hawkeyez88 Posted November 15, 2018 Share Posted November 15, 2018 56 minutes ago, DrEvil said: Hi I am making progress but stuck here: I have obtained .17 version of Arcooda and the latest version of FCM However, the .17 version of acrooda does not run, I think because I do not own a KINECT. Is there a version of FCM fro Arcooda version .14? You don't need the Kinect to have the version run. What behavior are you seeing when you try to start the cabinet version? Quote Link to comment Share on other sites More sharing options...
DrEvil Posted November 16, 2018 Share Posted November 16, 2018 I figured it out. I was missing the resource files. So now I have FCM initiating Arcooda but get a warning box stating I need level .17 of Arcooda, which is what I have. I just looked now at FCM again (today 11/16) and the latest release is for level 1.71.19 of Arcooda, yet I cannot find a download link to that version of Arcooda. Thanks for the help, I will keep chugging. I am actually doing a comprehensive re-configuration of my cabinet, including changing monitor config, keyboard encoder, and complete reinstall of everything including VPX, FP, PinballX and FX3. Somehow I figure a need to wipe a lot of things to get a fresh start on the latest builds and scripts. I think my biggest change is to keep my playfield in portrait all the time and now I completely avoid all screen rotation coding. This actually solves many issues with Pinballx and Arcooda and FX3, plus VPX doesnt really care. 1 Quote Link to comment Share on other sites More sharing options...
hawkeyez88 Posted November 28, 2018 Share Posted November 28, 2018 If you're running arcooda in steam, right click on it and check for updates. It should be automatic. Not sure if you got the standalone software from them or not though. On 11/16/2018 at 11:41 AM, DrEvil said: I figured it out. I was missing the resource files. So now I have FCM initiating Arcooda but get a warning box stating I need level .17 of Arcooda, which is what I have. I just looked now at FCM again (today 11/16) and the latest release is for level 1.71.19 of Arcooda, yet I cannot find a download link to that version of Arcooda. Thanks for the help, I will keep chugging. I am actually doing a comprehensive re-configuration of my cabinet, including changing monitor config, keyboard encoder, and complete reinstall of everything including VPX, FP, PinballX and FX3. Somehow I figure a need to wipe a lot of things to get a fresh start on the latest builds and scripts. I think my biggest change is to keep my playfield in portrait all the time and now I completely avoid all screen rotation coding. This actually solves many issues with Pinballx and Arcooda and FX3, plus VPX doesnt really care. Quote Link to comment Share on other sites More sharing options...
cgoran Posted November 29, 2018 Share Posted November 29, 2018 Hi guys, I'm getting quite a few errors when trying to set this up. All versions are the latest. I'm trying to just launch stand alone Arcooda not steam version. I attempted to use a command prompt to launch also - same results. I've attached several files. Is there a way to get something like this baked into PBX? Settings.ini Start_Arcooda.ahk Run_Arcooda.ahk PinballX.ini Quote Link to comment Share on other sites More sharing options...
DrEvil Posted November 29, 2018 Share Posted November 29, 2018 I was told by Arccoda that 1.71.17 is the latest cabinet version. The .19 and .20 versions apply to steam or other version of Pinball Arcade. Quote Link to comment Share on other sites More sharing options...
GAH1068 Posted November 29, 2018 Author Share Posted November 29, 2018 I am running the Steam version of Arcooda so that makes sense. Best bet woud be to go to PinballArcadeFans.com and post a message in the FreeCamMod group under TPA \ PC. NoEx (the author) might be able to help. All you may need is the previous version if you are running the offline Arcooda version. Most people bought the steam version of Arcooda if they have it. 1 Quote Link to comment Share on other sites More sharing options...
flippnswitchez Posted April 5, 2019 Share Posted April 5, 2019 Did anyone figure out how to get the standalone arcooda to run? Quote Link to comment Share on other sites More sharing options...
