Do they play nice or is there an option to enable?
ON first attempt I get LED Blinky to work in testing modes for LEDBlinky setup but no lights in GameEx Arcade edition.  Curious if this works with GameEx Arcade.
Are you running GameEx AE as the 64-bit version? If so, you may want to force 32-bit install by unchecking the box for "Install 64 bit version." and see if LED Blinky works in AE. Tom had made a note that some plugins may not work unless they are written to address 64-bit.
ok ill give it a try...i imagine I installed 64bit if it was available
there appears to only be one download for Arcade edition....  So that is what I have installed.  Maybe I just don't know where to enable.  Where do you enable in normal GameEx?
When you run the installer, click yes to accept the terms and click Next. There should be a check box to install 64 bit version. Uncheck it, click next and continue your install.
ok..installing...will test when i get home.  Does LEDBlinky just work natively(I know you need to tell LEDBlinky to use GameEx as a front end) but i cant rememeber if anything needs tweaked on GameEx side or if it just works.
Had hoped it would work, but it may be that a version needs to be made compatible for GameEx Arcade.  It was worth a try.
ill look in to seeing if i can rum command line version or something
Actually found plugin n eeded to be enabled in GameEx itself too  :)  Once I turned that on I have LIGHTS!  I need to tweak controls but much better off now...duh
So enabled in both GameEx AE (assuming via Setup Wizard) and via the Plugin interface?  Did you test it with 64 bit AE installed?
yeah i am still musing 64bit version
yeah...working is relative.  Cant get the contros to light...ill head over to arcade controls for that.  amazing how much i have forgotten since i set this up like 5 years ago  :)
thanks for help!
  • tthurman locked this topic
