartVideo=Restart Video
VideoQueue=Play All
QueueAllRandom=Play Randomly
More=More..
MostPlayed=Most Played
MostPlayedList=Most Played
VariousArtists=Various Artists
ConfirmDialog1=Select To Confirm.
ConfirmDialog2=Back To Cancel.
RemoveGame=Remove Game?
LocalDisk=Local Disk
SystemDisk=System Disk
CDDVD=CD/DVD Drive
NetworkDrive=Network Drive
RamDisk=Ram Disk
FloppyDisk=Floppy Disk
RemovableDisk=Removable Disk
UpdateGameList=Update List?
VideoQueueAll=
playstationstart=Playstation
themepickerlist=Themes
themepickerstart=Theme Picker
playstationlist=Playstation
mameVertList=Vertical
mameVertStart=Vertical Games
mameHorizlist=Horizontal
mameHorizstart=Horizontal Games
mamenotplayedlist=Not Played
mamenotplayedstart=Not Played
mamemawslist=Live - MAWS
mameMAWSstart=Live - MAWS Hall Of Fame
mameGameExlist=Live - GameEx
mameGamEexstart=Live - GameEx Favorites
ripcd=Rip CD
ripthiscd=Rip This CD Now
cantrip=- No CD, Invalid CD, or no CDDB data -
ViewPlaylist=View Playlist
KaraokAllSongs=All Songs
KaraokaMode1Click=Instant Play Mode
KaraokaModeQueue=Queue Mode
KaraokePlaylist=View/Edit Playlist
KaraokeStartMenu=Start Karaoke
mammodel2list=
CreateSnaps1=You are about to create snap shots for every game in the [EMULATOR] Games List.
NoeBooksFound=- NO EBOOKS FOUND -
QueueAll=Queue All
weather=Weather
Titles=Titles
Movies=Movies
Actors=Actors
Year=Year
Directors=Directors
Genres=Genres
Collections=Collections
Ratings=Ratings
Cast=Cast
Director=Director
Collection=Collection
TV=TV
NetFlix=NetFlix
SearchNetFlix=Search NetFlix
MameModel3Start=Sega Model 3 Games
MameModel3List=Model 3
[favorites]
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
[dvrms]
DVRFFDSHOW=0
CODEC=
[atractmodenewgametimer]
When in attract mode start a new random game or video each time this value is reached.=2
[attractvideospath]
The folder your videos are located.=L:\GameAds
[gameextender]
RemoteGameExLocation=\\workstation1\g$\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin
Enabled=False
Windowed=False
RemoteExtenderLocation=G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin
IPADDRESS=192.168.2.14
Port=8383
RefreshRate=20
SysUserName=John
Username=User33549
ComputerName=ARCADE
Publish=False
UserInfo=
GameExtenderCustomImage=False
GameExtenderImageNotFound=
[gameextenderviewer]
Server=90.0.0.13
PORT=8383
RefreshRate=7
StartWithGameEx=False
ExitWithGameEx=False
Windowed=False
[karaoke]
Path=C:\Karaoke
mode=False
[arcadesoundplugin]
Volume=8
[emulator_]
SelectionMusicFolder=C:\Music
[ebook]
Paths=C:\eBooks;G:\Dropbox\Mame32\Manuals
Quality=0
fittopage=False
[mediaplayer]
AudioMode=0
[cpwizard]
CPWizardEnable=False
CPWizardPath=E:\Program Files\CPWizard\CPWizard.exe
CPWizardStarted=True
CPWizardStartup=True
[video]
UseWMPWMV=
CMD=
[advkeyboard]
Forward=60
Rewind=61
PageUp=62
PageDown=63
VolumeDown=64
VolumeUp=65
Stop=66
Play=67
[cursorhider]
DoNotHide=
DoNotHideInGameEX=False
[defaultpaths]
EmuPath1=C:\Emulators
AssetPath1=C:\Assets
RomPath1=C:\Roms
[youtube]
[gamebase]
Path=H:\GAMEBASE
MapBack=False
ShowDesktop=True
[dvdrip]
Format=MP4
DVDRIPFOLDER=C:\DVD RIPS
Profile=Normal
CUSTOMCMD=
[gameexarcade]
[touchscreen]
Touchscreen_Enabled=2
Touchscreen_HidePointer=True
TouchScreen_ShowHelpScreens=True
TouchScreen_SingleClick=True
TouchScreen_OnlyCompatibleGames=True
TouchScreen_CheckForExit=True
TouchScreen_SendCredit=True
TouchScreen_ShowMouseAnimations=True
[laststatus]
specialfilter=ADULT
oldspecialfilter=ADULT
curemulator=0
listtype=7
curbak=bak
maxgames=415
gamename=
[steam]
LaunchBefore=
LaunchAfter=
[mappeddrives_1]
UNCPATH=\\Nasusa\roms_mint