Draco1962 Posted April 5, 2019 Share Posted April 5, 2019 On 11/29/2018 at 10:52 AM, GAH1068 said: I am running the Steam version of Arcooda so that makes sense. Best bet woud be to go to PinballArcadeFans.com and post a message in the FreeCamMod group under TPA \ PC. NoEx (the author) might be able to help. All you may need is the previous version if you are running the offline Arcooda version. Most people bought the steam version of Arcooda if they have it. You may want to check PinballArcadeFans.com as was suggested. I believe that FCM (as of the prior posts) is for the Steam version only but I may be incorrect on this as I do not run it on my rig. Quote Link to comment Share on other sites More sharing options...
flippnswitchez Posted April 5, 2019 Share Posted April 5, 2019 1 hour ago, Draco1962 said: You may want to check PinballArcadeFans.com as was suggested. I believe that FCM (as of the prior posts) is for the Steam version only but I may be incorrect on this as I do not run it on my rig. Thanks, I checked over there. No luck but I gave Noex access to files but there was no luck. So I emailed Arcooda about it. Noex said he basically was unable to launch the .exe because of the encryption dongle. Aroocda seemed like they were willing to work with him, so I let him know to email Arcooda they might provide what he needed so hopefully those with stand-alone can enjoy FCM also. Quote Link to comment Share on other sites More sharing options...
cgoran Posted April 9, 2019 Share Posted April 9, 2019 Would love to see a solution for this. Seems like it should be doable via PBX. I wonder if PBX would let you record button presses or something to get you to the right path/ menu? Quote Link to comment Share on other sites More sharing options...
halen Posted December 11, 2019 Share Posted December 11, 2019 GAH1068 Do you have a off-line data freecam mode 1.71.20? Quote Link to comment Share on other sites More sharing options...
GAH1068 Posted December 11, 2019 Author Share Posted December 11, 2019 Doubtful, I haven't been in Arcooda much since Zen started releasing their versions of the tables. I never really run in offline mode to begin with. I will check and fire up Arcooda when I get home tonight and see if things are working. I do know that for a while people were posting different offline versions in a thread on pinballarcadefans.com . If you ask NoEx will more than likely post a version too if he can. Quote Link to comment Share on other sites More sharing options...
GAH1068 Posted December 12, 2019 Author Share Posted December 12, 2019 @halen - My version of Arcooda shows it is version 1.71.19 still. I am running the Steam version but here is the offline file I generated for it. Welcome to give it a try. OfflineData.TPA Quote Link to comment Share on other sites More sharing options...
halen Posted December 12, 2019 Share Posted December 12, 2019 Thanks man!!!!!! 1 Quote Link to comment Share on other sites More sharing options...
halen Posted April 6, 2020 Share Posted April 6, 2020 GAH 1068 I have two systems in my pincab. Arcooda and Pinball Arcade. I am working with AHK script s. Ghostbusters Stern table is in Pinball Arcade System and when i click in the wheel i have a message that table is not possible to load. Have you this problem? Do you have a xml of pinball arcade system? Quote Link to comment Share on other sites More sharing options...
GAH1068 Posted April 7, 2020 Author Share Posted April 7, 2020 I am able to run either Arcooda and standard TPA without issue. Attached is my Pinball Arcade.XML file. I don't include any of the ones that are part of the Arcooda so these are the ones that are in TPA only Pinball Arcade.xml Quote Link to comment Share on other sites More sharing options...
halen Posted November 11, 2021 Share Posted November 11, 2021 I am having problems with TPA. In Arcooda mode it only loads the program and does not load the table. This issue was described in Arcooda direct Launch for PBX. However I discovered a new app: http://www.emuline.org/topic/1826-tuto-pinball-arcade-loader/. It works great but I'm having trouble getting it to work in Pinball X. Can you help? Quote Link to comment Share on other sites More sharing options...
Mike_da_Spike Posted November 11, 2021 Share Posted November 11, 2021 1 hour ago, halen said: I am having problems with TPA. In Arcooda mode it only loads the program and does not load the table. This issue was described in Arcooda direct Launch for PBX. However I discovered a new app: http://www.emuline.org/topic/1826-tuto-pinball-arcade-loader/. It works great but I'm having trouble getting it to work in Pinball X. Can you help? Never seen that tool before, but whats the issue you facing ? If you have an issue, you must describe what your issue is. Make sure you can launch a table from the command prompt. if you got that working, you can add it to PBX. Please provide your setup (pinballx.ini) and your log file. (Log.txt) Quote Link to comment Share on other sites More sharing options...
halen Posted November 11, 2021 Share Posted November 11, 2021 The issue is: I should not be able to launch a table directly outside PinballX. TPAFreeCamMod.exe -arcooda -table fnhouse When i use the command -arcooda the PBA open but not in the table. If i use the command without -arcooda the TPAFREECAMMOD works without problem. I test Pinball Arcade Loader and works better than TPAFREECAM. The table load fast. But i need help to edit the script to use Pinball Arcade Loader only to Arcooda tables. Quote Link to comment Share on other sites More sharing options...
