pls help , finishing stages of cabinet table huge problem
I set up visual pinball 9 in the "visual pinball" setting , then vpx in "other systems" setup.  When I load a vpx table it will crash and in the help settings the system shows its trying to load thru vpin9. Opposite happens with some of the vpin9 tables - it will try to load through vpx.  All tables are in one folder, works outside of Pinball x but does not seem to work inside.  Any help would be greatly appreciated
Please be aware of where you are posting your thread asking for help - you may not get seen quickly.
Help us help you by attaching a copy of your pinballx.ini file and log.txt file (right after the error occurs) so it can be reviewed by the community.  Thank you.
so here is what I think is up, I loadedtales of the arab knights, and twilight zone  both vp x tables but it seems they are trying to load w/ vpin 9 through the front end pinball x, my thought or question is how does the front load pinball x know when to start a game in vpx exe or vpin 9 exe, I think that's whats up since all tables for 9 and x are in the same folder but all work perfectly until I use the frontloader, thanks john
Please attach copies of your pinballx.ini and log.txt files as previously requested. These files help us give you the right answer without a lot of second guessing. Refer to the following if you need assistance finding the files:
thanks here are the logs
[Display]
Monitor=0
rotate=270
Windowed=False
WindowWidth=480
WindowHeight=720
WindowX=0
WindowY=65
PlayFieldBrightness=230
WheelTextColor=ffffffff
InfoTextColor=ffffffff
InfoTextOutlineColor=ff000000
FilterTextColor=ffffffff
MenuColor=ffffa500
[BackGlass]
monitor=1
x=0
y=0
width=1920
height=1080
AutoPositionB2S=True
[DMD]
monitor=2
x=0
y=0
width=900
height=300
AutoPositionPinMAME=False
[FileSystem]
EnableFileMatching=True
[Interface]
DesktopModeEnabled=False
EnableAdditionalDetail=True
ShowSystem=True
ShowRatings=True
[Audio]
StreamVolume=100
SampleVolume=100
PlaySoundInVideos=True
[Startup]
playsound=True
playvideo=False
StartWithWindows=no
[KeyCodes]
quit=27
left=37
right=39
select=13
rotate=82
pageleft=33
pageright=34
exitemulator=81
ingame=80
screenshot=83
capturevideos=86
instructions=73
volumedown=109
volumeup=107
credit=53
plunger=164
launch=50
[JoyCodes]
quit=10
left=0
right=1
select=2
rotate=11
pageleft=3
pageright=4
exitemulator=12
ingame=13
instructions=14
launch=17
Credit=15
Plunger=16
[Text]
All=All
PlayGameTwoPlayer=Two Player Game
Line1=Free Play
Line2=Press Start
Featuring=Featuring
Tables=Tables
PlayGame=Play Game
Instructions=Instructions
Information=Information
Flyer=Flyer
Gameplay=Gameplay
Tutorial=Tutorial
Promo=Promo
ExitGame=Exit Game
ReturnToGame=Return to Game
Return=Return
Exit=Exit
Shutdown=Shutdown
Favorite=Favorite
Favorites=Favorites
FavoritesAdd=Add To Favorites
FavoritesRemove=Remove From Favorites
MostPlayed=Most Played
LastPlayed=Last Played
Lists=Lists
CapturingVideos=Capturing videos. Please wait. This will take several minutes.
