Hey,
Is anyone having the same problem with forums being less readable since today ? i'm getting white bars everywhere, in browse menu text is only readable when hovering with mouse over it or grey text doesn't stand out enough anymore (downloads section for example). I tried in edge and chrome and it's the same but  would like to know if it's something on my end or something has changed
Click the Themes option on the bottom right and select the prior version.
We are not sure how or what changed to cause this and it will require Tom to check with the vendor if he is unable to fix the issue.
hmm, i can't say i can see a themes option anywhere can you post a screenshot of where to look ? i see a "theme by jcdesign" all the way on the bottom but nothing to select another theme.