Drive=R
[uplay]
UPlayEnabled=False
LaunchBefore=
[origin]
OriginEnabled=False
[emulator_0]
excludedfileswithnamesverifiedfound=;10yard85;
[login]
[movies]
[netflix]
[tv]
available=False
[frmobject]
Size=640, 400
Location=144, 152
WindowState=0
[videocapture]
Seconds=45
UseGPU=False
KeysStartRecord=164|120
KeysEndRecord=164|120
SavePath=E:\Program Files (x86)\Mame Gameex Arcade
[INTERNAL]
currentstation=
VGenre=---
OPTIMIZED=0
lastcpustring=Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz, 6135MB3.07Ghz - 8 Cores or CPU's5
version=15.60
timesruncount=0
emu_1lastfolderwrite=8/11/2019 8:20:56 AM
emu_1lastromfilter=*.*
emu_2lastfolderwrite=8/11/2019 8:19:41 AM
emu_2lastromfilter=*.*
emu_3lastfolderwrite=8/11/2019 8:20:01 AM
emu_3lastromfilter=*.*
emu_4lastfolderwrite=8/11/2019 8:20:19 AM
emu_4lastromfilter=*.*
emu_5lastfolderwrite=8/11/2019 8:20:56 AM
emu_5lastromfilter=*.*
emu_6lastfolderwrite=8/11/2019 8:21:49 AM
emu_6lastromfilter=*.*
emu_7lastfolderwrite=8/11/2019 8:22:01 AM
emu_7lastromfilter=*.*
emu_8lastfolderwrite=8/11/2019 8:22:12 AM
emu_8lastromfilter=*.*
emu_9lastfolderwrite=8/11/2019 8:22:24 AM
emu_9lastromfilter=*.*
emu_10lastfolderwrite=8/11/2019 8:22:36 AM
emu_10lastromfilter=*.*
emu_12lastfolderwrite=8/11/2019 8:23:02 AM
emu_12lastromfilter=*.*
emu_13lastfolderwrite=8/11/2019 8:23:15 AM
emu_13lastromfilter=*.*
emu_14lastfolderwrite=8/11/2019 8:23:26 AM
emu_14lastromfilter=*.*
emu_15lastfolderwrite=8/11/2019 8:24:26 AM
emu_15lastromfilter=*.*
emu_16lastfolderwrite=8/11/2019 8:24:39 AM
emu_16lastromfilter=*.zip
emu_18lastfolderwrite=8/11/2019 8:25:03 AM
emu_18lastromfilter=*.*
emu_20lastfolderwrite=8/11/2019 8:25:27 AM
emu_20lastromfilter=*.*
emu_21lastfolderwrite=8/11/2019 8:25:36 AM
emu_21lastromfilter=*.lnk
emu_22lastfolderwrite=8/11/2019 8:26:32 AM
emu_22lastromfilter=*.*
emu_23lastfolderwrite=8/11/2019 8:26:50 AM
emu_23lastromfilter=*.zip
lastglaunchlist=0
glaunchlistselected_0=1
glaunchlisttop_0=1
viewalbumtype=0
windowed=False
selectedgame=1
gamelisttop=1
catfilter=
manufilter=
yearfilter=
listtype=7
emulator=0
yearlisttop=1
catlisttop=1
namelisttop=1
manulisttop=1
yearselectedgame=1
catselectedgame=1
manuselectedgame=1
nameselectedgame=1
romname=3x3puzzl
romname2=3x3puzzl
specialfilter=ADULT
currentstationurl=
mameexe=mame64.exe
mamepath=E:\Program Files (x86)\Mame20764bit
mamefilemodified=2/26/2019 10:54:10 AM
mamefilesize=241145856
mamepromptupdate=False
mameis32bit=False
bezelversion=3
mameversion=0.207
errorreportingenabled=false
[CachedImages]
res=1228800
bakres=1228800
[CachedImagesMenuFont]
res=0
[SetupWizard]
EmuPath1=E:\Emulation\Emulators
AssetPath1=E:\Emulation\Assets
ROMPath1=E:\Emulation\ROMs
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=Basic
SavePosition=False
SearchText=
EmulatorIndex=0
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=0
NewsFeedsIndex=0
MappedDrivesIndex=0
SystemIndex=0
ShowPanel=True
FontSize=1
WindowSize=650, 478
WindowLocation=315, 221
WindowState=Maximized
CustomArray=
SearchArray=
SectionIndex=6
[Emulator_1]
System=Arcade
Category=Arcade
Emulator=MAME
Version=0.145
Rating=8.4
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/mame.7z
RequiredFiles=
Website=http://mamedev.org/
Info=MAME stands for Multiple Arcade Machine Emulator. When used in conjunction with images of the original arcade game's ROM and disk data, MAME attempts to reproduce that game as faithfully as possible on a more modern general-purpose computer. MAME can currently emulate several thousand different classic arcade video games from the late 1970s through the modern era.
