Last thing in the log is "Loading Game Statistics and Scores"
Maybe you have a corrupt statistics.ini file or high score data?. Look in databases folder for the statistics.ini file and see if there's any rogue characters in there (or post it back here)
Okay, here is the thing.
On a clean installation there is no statistics.ini file at all in the Databases folder?
So I found my old one and its 11k but empty?
Should there be a statistics.ini file on a clean install?
Where can I download this file from?
Statistics.ini
The statistics file is a file with your statistics per game.
So think when pbx launches fine and you run a table it will create it automaticly.
And a 11kb file that is empty looks corrupted ( good catch @scutters !)
So I deleted everything. Started fresh but still hangs.
I Have created a brand new install.
I did try to install the 64 bit, but reverted to the 32 (un ticked the install option for x64)
I also installed 3.35 the new version from last night.
Are the 64 bit DLLs cached in the GAC like the old .NET? I checked the registry and it installed okay.
I continues to stall on those Stats even without a statistics.ini file at all. Stalls on a vanilla installation.
Thanks!