Ratings=Ratings
HighScores=High Scores
RateTable=Rate Table
NotRated=Not Rated
[FuturePinball]
WorkingPath=h:\-PINBALL-\-FUTURE PINBALL-
TablePath=h:\-PINBALL-\-FUTURE PINBALL-\Tables
Executable=Future Pinball.exe
LaunchBeforeEnabled=false
LaunchBeforeWorkingPath=
LaunchBeforeHideWindow=False
LaunchBeforeWaitForExit=True
LaunchAfterEnabled=False
LaunchAfterWorkingPath=
LaunchAfterHideWindow=False
LaunchAfterWaitForExit=True
MouseClickFocus=True
[VisualPinball]
WorkingPath=C:\Visual Pinball
Executable=VPinball995.exe
AutoConfigure=False
[ExitScreen]
EnableExit=True
EnableShutdown=True
[StartupProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=true
WaitForExit=false
[ExitProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=False
WaitForExit=
[AttractMode]
Timer=1
ShowFor=15
MuteAudio=False
[System_1]
Name=MAME
Enabled=False
TablePath=C:\
Executable=mamep64.exe
Parameters=[TABLEFILE]
SystemType=0
[AutoExit]
Enabled=False
Minutes=10
[Login]
StreamQuality=7
[PinballFX2]
Enabled=False
WorkingPath=C:\Program Files (x86)\Microsoft Game Studios\Pinball FX2
Executable=Pinball FX2.exe
Parameters=-applaunch 226980 [TABLEFILE]
Process=Pinball FX2.exe
Rotate=False
WaitFor=20
[PinballArcade]
Executable=steam.exe
Parameters=-applaunch 238260
Process=PinballArcade.exe
WaitForSelect=50
[GameListManager]
onlinemode=true
[RealDMD]
EnableColor=True
Color=ffff1414
[PinballFX3]
Executable=Pinball FX3.exe
Parameters=-applaunch 442120 "-table_[TABLEFILE]"
Process=Pinball FX3.exe
Rotate=False
WaitFor=20
[Topper]
monitor=2
[VideoCapture]
KeysStartRecord=164|120
KeysEndRecord=164|120
Seconds=45
UseGPU=False
[Internal]
lastwheelcachematchsize=-1123
lastselected=Twilight Zone Skitso detail mod 1.5Twilight Zone Skitso detail mod 1.5VisualPinball
filter_year=
filter_company=
filter_custom=
filter_favorites=False
filter_lastplayed=False
filter_mostplayed=False
filtername=Tables
filter_rating=0
[Plugin_1]
Enabled=False
Name=PlugInLED.dll
[Plugin_2]
Name=PlugInSpeech.dll
[Plugin_3]
Enabled=False
[Plugin_4]
Enabled=False
Name=Xpadder Plugin.dll
[SetupWizard]
EmuPath1=C:\Emulation\Emulators
AssetPath1=C:\Emulation\Assets
ROMPath1=C:\Emulation\ROMs
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=Basic
SavePosition=False
SearchText=
EmulatorIndex=0
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=0
NewsFeedsIndex=0
MappedDrivesIndex=0
SystemIndex=1
ShowPanel=True
FontSize=1
WindowSize=650, 478
WindowLocation=1117, 101
WindowState=Maximized
CustomArray=
SearchArray=
SectionIndex=22
[frmInfo]
Size=386, 322
Location=767, 359
WindowState=Normal
[System_2]
Name=visual pinball x
Executable=VPinballX.exe
LaunchBeforeEnabled=False
[System_3]
Name=
WorkingPath=
TablePath=
Executable=
Parameters=
13:25:39.1  1/28/2019:  PinballX - Version 3.28
13:25:39.1  1/28/2019:  Windows 10 Home 64-bit (8GB)
13:25:39.1  1/28/2019:  Loading Settings
13:25:39.1  1/28/2019:  Initialize Component
13:25:39.1  1/28/2019:  Initialize Display
13:25:39.2  1/28/2019:  Loading PlugIns
13:25:39.2  1/28/2019:  Loaded Plugin:"Speak Game Names" Version 1 By Tom Speirs
13:25:39.3  1/28/2019:  PlugIn: "Speak Game Names" Initialized OK
13:25:39.3  1/28/2019:  Using Plugin System Version: 1
13:25:39.3  1/28/2019:  Looking for startup images
13:25:39.4  1/28/2019:  Testing Flash engine.
13:25:39.5  1/28/2019:  Hiding Cursor
13:25:39.5  1/28/2019:  Hiding Taskbar
13:25:39.5  1/28/2019:  Getting GPU Information
13:25:39.6  1/28/2019:  CPU:  Intel(R) Core(TM) i5-8400 CPU @ 2.80GHz
13:25:39.6  1/28/2019:  GPU 1: NVIDIA GeForce GTX 1050 Ti
13:25:39.6  1/28/2019:  Displays: 1
13:25:39.6  1/28/2019:  Load Game List
13:25:39.6  1/28/2019:  Loading Database: Pinball FX3
13:25:39.6  1/28/2019:  Loading Database: Future Pinball
13:25:39.6  1/28/2019:  Loading Database: Visual Pinball
13:25:39.6  1/28/2019:  Initial load gamelist took: 47ms
13:25:39.6  1/28/2019:  Finding and matching artwork and videos
13:25:40.0  1/28/2019:  Took: 407ms
13:25:40.0  1/28/2019:  Loading Game Statistics and Scores
13:25:40.3  1/28/2019:  Main display running full screen windowed.