TitleText=Mame
StartPageName=[Arcade] Arcade (MAME)
StartPageLogo=MAME
Command=mame64.exe [ROM] -rompath "[ROMPATH]"
RomFilter=
Database=[Arcade] Arcade (MAME)
ConfigFile=[Mapping Off] Exit (Process Close)
MapFile=[APP]\Map Files\[Arcade] Arcade (MAME).map
RomPath=E:\Emulation\ROMs\MAME\Roms
SnapPath=E:\Emulation\Assets\MAME\Snaps
TitlePath=E:\Emulation\Assets\MAME\Titles
BoxPath=E:\Emulation\Assets\MAME\Boxes
CartPath=E:\Emulation\Assets\MAME\Cartridges
ManualPath=E:\Emulation\Assets\MAME\Manuals
ControlPanelPath=E:\Emulation\Assets\MAME\Controls
WorkingPath=E:\Emulation\Emulators\MAME
MapKeys=
WaitBeforeKeys=
SendKeys=
ReplaceDash=
ReplaceUnder=
Capitals=
RemoveBrackets=
ShowDesktop=
Debug=
AlsoLaunch=
LaunchBefore=
LaunchAfter=
ExcludedFiles=
CustomBackground=
PlayMusic=
DontShowInfo=
PlaySelectionMusic=
PCGame=
UseDbName=True
GamesIn7Zips=
MergeSets=
PlayInScreenSaver=
ShowMostPlayed=
RandomMostPlayed=
CDCheck=
CDCheckFile=
CustomArtName1=
CustomArtPath1=
CustomArtName2=
CustomArtPath2=
CustomArtName3=
CustomArtPath3=
DownloadID=217
[Emulator_2]
Enabled=False
[Emulator_3]
Enabled=False
[Emulator_4]
Enabled=False
[Emulator_5]
Enabled=False
[Emulator_6]
Enabled=False
[Emulator_7]
Enabled=False
[Emulator_8]
Enabled=False
[Emulator_9]
Enabled=False
[Emulator_10]
Enabled=False
[Emulator_11]
ManualPath=
CartPath=
BoxPath=
TitlePath=
SnapPath=
Command=
RomPath=
WorkingPath=
StartPageLogo=
TITLETEXT=
STARTPAGENAME=
Enabled=False
[Emulator_12]
Enabled=False
[Emulator_13]
Enabled=False
[Emulator_14]
Enabled=False
[Emulator_15]
Enabled=False
[Emulator_16]
Enabled=False
[Emulator_17]
Enabled=False
[Emulator_18]
Enabled=False
[Emulator_19]
Enabled=False
[Emulator_20]
Enabled=False
[Emulator_21]
Enabled=False
[Emulator_22]
Enabled=False
[Emulator_23]
Enabled=False
[CachedImagesGameFont]
res=1228800
[CachedImagesGameFontFaded]
res=1228800
[CachedImages3d]
themedir=\themes\Default - Default\MEDIA\
titlefontres=1228800
titlefont=HandelGothic BT
titlefontstyle=0
titlefontsize=0
outlinefonts=True
use16bitcolour=False
gradienttitlefont=False
lowercasetitlefont=True
antialiasfonts=False
windowed=False
[VideoLists]
mamevideolists_reset221_startmame=False
mamevideolists_lastmodifiedlist_startmame=8/11/2019 9:47:00 PM
mamevideolists_list_startmame=
mamevideolists_reset221_most=False
mamevideolists_lastmodifiedlist_most=8/14/2019 7:59:19 PM
mamevideolists_list_most=E:\Program Files (x86)\Mame Gameex Arcade\GameEx Arcade Edition\MEDIA\DOWNLOADED ARTWORK\MAME\VIDEO\ms5pcb.mp4
mamevideolists_reset221_mamef=False
