Is there a way in pinball x to show an option first for systems? Visual Pinball X - Pinball FX3 - Future Pinball and after choosing the system i play the table of this system? I would have a menu with the systems and after I chose the system would appear the wheels of this system.
You mean like under the Lists menu option that comes up when you select a table, but open that menu on pinballx startup?
Not a menu Lists. I want a menu with the systems after pinball x opens before the wheels appear so that I can choose the system and  then I want the wheels of this system can be select.
Nothing like that exists as far as i know.
You might be able to to do some kind of launch before script that updates the pinballx.ini file [internal] section to set the filter values (that hold information on your last selected system/ table) based on a selection - but i've not tried doing anything like that.
Other option is to request it as a feature enhancement;
  • Draco1962 locked this topic
