Tom Speirs Posted November 23, 2020 Share Posted November 23, 2020 16 hours ago, Mike_da_Spike said: What do you mean ? Just out of the box a launcher for PBX ? Hide Mike_da_Spike's signature Hide all signatures Also try PinballX Database manager as an alternative way for gamemanger Yes buddy. Is that okay? 3 Quote Link to comment Share on other sites More sharing options...
GAH1068 Posted November 24, 2020 Author Share Posted November 24, 2020 Great news Tom! My script works well but native support would be soooo much better! Quote Link to comment Share on other sites More sharing options...
Mike_da_Spike Posted November 24, 2020 Share Posted November 24, 2020 7 hours ago, Tom Speirs said: Yes buddy. Is that okay? Hide Tom Speirs's signature Hide all signatures Haha, is that ok ? Of course it is ! It's good news ! Thanks Tom ! Quote Link to comment Share on other sites More sharing options...
AndyMcDandy Posted November 26, 2020 Share Posted November 26, 2020 Curious, has there been any talks with the Zaccaria devs to add launch commands to their software so special script won't be needed? BTW, there is one flaw with the script. If you don't own all the tables and there happens to be a sale, the script won't load the specific table due to a sale alert pop-up. Quote Link to comment Share on other sites More sharing options...
Mike_da_Spike Posted November 26, 2020 Share Posted November 26, 2020 47 minutes ago, AndyMcDandy said: Curious, has there been any talks with the Zaccaria devs to add launch commands to their software so special script won't be needed? BTW, there is one flaw with the script. If you don't own all the tables and there happens to be a sale, the script won't load the specific table due to a sale alert pop-up. If you don't own the table, you can disable it in Databasemanager or gamemanager to avoid to select it in pbx Quote Link to comment Share on other sites More sharing options...
AndyMcDandy Posted November 26, 2020 Share Posted November 26, 2020 I only had one table active, one that I had purchased and before the script could load the actual table, Zaccaria would display a pop-up about the current sale it had. Zaccaria devs really need to add direct table launch command like Zen Studios have done with their Pinball FX3. Quote Link to comment Share on other sites More sharing options...
joyrider3774 Posted November 27, 2020 Share Posted November 27, 2020 Bought the robot table so just in case you did not know ... wheel images and logo available in other topic, music and database uploaded to ftp. Did not create any other media yet like backglass / table video / topper video <game name="robotdeluxe"> <description>Robot Deluxe (Magic Pixel 2020)</description> <rom></rom> <manufacturer>Magic Pixel</manufacturer> <year>2020</year> <type>DX</type> <hidedmd>True</hidedmd> <hidetopper>True</hidetopper> <hidebackglass>True</hidebackglass> <enabled>True</enabled> <rating>0</rating> </game> Quote Link to comment Share on other sites More sharing options...
nanuk101 Posted December 13, 2020 Share Posted December 13, 2020 thx for the table info Quote Link to comment Share on other sites More sharing options...
minivp61 Posted June 27, 2022 Share Posted June 27, 2022 Hello, Sorry if this has been already asked... Sometimes ESC does not exit out of Zaccaria. It instead goes to the Zaccaria menu. Anyone else have this problem? If so, any solution? Quote Link to comment Share on other sites More sharing options...
Mike_da_Spike Posted June 28, 2022 Share Posted June 28, 2022 5 hours ago, minivp61 said: Hello, Sorry if this has been already asked... Sometimes ESC does not exit out of Zaccaria. It instead goes to the Zaccaria menu. Anyone else have this problem? If so, any solution? I dont have any problems with the exit emulator button. Works fine for all emulators (including zaccaria) If you still encounter an issue, please open a new thread in the general Pimballx forum and attach your logfile, where you reproduced your issue and attach your pinballx.ini as well Quote Link to comment Share on other sites More sharing options...
gokwh Posted September 25, 2022 Share Posted September 25, 2022 Hi, I'm trying to use this Script but it's impossible, I don't have steam, my executable is ZaccariaPinball.exe Could you help me implement it to Pinball x? Thank you Quote Link to comment Share on other sites More sharing options...
Mike_da_Spike Posted September 26, 2022 Share Posted September 26, 2022 10 hours ago, gokwh said: Hi, I'm trying to use this Script but it's impossible, I don't have steam, my executable is ZaccariaPinball.exe Could you help me implement it to Pinball x? Thank you Did you purchase it from the Microsoft store ? I only have experience with the steam. Maybe the original ahk file will work for you EDIT : Could not find it anymore in the store. Where did you get you r version from, as far as I know, is that Steam is the only one that has it. EDIT2: In the AHK, this is the part where it launches the steam version. Modify this for you installation ;From here run your zaccaria RegRead, SteamDirPath, HKCU, Software\Valve\Steam, SteamPath Run, "%SteamDirPath%\Steam.exe" -applaunch 444930 -rotate right But no need to use the AHK anymore as Zaccaria now uses direct table launch. Quote Link to comment Share on other sites More sharing options...
gokwh Posted September 26, 2022 Share Posted September 26, 2022 Hello. I found it on the net. Does pinball x launch it directly? Is the database necessary? could you pass me a screenshot or similar of the configuration for zacarias? Thanks in advance Quote Link to comment Share on other sites More sharing options...
Mike_da_Spike Posted September 26, 2022 Share Posted September 26, 2022 12 minutes ago, gokwh said: Hello. I found it on the net. Does pinball x launch it directly? Is the database necessary? could you pass me a screenshot or similar of the configuration for zacarias? Thanks in advance All your questions will be answered if you read the following thread : https://forums.gameex.com/forums/topic/26401-zaccaria-finally-has-direct-table-launch/#comments but still, it requires the steam version. Quote Link to comment Share on other sites More sharing options...
Draco1962 Posted September 26, 2022 Share Posted September 26, 2022 Sorry to be a party pooper but here I go. So far as I am aware Zaccaria Pinball is not officially distributed for purchase through channels other than Steam. If you downloaded the app "from the internet" then discussion stops there. The official support through PinballX is the purchased Steam version only as Mike noted. Thanks. 1 Quote Link to comment Share on other sites More sharing options...