mamevideolists_lastmodifiedlist_mamef=8/14/2019 7:59:19 PM
mamevideolists_list_mamef=
mamevideolists_reset221_mameall=False
mamevideolists_lastmodifiedlist_mameall=8/14/2019 7:59:19 PM
mamevideolists_list_mameall=10yard.mp4|1943kai.mp4|1941.mp4|1943b.mp4|10yard85.mp4|progolf.mp4|cprogolf18.mp4|gtmr.mp4|005.mp4|1943j.mp4|1944.mp4|pc_1942.mp4|1943mii.mp4|1on1gov.mp4|1942.mp4|1943.mp4
mamevideolists_reset221_original=False
mamevideolists_lastmodifiedlist_original=8/14/2019 7:59:19 PM
mamevideolists_list_original=19xx.mp4|progolf.mp4|2020bb.mp4|1943mii.mp4|10yard.mp4|1on1gov.mp4|1942.mp4|1943kai.mp4|1945kiii.mp4|1943.mp4|1941.mp4|openice.mp4|005.mp4|1944.mp4|gtmr.mp4|pc_1942.mp4
mamevideolists_reset221_golden=False
mamevideolists_lastmodifiedlist_golden=8/14/2019 7:59:19 PM
mamevideolists_list_golden=1943kai.mp4|progolf.mp4|10yard.mp4|1943.mp4|005.mp4|pc_1942.mp4|1942.mp4|4in1.mp4|m660.mp4|tceptor2.mp4|1943mii.mp4|1943b.mp4|1943j.mp4|cprogolf18.mp4|10yard85.mp4|4dwarrio.mp4
mamevideolists_reset221_mamemulti=False
mamevideolists_lastmodifiedlist_mamemulti=8/11/2019 9:47:00 PM
mamevideolists_list_mamemulti=
mamevideolists_reset221_fourplayer=False
mamevideolists_lastmodifiedlist_fourplayer=8/13/2019 7:41:04 PM
mamevideolists_list_fourplayer=
mamevideolists_reset221_vector=False
mamevideolists_lastmodifiedlist_vector=8/14/2019 7:59:19 PM
mamevideolists_list_vector=boxingb.mp4|bradley.mp4|armora.mp4|elim2.mp4|aztarac.mp4|bzone.mp4|omegrace.mp4|cchasm.mp4|asterockv.mp4|barrier.mp4|bwidow.mp4|asteroid.mp4|aerolitos.mp4|esb.mp4|demon.mp4|astdelux.mp4
mamevideolists_reset221_notplayed=False
mamevideolists_lastmodifiedlist_notplayed=8/14/2019 7:59:19 PM
mamevideolists_list_notplayed=progolf.mp4|1945kiii.mp4|10yard85.mp4|1941.mp4|1944.mp4|1943kai.mp4|1on1gov.mp4|1943mii.mp4|10yard.mp4|005.mp4|cprogolf18.mp4|1943b.mp4|bgareggabl.mp4|1942.mp4|1943j.mp4|gtmr.mp4
mamevideolists_reset221_chd=False
mamevideolists_lastmodifiedlist_chd=8/14/2019 7:59:19 PM
mamevideolists_list_chd=cubeqst.mp4
mamevideolists_reset221_horizontal=False
mamevideolists_lastmodifiedlist_horizontal=8/14/2019 7:59:19 PM
mamevideolists_list_horizontal=3countb.mp4|10yard85.mp4|openice.mp4|10yard.mp4|gtmr.mp4|1944.mp4|3bagflvt.mp4|4dwarrio.mp4|m21.mp4|pc_1942.mp4|2020bb.mp4|3x3puzzl.mp4|4enraya.mp4|1on1gov.mp4|tceptor2.mp4|3on3dunk.mp4
mamevideolists_reset221_gameexplayed=False
mamevideolists_lastmodifiedlist_gameexplayed=8/14/2019 7:59:19 PM
mamevideolists_list_gameexplayed=1on1gov.mp4|openice.mp4|64street.mp4|1945kiii.mp4|1944.mp4|1942.mp4|1943kai.mp4|acedrvrw.mp4|1943.mp4|19xx.mp4|gtmr.mp4|88games.mp4|10yard.mp4|720.mp4|005.mp4|1941.mp4