Draco1962 Posted November 11, 2021 Share Posted November 11, 2021 1 hour ago, halen said: The issue is: I should not be able to launch a table directly outside PinballX. TPAFreeCamMod.exe -arcooda -table fnhouse When i use the command -arcooda the PBA open but not in the table. If i use the command without -arcooda the TPAFREECAMMOD works without problem. I test Pinball Arcade Loader and works better than TPAFREECAM. The table load fast. But i need help to edit the script to use Pinball Arcade Loader only to Arcooda tables. Please attach copies of your pinballx.ini and log.txt files as requested. Quote Link to comment Share on other sites More sharing options...
Mike_da_Spike Posted November 11, 2021 Share Posted November 11, 2021 Its along time I setup tpa arcooda and all. But wasnt it for arcooda mode, that you need to change some files ? So tpa is almost the same, only less tables and menu different ? So, is your tpa in "arcooda" mode ? As -arcooda doesnt set it to arcooda. Checking the tpa loader, it looks pretty straight forward. Run in command line: PinballArcadeLoader.exe PathToYourExe NameOfYourTable For example PinballArcadeLoader.exe "C:\Pinball Arcade\PinballArcade11.exe" StarTrekTNG Thee are some parameters as well, for camera lock and players Quote Link to comment Share on other sites More sharing options...
halen Posted November 11, 2021 Share Posted November 11, 2021 Mike The pinballArcadeloader is working here. The question is: How i work pinballarcadeloader on pinball x to recognize the parameters [Table] and when i click on the wheel the table open. I have two emulators. The Pinball Arcade that i use to TPAFREECAMMODE (Tables that not working on Arccoda- Stern Table for example) and Arcooda to open the Pinball Arcooda Tables . I have the script and configuration of GAH1068 and was working without issue. But i dont know why the Arcooda is not working more. I said i try to load the table from CMD with the command TPAFreeCamMod.exe -arcooda -table fnhouse and is not working. I think the problem is not pinball X. PinballX.ini log.txt Quote Link to comment Share on other sites More sharing options...
Mike_da_Spike Posted November 12, 2021 Share Posted November 12, 2021 I will make a real install document with settings in a few weeks. As I said, I didn't use TPA for a long time, and didn't test anything yet (3.2 hours for total play is not much and bought all the packs before the license expired ). But think this needs to be done : I hope this works for you and that it does make sense (I'm not a native English speaker, so apologize for any typo/incorrect sentence or even wrong words) Workingpath : path where you have the pinballarcade loader have installed/placed in my case : C:\PINBALL\SCRIPTS\PBALOADER I Have a folder C:\pinball where I install everything (even Steam) under this folder I have a scripts for all kind of stuff to help an emulator launch, or startup scripts Executable : PinballArcadeloader.exe This is the exe file that needs to be used Parameters : "<path to your executable>" [TABLEFILE] In my case : "C:\Pinball\steam\steamapps\common\PinballArcade\PinballArcadeCabinet.EXE" [TABLEFILE] (as I installed steam under c:\pinball) Within your favourite program to manage the tables, you must make sure all the table names are corresponding to the table to launch Process to monitor : PinballArcadeCabinet.exe This is btw my original setup on my cabinet. Not sure if this is still valid (and yes. I use the -arcooda as well ) 1 Quote Link to comment Share on other sites More sharing options...
halen Posted November 12, 2021 Share Posted November 12, 2021 Mike, Thanks Man!!! Works like a charm!!! I rotate the screen with display.exe and add HIDETEXT in the parameters: "C:\Pinball\steam\steamapps\common\PinballArcade\PinballArcadeCabinet.EXE" [TABLEFILE] HIDETEXT Quote Link to comment Share on other sites More sharing options...
Mike_da_Spike Posted November 12, 2021 Share Posted November 12, 2021 12 minutes ago, halen said: Mike, Thanks Man!!! Works like a charm!!! I rotate the screen with display.exe and add HIDETEXT in the parameters: "C:\Pinball\steam\steamapps\common\PinballArcade\PinballArcadeCabinet.EXE" [TABLEFILE] HIDETEXT Awesome. Maybe you can use @joyrider3774his fx3 launcher to add the parameters via een menu. I will create complete documentation and if nobody creates something with joyriders his framework, I will putt something together. Cool that you are happy. I was not able to test it yet Quote Link to comment Share on other sites More sharing options...