13:25:40.4  1/28/2019:  Loading Surfaces
13:25:40.4  1/28/2019:  Finished Loading Surfaces
13:25:40.4  1/28/2019:  Initialize Audio
13:25:40.4  1/28/2019:  Set Keyboard Controls
13:25:40.4  1/28/2019:  Initialize Joystick
13:25:40.5  1/28/2019:  No Joysticks Attached
13:25:40.5  1/28/2019:  Started
13:25:46.0  1/28/2019:  Launch System
13:25:46.0  1/28/2019:  Waiting for threads
13:25:46.1  1/28/2019:  Disposing display
13:25:46.8  1/28/2019:  C:\Visual Pinball\VPinball995.exe /play -"C:\Visual Pinball\Tables\TOTAN_1.2.0.vpx"
13:25:46.8  1/28/2019:  C:\PinballX\vpauto.exe
13:26:34.4  1/28/2019:  Main display running full screen windowed.
13:26:38.6  1/28/2019:  Launch System
13:26:38.6  1/28/2019:  Waiting for threads
13:26:38.6  1/28/2019:  Disposing display
13:26:39.3  1/28/2019:  C:\Visual Pinball\VPinball995.exe /play -"C:\Visual Pinball\Tables\TOTAN_1.2.0.vpx"
13:26:39.3  1/28/2019:  C:\PinballX\vpauto.exe
13:27:00.7  1/28/2019:  Main display running full screen windowed.
13:27:04.1  1/28/2019:  Launch System
13:27:04.1  1/28/2019:  Waiting for threads
13:27:04.1  1/28/2019:  Disposing display
13:27:05.7  1/28/2019:  C:\Visual Pinball\VPinball995.exe /play -"C:\Visual Pinball\Tables\TOTAN_1.2.0.vpx"
13:27:05.7  1/28/2019:  C:\PinballX\vpauto.exe
13:28:39.1  1/28/2019:  Main display running full screen windowed.
13:28:56.2  1/28/2019:  Launch System
13:28:56.2  1/28/2019:  Waiting for threads
13:28:56.2  1/28/2019:  Disposing display
13:28:56.1  1/28/2019:  C:\Visual Pinball\VPinball995.exe /play -"C:\Visual Pinball\Tables\Twilight Zone Skitso detail mod 1.5.vpx"
13:28:57.0  1/28/2019:  C:\PinballX\vpauto.exe
13:30:03.7  1/28/2019:  Main display running full screen windowed.
13:30:36.3  1/28/2019:  Exiting
13:30:36.3  1/28/2019:  Showing Taskbar
13:30:36.3  1/28/2019:  Unhiding Mouse Cursor
13:30:36.3  1/28/2019:  Disposing Plugins
13:30:36.3  1/28/2019:  Saving Settings
13:30:36.3  1/28/2019:  Bye
How did you setup the tables in  gamemanager ? Did you put the correct tables to the correct vp version?
Best is to create sub dirs and put the correct table files in there
I actually use a seperate list xml for visual pinball system and don't create a seperate system for vpx. That list xml only contains vpx tables and i use the alternateexe tag for all those tables to tell it to launch vpx instead of vp9. Seems to work fine and i can make a seperate group for vp9 and vpx tables. Its just an alternate way, my guess is also that vpx tables got added to the wrong game list in his configuration.
thanks think I figured it out all the tables from my tables folder downloaded in vp9 mgr so had to delete them, now the only prob is trying to inport into vpin 10 the media, its finding nothing????
if you use seperate systems for "visual pinball" and "visual pinball X" then you need to place your media also in the correct system directories Like "Media\Visual Pinball\..." for your vp9 tables (visual pinball system) and "Media\Visual Pinball X\...." for your vpx tables (visual pinball X) system.
they might still exist in your original media folder. Each system has a seperate directory under media and if you created 2 systems one for visual pinball x and one for visual pinball (9) you need to place them in correct directory ...
ok, so I made a separate visual pinballx media folder and copied all the files I had previously downloaded and they are working correctly, but now when I try to download additional visual pinball x media it is not downloading to either folder
You may have to familiarize yourself with the folder layouts and manually download the files to the desired media folders.
finally my pc is ready every table working and uploaded to the frontload, have studied and solved every problem except when trying to import  media files   nothing will import, I really don't understand why its not pulling the media , any help , would like to figure this out so I can spend some time /w the wife and kids and not have to manually download and place all the media in the folders, any clues why its not pulling media thanks ps I am a subscriber and just looked and the media is online , it is just painfull to do manually, why cant it pull the media???
Edited by slickric
have a look in this thread i posted some info about how the search actually searches (using description field).
make sure your password is correctly entered in settings of pinballx, and it's enabled, check checkbox to go online in game manager etc and make sure windows firewall is not blocking game manager etc