mamevideolists_reset221_vertical=False
mamevideolists_lastmodifiedlist_vertical=8/14/2019 7:59:19 PM
mamevideolists_list_vertical=1943b.mp4|m660.mp4|1942.mp4|1941.mp4|1943j.mp4|005.mp4|1943kai.mp4|cprogolf18.mp4|1943mii.mp4|1945kiii.mp4|bgareggabl.mp4|19xx.mp4|progolf.mp4|jantotsu.mp4|4in1.mp4|1943.mp4
mamevideolists_reset221_trackball=False
mamevideolists_lastmodifiedlist_trackball=8/14/2019 7:59:19 PM
mamevideolists_list_trackball=aceattac.mp4|bking3.mp4|atarifb.mp4|bking.mp4|argusg.mp4|bsktball.mp4|horshoes.mp4|amerdart.mp4|soccer.mp4|ataxx.mp4|bigevglf.mp4|bking2.mp4|abaseb.mp4|arcadecl.mp4|atarifb.mp4|beezer.mp4
mamevideolists_reset221_spinner=False
mamevideolists_lastmodifiedlist_spinner=8/13/2019 7:41:04 PM
mamevideolists_list_spinner=
mamevideolists_reset221_neogeo=False
mamevideolists_lastmodifiedlist_neogeo=8/14/2019 7:59:19 PM
mamevideolists_list_neogeo=sonicwi3.mp4|bangbead.mp4|b2b.mp4|alpham2.mp4|bstars2.mp4|aof.mp4|3countb.mp4|aodk.mp4|bakatono.mp4|2020bb.mp4|bstars.mp4|androdun.mp4|aof3.mp4|aof2.mp4|sonicwi2.mp4|aof3k.mp4
mamevideolists_reset221_cps=False
mamevideolists_lastmodifiedlist_cps=8/14/2019 7:59:19 PM
mamevideolists_list_cps=cworld2j.mp4|chikij.mp4|dino.mp4|dino.mp4|cawing.mp4|punisherbz.mp4|19xx.mp4|armwar.mp4|csclub.mp4|batcir.mp4|cybots.mp4|captcomm.mp4|area88.mp4|avsp.mp4|1941.mp4|1944.mp4
mamevideolists_reset221_atari=False
mamevideolists_lastmodifiedlist_atari=8/14/2019 7:59:19 PM
mamevideolists_list_atari=asteroid.mp4|arcadecl.mp4|720.mp4|astdelux.mp4|avalnche.mp4|batman.mp4|abaseb.mp4|beathead.mp4|atarifb.mp4|badlands.mp4|apb.mp4|soccer.mp4|bzone.mp4|cloak.mp4|bsktball.mp4|atarifb.mp4
mamevideolists_reset221_gun=False
mamevideolists_lastmodifiedlist_gun=8/14/2019 7:59:19 PM
mamevideolists_list_gun=cluedo.mp4|bronx.mp4|bbusters.mp4|bang.mp4|cheyenne.mp4|bubbletr.mp4|chiller.mp4|borntofi.mp4|cracksht.mp4|deerhunt.mp4|combat.mp4|deerhunt.mp4|claypign.mp4|combat.mp4|crossbow.mp4|nycaptor.mp4
mamevideolists_reset221_adult=False
mamevideolists_lastmodifiedlist_adult=8/14/2019 7:59:19 PM
mamevideolists_list_adult=billlist.mp4|boonggab.mp4|bigtwin.mp4|psailor1.mp4|apparel.mp4|bakatono.mp4|blockgal.mp4|blandia.mp4|3x3puzzl.mp4|bijokkoy.mp4|psailor2.mp4|bijokkog.mp4|7jigen.mp4|mjapinky.mp4|realbrk.mp4|abunai.mp4
mamevideolists_reset221_update=False
mamevideolists_lastmodifiedlist_update=8/11/2019 9:47:00 PM
mamevideolists_list_update=
3
Edited by tthurman
Woah.....that's better.
