Incase anyone interested building a dedicated cabinet
Here is what I purchased from eBay in my conquest to getting components to be a very low cost cabinet
#1 The computer
$285
This did not include a mouse or keyboard or drives....BUT..........
This 3.0 Ghz pentium can be overclocked to 3.8 Ghz and be stable at that rate
I left it running California Speed in Mame all night long
I monitored the cpu heat and it didnt seam it was running much hotter playing CS than sitting idle
This is a very overclockable machine
*built in graphics are not the best but again - mame doesnt care because it does not take advantage of hardware in graphics cards
#2 The 20 LCD
$121.00
The Dell monitor has all the connectors
RCA-SVideo-GVA-DVI
The specs show the refresh is slow but honestly - I dont see it
I guess because in Mame screen rates max out at 60fps
#3 The Arcade controls
$88.95
* A 3 inch PS/2 Blue Translucent Trackball Mouse from Betson Imperial
* 3 Blue Maximum Joysticks from Betson Imperial
* 63 Arcade Push Buttons
o 28 Blue Push Buttons from Betson Imperial
o 16 White Push Buttons from Betson Imperial
o 1 Red Push Button from Betson Imperial
o 1 Green Push Button from Betson Imperial
o 1 Player 1 Push Button from Betson Imperial
o 1 Player 2 Push Button from Betson Imperial
o 2 Blue Push Buttons from an Ebay Seller
o 13 White Push Buttons from an Ebay Seller
* A Total of 70 Microswitches
o 58 Loose Microswitches for the Push Buttons
o 12 Microswitches on the 3 Joysticks
* 61 Nuts, to hold the Push buttons in place
* About 101 end pieces that you solder to your wire ends that slide on and off of the microswitches
* Y Mouse-Keyboard & Mouse Adapter for USB
* A Gravis Gamepad Pro Usb Controller
#5 Speakers
$59.81
Bose speakers
ok these are more high priced than what I wanted but...
Bose ...and they sound great - crisp - loud
Bose...man ...Bose
#6 Mame controller TOKN 32
$47.95
Grand total
$602.71
Now I got stuff laying around (keyboard, mouse, harddrive, and cd player) that I put in but if anyone was trying to keep up with costs...figure
keyboard - $10 <---find cheapest...only need to configure stuff...I got one of those illuminated keyboards which helps out alot
mouse - $4 <---find cheapest or borrow - trackball in unit will be mouse later
cd player - $20 <--- find a clearance sale - only gonna use it to load OS...you could borrow one
Harddrive - $80 <----this varies...suggest getting brand name - quality vs quantity
This is miscellanious stuff and milage may vary on prices
Now other things to get:
Millstead
3/4 In. x 2 Ft. x 4 Ft. MDF Pre-cut Panels
Model 15138
(Home Depot)
$6.88 each x 5 =$34.40
Caster wheels
4 for $7.00 at Skycraft Geek Heaven
*the prices on the website are higher than what they have instore
LCD mount - this is hard to find at a decent price
Radio shack has them at like $90
Sams had them at $30 but are no longer there...doh!
This is one of those things I need to find cheap as possible...this will never be seen
Maybe once the case is built - I might toss some decorations on it Inexpensive cool lights
So I am coming in under $700
Minus time spent and Beers to be drank
Too bad there was a WORK IN PROGRESS section here in the forums...as this is not a HELP ME thread more like a WANNA WATCH
Cheers-n-stuff
As a IT dude..I can tell you...overclocking only leads to shorter life span..resist the urge!!
OC'ing a proc can be harmful if you don't maintain a decent temperature. The key word is temperature. Heat will kill anything not just procs. Liquid cooling is cheap enough - Koolance.com.
Thanks for the TIPS
I was more curious to see how fast it could be tweaked and sustained
As far as playing PACMAN - I see no difference
And the new 108 has multi-threading but the speed and MT doest make California Speed that much faster
It's reverted back to the 3.0 Ghz
But even if it did explode - $280 is something I could rebound from
i was going to overclock my celeron, but then I thought, why create the extra burden on my pc to make about 5 games only a LITTLE more passable when I have thousands of other games that think they have died and gone to heaven on a 3.2gHz PC?? I have actually thought about de-clocking it so that it is silent since processor speed is so unnecessary for most games. Haven't done it yet though. Either way I am happy with my $30 Celeron 351. Of course all this logic only makes sense on a dedicated cabinet.
Sort of why I stopped at a P4 2.8GHz. It's cheap second-hand, fast enough for GameEx niceities (and of course easily capable of running all the old-skool games and consoles I'm interested in with a lot to spare) but the CPUs not stressed at all and doesn't need heaps of cooling...a simple quiet CPU Fan upgrade. Also chose a nVidia 6200 GPU. Not very powerful, but it's got 256mb RAM, DX9 support and doesn't even need a fan!
Choose carefully for your cabinet project...
Shaun
