I have downloaded the Mame system update pack but when I run it I get the error "Invalid Rom Path"
My setup is
Gammex is in C:\Gameex
Roms are in D:\MAME 0184 Roms (couldnt fit them on my C drive)
Any ideas?????
Jason
Can you please attach copies of your gameex.ini and log.txt files in reply to this thread?  Thanks!
The MAME system pack?
The only update pack I'm familiar with is for romsets, and in addition to not being available here,  is made to be used with a set manager.
Sorry.  Have used the wrong terminology.  I meant the Mame System Pack (Forget the update bit)  See attached
Awesome, thanks Tom.  The set I have is an upgraded set from the 0161 rom set.  I upgraded this to 0184 using clrmamepro.  For some reason the 005.zip rom was missing.  Just re-downloaded it, added it to my roms and it worked.
Thanks again.
Jason
Hi@dalob ... I edited your post already but please make note of the forum rules and don't mention where you get your ROM sets from. Next time we'll have to formally warn you. 😉