Spoiler
Log
20:22:56.42  8/14/2019:  Opening Configuration File
20:22:56.47  8/14/2019:  GameEx Arcade Edition x64: Version 15.60: Starting Log
20:22:56.60  8/14/2019:  Windows 10 Pro 64-bit
20:22:56.60  8/14/2019:  Aero running
20:22:56.60  8/14/2019:  Initializing Vista/Windows 7 volume control
20:22:56.62  8/14/2019:  Getting CPU and RAM info
20:22:56.63  8/14/2019:  Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz, 6135MB
20:22:56.63  8/14/2019:  3.07Ghz - 8 Cores or CPU's
20:22:56.64  8/14/2019:  Running Randomize()
20:22:56.71  8/14/2019:  Loading PlugIns
20:22:56.75  8/14/2019:  Checking for applications to Launch On Startup
20:22:56.75  8/14/2019:  Setting default net connection limit to 15
20:22:56.76  8/14/2019:  Running Misc startup tasks
20:22:56.76  8/14/2019:  Setting Menu types
20:22:56.77  8/14/2019:  Getting Configuration Values
20:22:56.78  8/14/2019:  Using Theme: Default - Default
20:22:56.78  8/14/2019:  Checking for alternate Image Directory for Theme: Default - Default
20:22:56.79  8/14/2019:  Launching HideOS.exe
20:22:56.79  8/14/2019:  Initialising Video/MNG DLL's
20:22:56.80  8/14/2019:  GameEx will check for media insertion (may affect performance)
20:22:56.80  8/14/2019:  Hiding Taskbar
20:22:56.81  8/14/2019:  Is Media Center running?
20:22:56.82  8/14/2019:  Checking/Creating LCD Registry values
20:22:56.83  8/14/2019:  Check Media Center Exit/Start Mode
20:22:56.83  8/14/2019:  Media Center Mode 2
20:22:56.85  8/14/2019:  Video previews on. Warning: Only recommended on modern systems
20:22:56.85  8/14/2019:  Snap Delay set to: 7
20:22:56.86  8/14/2019:  Get other settings
20:22:56.86  8/14/2019:  Set: Find emulator artwork on best match basis
20:22:56.86  8/14/2019:  Start work for Form
20:22:56.87  8/14/2019:  Getting Original Screen Size
20:22:56.88  8/14/2019:  Opening Database Connection
20:22:56.88  8/14/2019:  Data Source=E:\Program Files (x86)\Mame Gameex Arcade\GameEx Arcade Edition\DATA\data.db3;Pooling=true;FailIfMissing=true
20:22:56.99  8/14/2019:  Initializing Component
20:22:57.04  8/14/2019:  MAME Path is: E:\Program Files (x86)\Mame20764bit
20:22:57.05  8/14/2019:  MAME EXE file is: mame64.exe
20:22:57.05  8/14/2019:  ROM Path is: E:\Program Files (x86)\Mame20764bit\roms
20:22:57.06  8/14/2019:  Catver.ini is located at: E:\Program Files (x86)\Mame Gameex Arcade\GameEx Arcade Edition\DATA\catver.ini
20:22:57.06  8/14/2019:  controls.ini is located at: E:\Program Files (x86)\Mame Gameex Arcade\GameEx Arcade Edition\DATA\controls.ini
20:22:57.11  8/14/2019:  History.dat is located at: E:\Program Files (x86)\Mame Gameex Arcade\GameEx Arcade Edition\DATA\history.dat
20:22:57.12  8/14/2019:  nplayers.ini is located at: E:\Program Files (x86)\Mame Gameex Arcade\GameEx Arcade Edition\DATA\nplayers.ini
20:22:57.12  8/14/2019:  command.dat is located at: E:\Program Files (x86)\Mame Gameex Arcade\GameEx Arcade Edition\DATA\command.dat
20:22:57.12  8/14/2019:  MAMEinfo.dat is located at: E:\Program Files (x86)\Mame Gameex Arcade\GameEx Arcade Edition\DATA\mameinfo.dat
20:22:57.13  8/14/2019:  Snap Path: Not Found
20:22:57.14  8/14/2019:  Database Snap Path: Not Found
20:22:57.15  8/14/2019:  Background Snap Path: Not Found
20:22:57.15  8/14/2019:  AVI Snap Path: Not Found
20:22:57.15  8/14/2019:  Video theme Path: Not Found
