Hi,
I started with about 2000 zipped rom files, added today about 6000 more.  But my game count in gaemeex evolution is the same!!  What am i doing wrong?
I tried moving the files in E:\GameEx Evolution\UserData\Cache\Data  and the program recreated them, but count is the same.
I tried in setup wizard to audit roms, no difference.
Any help appreciated.
I included a copy of log files.
Edit: I  have found that if I uninstall gameex and delete all its folders, and reinstall, that it sees the new roms. But that is not efficient, obviously. Hoping for a better way?
edit: I meant to post this in GameEx Evolution / General  if someone can move it?
Tonycubed2
[SETUPWIZARD].log [GAMEEX_EVOLUTION].log
I primarily support GameEx, AE, and PinballX, so won't be of much help to you here.
I am sure that there is a way to update things that I'm not aware of and someone will assist with an answer.
Thanks. It’s curious. GameEx has the update option, but not evolution. I will patiently wait for a nudge in the right direction. I suspect a few data files need deleting. Let’s see.
The two front ends may look similar in some respects, but they are entirely different beasts.
Quote
What exactly did it do?  I can't honestly say I've ever had a need to update the set in EVO, so I don't have any experience with this feature.
