Hi everyone, I found a problem with pinballx, I try to describe it as best as possible, but my English is terrible.
After installing pinball fx3 latest version using pinballx I can start the game by launching the table directly, but after a few seconds I return to the pinballx screen of the table selection. I tested pinballx with vpx and pfx2 and the problem does not occur. Running pfx3 directly the game works perfectly, but if I do it as a pinballx it just comes out of the game.
It also happens if I don't press any key during the game and it always does as if it received the command to exit the emulator.
I searched the forum, others had this problem, which seems to have been fixed in a new version of pinballx. I then uninstalled pinballx and reinstalled the latest version, and redoing all the settings from the beginning.
Unfortunately the problem remains. I attach the configuration files thanks for the help.
PinballX.ini
Do you maybe have an extra space in the process to be monitored (in begin or end?)
A log file where it happened will be appriciated
here are the files. I tried to compare them with an old backup of a previous version of pinballx where everything worked, and I noticed that it is pinballx that automatically leaves the game table even if I don't understand the reason
[SETTINGS].log log.txt
Solved, but I'm not sure how. I tried to launch the table from cmd and it didn't start. So I modified the executable of pinballfx3 (from pinball fx3.exe to pinballfx3.exe) and from cmd obviously started. I re-set the executable parameters to pinballx and it works. The strange thing is that on pinball fx2 works despite there is space in pinball fx2 (executable pinball fx2.exe and not pinaballfx2.exe).
Mystery.
1 hour ago, Mike_da_Spike said:
I have a space too and works fine. Not sure what happends to you.
iI hope I no longer run into these strange problems, I updated the pinball after 1 year and spent more time solving absurd problems than playing ... will the day ever come where everything will go first? thanks anyway for the support, you are great