20:22:57.16  8/14/2019:  Video background Path: Not Found
20:22:57.16  8/14/2019:  Flyer Path: Not Found
20:22:57.17  8/14/2019:  Cabinet Path: Not Found
20:22:57.17  8/14/2019:  Cabinet 3D Path: Not Found
20:22:57.18  8/14/2019:  Title Path: Not Found
20:22:57.18  8/14/2019:  PCB Path: Not Found
20:22:57.19  8/14/2019:  Artwork Preview Path: Not Found
20:22:57.19  8/14/2019:  Panel Path: Not Found
20:22:57.20  8/14/2019:  Manual Path: Not Found
20:22:57.20  8/14/2019:  Icon Path: Not Found
20:22:57.20  8/14/2019:  Marquee Path: Not Found
20:22:57.25  8/14/2019:  Applying Language/Text
20:22:57.25  8/14/2019:  Text/Language: English
20:22:57.26  8/14/2019:  Loading Language/Text
20:22:57.28  8/14/2019:  Loading Addins
20:22:57.28  8/14/2019:  Using Version 3 Themes Animations
20:22:57.28  8/14/2019:  Retrieving resolution setting
20:22:57.30  8/14/2019:  Using General Font: HandelGothic BT
20:22:57.30  8/14/2019:  Using Title Font: HandelGothic BT
20:22:57.31  8/14/2019:  GameEx will try to reduce CPU usage
20:22:57.36  8/14/2019:  Initialising Direct3D
20:22:57.69  8/14/2019:  Applying GameEx is Loading Image
20:22:57.71  8/14/2019:  Setting Resolution to 1280x960 32 bit color
20:22:57.73  8/14/2019:  Creating Surfaces
20:22:57.89  8/14/2019:  Creating Back Buffer
20:22:57.90  8/14/2019:  Loading graphic Surfaces
20:22:57.90  8/14/2019:  Display is running at: 1280x960 32bit color, 60hz
20:22:57.92  8/14/2019:  Adapter: AMD Radeon HD 5450
20:22:57.94  8/14/2019:  Max texture size: 16384x16384
20:22:57.94  8/14/2019:  Available texture memory: 3303MB
20:22:57.97  8/14/2019:  Available video memory: 512MB
20:22:58.04  8/14/2019:  Initialising Bass Audio Library
20:22:58.09  8/14/2019:  Creating Surfaces Misc and Dialogs
20:22:58.20  8/14/2019:  Creating Surfaces Volume
20:22:58.20  8/14/2019:  Creating Surfaces Arrows
20:22:58.21  8/14/2019:  Creating Surfaces GameEXlogo Text
20:22:58.21  8/14/2019:  Creating Surfaces Toolbar
20:22:58.24  8/14/2019:  Creating Surfaces Toolbar Controls
20:22:58.29  8/14/2019:  Creating Surfaces Backgrounds
20:22:58.30  8/14/2019:  Creating Surfaces GameEx Logo
20:22:58.36  8/14/2019:  Creating Surface Unselected
20:22:58.37  8/14/2019:  Creating Surfaces Snaps
20:22:58.39  8/14/2019:  Creating Surfaces Menu and List Bars
20:22:58.95  8/14/2019:  Creating Fonts
20:22:58.96  8/14/2019:  Creating Game Font
20:22:59.30  8/14/2019:  Creating Game Font Faded
20:22:59.89  8/14/2019:  Creating Title Font
20:22:59.96  8/14/2019:  Restoring Title Font From Cache
20:23:00.01  8/14/2019:  Creating Font Black
20:23:00.05  8/14/2019:  Creating Font Black Small
20:23:00.10  8/14/2019:  Fonts Created Succesfully
20:23:00.48  8/14/2019:  18MB Video Memory Used
20:23:00.49  8/14/2019:  Initial Emulator Load
20:23:00.66  8/14/2019:  Loading Custom Emulators
20:23:00.67  8/14/2019:  Loading Emulator 1: [Arcade] Arcade (MAME)
20:23:00.71  8/14/2019:  Checking if Steam enabled
20:23:00.72  8/14/2019:  Cannot find steam path
20:23:00.74  8/14/2019:  Checking if Origin enabled
20:23:00.75  8/14/2019:  Cannot find origin executable
20:23:00.77  8/14/2019:  Checking if Uplay enabled
20:23:00.77  8/14/2019:  Cannot find UPlay executable
20:23:00.78  8/14/2019:  gamebase support enabled.
20:23:00.78  8/14/2019:  ERROR: Could not find gamebase path or gblanucher.exe
20:23:00.79  8/14/2019:  gamebase support disabled.
20:23:00.98  8/14/2019:  Getting CD/DVD Drives
20:23:00.00  8/14/2019:  MAME CMD options: -nowindow -joy -skip_gameinfo
20:23:01.01  8/14/2019:  Initialising DirectInput for Gamepad support
20:23:01.05  8/14/2019:  Unable to create a joystick device
20:23:01.06  8/14/2019:  Loading Start Page
20:23:01.30  8/14/2019:  Initializing MCE Remote
20:23:01.32  8/14/2019:  Initialization OK! Starting GameEx!
20:23:01.33  8/14/2019:  Testing Main Loop Once: Processing Frame
20:23:02.45  8/14/2019:  Testing Main Loop Once: Main Loop ran successfully
20:23:03.45  8/14/2019:  Attempting to load game list
20:23:03.77  8/14/2019:  Validating: Emulator_1: Snap Path: E:\Emulation\Assets\MAME\Snaps
20:23:03.77  8/14/2019:  Validating: Emulator_1: Control Panel Path: E:\Emulation\Assets\MAME\Controls
20:23:03.78  8/14/2019:  Validating: Emulator_1: Database: [Arcade] Arcade (MAME)
20:23:03.78  8/14/2019:  Warning: Emulator_1: Database Does not exist
20:23:03.79  8/14/2019:  Validating: Emulator_1: Title Snap Path: E:\Emulation\Assets\MAME\Titles
20:23:03.79  8/14/2019:  Validating: Emulator_1: Box Art Path: E:\Emulation\Assets\MAME\Boxes
20:23:03.80  8/14/2019:  Validating: Emulator_1: Cart Art Path: E:\Emulation\Assets\MAME\Cartridges
20:23:03.80  8/14/2019:  Validating: Emulator_1: Manual Path: E:\Emulation\Assets\MAME\Manuals
20:23:03.80  8/14/2019:  Warning: Emulator_1: MAPFile Does Not Exist
20:23:15.33  8/14/2019:  Exiting GameEx!
20:23:15.39  8/14/2019:  Closing HideOS.exe
20:23:15.60  8/14/2019:  Disposing all videos
20:23:15.61  8/14/2019:  Deleting temporary Karaoke videos
20:23:15.62  8/14/2019:  Disposing Image List
20:23:15.62  8/14/2019:  Disposing Fonts
20:23:15.63  8/14/2019:  Disposing Surfaces
20:23:15.64  8/14/2019:  Saving Settings
20:23:15.65  8/14/2019:  Saving Settings
20:23:15.66  8/14/2019:  Shutting down Bass
20:23:15.74  8/14/2019:  Disposing Plugins
20:23:15.76  8/14/2019:  Closing database connection
20:23:15.77  8/14/2019:  Checking for applications to Launch On Exit
20:23:15.78  8/14/2019:  Bye
9
Edited by tthurman
Better now
Going forward, can you please attach your support files? Copy & paste makes for a lot of scrolling and is harder for some of us to search for specific error or configuration text to help you quickly. Thanks.
Generally, you do invoke the controller configuration for MAME by using using a command line switch. I have an X-Arcade Tankstick so  -ctrlr x-arcade  is in my command line. You may want to try -ctrlr hotrod in your MAME command line.
Is there a way to have the “command line” associated with the desktop launch icon, or do you have to type it from a command prompt each time?
Should just be in the advanced mame options listing and you should have a corresponding hotrod.cfg file in your mame\ctrlr directory. If not, that could be why.
Any reason why you have MAME installed in E:\Program Files (x86)\Mame20764bit?> May be that Windows is seeing that path as a higher level of protected. Otherwise, MAME should not treat your Hotrod controller any differently regardless of whther MAME is 32 or 64-bit.
A few questions:
Does Windows 10 recognize the device?
And have you tried a 32-bit version of MAME?
Windows 10 does recognize the device, it will register imput in wordpad and word.
I  have not tried MAME 32 bit with Gameex.  My OS drive (C) is a small SSD, I would prefer to install all files on a much larger SATA drive (E).  If you think I would do better starting over with MAME 32, just let me know and I can.
Your e: drive is fine. It is how I am setup. Suggesting maybe installing to the root of your drive instead of under Program Files.
This is resolved, I moved the directory and installed the 32 bit to root of drive... all is good.  The controller now works with the -config and its looking good.
